Problem z kolerem w zmodeler 2.2.6 - Wersja do druku +- eTrucks.pl • Od 16 lat najlepsze forum z modami do ETS1, GTS, ETS2, ATS, ST (http://etrucks.pl) +-- Dział: Wasza Twórczość (/forum-167.html) +--- Dział: Modelowanie 3D (/forum-268.html) +---- Dział: Pomoc (/forum-272.html) +---- Wątek: Problem z kolerem w zmodeler 2.2.6 (/thread-20083.html) Strony: 1 2 |
RE: Problem z kolerem w zmodeler 2.2.6 - Michal_Z_gno - 10/06/2014 09:16 PM Log masz w moje dokumenty/euro truck simulator 2/ game.log Wklej to co masz w tym pliku to będzie wiadomo co jest nie tak. RE: Problem z kolerem w zmodeler 2.2.6 - dominik_SKIPPER - 10/06/2014 09:22 PM (10/06/2014 09:16 PM)Michal_Z_gno napisał(a): Log masz w moje dokumenty/euro truck simulator 2/ game.log Dzięki wielkie Jutro wszystko wklej bo już idę spać :ff: RE: Problem z kolerem w zmodeler 2.2.6 - dominik_SKIPPER - 11/06/2014 01:42 PM (10/06/2014 09:16 PM)Michal_Z_gno napisał(a): Log masz w moje dokumenty/euro truck simulator 2/ game.log Jak chciałeś skopiowałem cały log ************ : log created on : Tuesday June 10 2014 @ 20:00:54 00:00:00.000 : [sys] running on x86 / Windows 7 x64 (version 6.1) 00:00:00.000 : [sys] DirectX version : 4.09.00.0904 00:00:00.000 : [sys] Command line: C:\Program Files (x86)\Euro Truck Simulator 2\bin\win_x86\eurotrucks2.exe 00:00:00.000 : [cpu] CPU0: GenuineIntel [Pentium® Dual-Core CPU E5200 @ 2.50GHz] with 2 cores (2 threads) at ~2500MHz. 00:00:00.000 : [sys] using 1 worker thread(s) 00:00:00.000 : [sys] using QPC / TSC invariant timer, frequency 2441445Hz 00:00:00.000 : [mem] physical total: 3070M 00:00:00.000 : [mem] physical avail: 2432M 00:00:00.000 : [mem] virtual total: 4095M 00:00:00.000 : [mem] virtual avail: 4022M 00:00:00.000 : [mem] Trying to allocate memory pool (409600K) 00:00:00.000 : [mem] Allocated 5 temporary loading buffer(s) 00:00:00.827 : Disabling color wrap as both color strings are empty 00:00:00.890 : [hashfs] base.scs: Mounted and validated, 47764 entries (720200D506205404FB8361E9258210F965123EEDBD80D4D7C4CBA9E76270C45) 00:00:00.893 : [hashfs] core.scs: Mounted and validated, 3 entries (6BBE64745A8E4785DBD1D71FCC22832326B1846769601000BC06149F5D51B3B) 00:00:00.988 : [hashfs] def.scs: Mounted and validated, 4835 entries (C47D41F8CF0673DFCFE3C78889A786613C438FA37FD6CE2600A1838E4439F28) 00:00:01.076 : [hashfs] locale.scs: Mounted and validated, 133 entries (89F2F20A9DE9F85F7AFD0F916070D6F938DF040C9EF0DA94421632A3E17CDE9) 00:00:01.078 : [hashfs] base_cfg.scs: Mounted and validated, 2 entries (27EDE39735C64660F3FAA075FCF752EA4D2D915D5648BF1F47EB703489D0C6F) 00:00:01.079 : [ufs] Home directory: 'C:/Users/michalik/Documents/Euro Truck Simulator 2'. 00:00:01.079 : exec /home/config.cfg 00:00:01.079 : [sys] Executing /home/config.cfg ... 00:00:01.079 : uset r_full_resolution_corrections "0" 00:00:01.079 : uset r_force_color_shadowmaps "0" 00:00:01.080 : uset g_hw_info "1" 00:00:01.080 : uset g_cargo_sort "0" 00:00:01.080 : uset g_tooltip_delay "0.4" 00:00:01.080 : uset g_global_force_load_selector "0" 00:00:01.080 : uset g_desktop_fadeout "60" 00:00:01.080 : uset r_wireframe "0" 00:00:01.080 : uset r_multimon_border_fov_right "0" 00:00:01.080 : uset r_multimon_border_fov_left "0" 00:00:01.080 : uset r_multimon_mode "0" 00:00:01.080 : uset r_segment_cache_static_buffers "1" 00:00:01.080 : uset r_segment_cache_behavior "3" 00:00:01.080 : uset r_use_depth_bounds "1" 00:00:01.080 : uset r_show_light_pixel_coverage "0" 00:00:01.080 : uset r_deferred_debug "0" 00:00:01.080 : uset r_mirror_scale_y "1.0" 00:00:01.080 : uset r_mirror_scale_x "1.0" 00:00:01.080 : uset r_scale_y "1" 00:00:01.080 : uset r_scale_x "0.75" 00:00:01.080 : uset r_normal_maps "1" 00:00:01.080 : uset r_sunshafts "1" 00:00:01.080 : uset r_color_saturation "0.0" 00:00:01.080 : uset r_color_yellow_blue "0.0" 00:00:01.080 : uset r_color_magenta_green "0.0" 00:00:01.080 : uset r_color_cyan_red "0.0" 00:00:01.080 : uset r_color_correction "1" 00:00:01.080 : uset r_dof_filter_size "0.5" 00:00:01.080 : uset r_dof_transition "400.0" 00:00:01.080 : uset r_dof_start "200.0" 00:00:01.080 : uset r_dof "1" 00:00:01.080 : uset r_mlaa_threshold "1.0" 00:00:01.080 : uset r_mlaa "0" 00:00:01.081 : uset r_hdr "0" 00:00:01.081 : uset r_fake_shadows "2" 00:00:01.081 : uset r_sun_shadow_texture_size "2048" 00:00:01.081 : uset r_sun_shadow_quality "2" 00:00:01.081 : uset r_mirror_view_distance "80" 00:00:01.081 : uset r_deferred_mirrors "0" 00:00:01.081 : uset r_deferred "1" 00:00:01.081 : uset r_nowmi "0" 00:00:01.081 : uset r_startup_progress "0" 00:00:01.081 : uset r_setup_done "1" 00:00:01.081 : uset r_gamma "1" 00:00:01.081 : uset r_manual_stereo_buffer_scale "1.0" 00:00:01.081 : uset r_manual_stereo_ui_fov_game "100" 00:00:01.081 : uset r_manual_stereo_ui_fov "80" 00:00:01.081 : uset r_manual_stereo_ui_dist_game "0.5" 00:00:01.081 : uset r_manual_stereo_ui_dist "0.8" 00:00:01.081 : uset r_manual_stereo_in_menu "1" 00:00:01.081 : uset r_nv_stereo_mode "2" 00:00:01.081 : uset r_no_frame_tracking "0" 00:00:01.081 : uset r_msaa "0" 00:00:01.081 : uset r_fullscreen "1" 00:00:01.081 : uset r_mode "1440x900x32x0" 00:00:01.081 : uset r_path "" 00:00:01.081 : uset r_device "dx9" 00:00:01.081 : uset i_virtual_cursor_speed "500.0" 00:00:01.081 : uset g_trackir "1" 00:00:01.081 : uset g_pedestrian "1" 00:00:01.081 : uset g_light_span_factor "0.25" 00:00:01.081 : uset g_light_distance_factor "0.25" 00:00:01.081 : uset g_vehicle_flare_lights "1" 00:00:01.082 : uset g_auto_traffic_headlights "1" 00:00:01.082 : uset g_auto_traffic "1" 00:00:01.082 : uset g_kdop_preview "0" 00:00:01.082 : uset g_screenshot_on_bug "0" 00:00:01.082 : uset g_developer "1" 00:00:01.082 : uset g_wc_fps "0.0" 00:00:01.082 : uset g_wc_radius "-1.0" 00:00:01.082 : uset g_steam_screenshots "2" 00:00:01.082 : uset g_artist_id "0" 00:00:01.082 : uset g_flyspeed "100.0" 00:00:01.082 : uset g_news "1" 00:00:01.082 : uset g_colbox "0" 00:00:01.082 : uset g_radio_mode "1" 00:00:01.082 : uset g_ignore_low_fps "0" 00:00:01.082 : uset g_truck_light_quality "1" 00:00:01.082 : uset g_truck_light_specular "1" 00:00:01.082 : uset g_gfx_all_scales "0" 00:00:01.082 : uset g_gfx_advanced "1" 00:00:01.082 : uset g_gfx_quality "1" 00:00:01.082 : uset g_menu_aa_limit "8" 00:00:01.082 : uset g_additional_water_fov "20.0f" 00:00:01.082 : uset g_rain_reflect_hookups "0" 00:00:01.082 : uset g_rain_reflect_actor "0" 00:00:01.082 : uset g_rain_reflect_traffic "0" 00:00:01.082 : uset g_rain_reflect_cache "0" 00:00:01.082 : uset g_rain_reflection "1" 00:00:01.082 : uset g_reflection "1" 00:00:01.082 : uset g_grass_density "0" 00:00:01.082 : uset g_veg_detail "0" 00:00:01.082 : uset g_minicon "0" 00:00:01.082 : uset g_console "1" 00:00:01.083 : uset g_texture_usage_stats "0" 00:00:01.083 : uset g_fps "0" 00:00:01.083 : uset g_stream_exts ".ogg;.mp3" 00:00:01.083 : uset r_vsync "0" 00:00:01.083 : uset r_anisotropy_factor "0.1875" 00:00:01.083 : uset r_texture_detail "1" 00:00:01.083 : uset t_averaging_window_length "20" 00:00:01.091 : [lang] Language autodetection: 415 00:00:01.104 : Selected language: pl_pl 00:00:01.104 : Euro Truck Simulator 2 init ver.1.9.22s (rev. 52066) 00:00:01.104 : [net] LOG INFO: Started 00:00:01.116 : Setting UI reference mode to: 1440x900... 00:00:01.116 : [gfx] Selected rendering device: dx9 00:00:01.124 : [dx9] NVAPI not detected. (-2) 00:00:01.124 : [dx9] Direct3D9Ex detected. 00:00:01.124 : [dx9] Number of adapters found: 1 00:00:05.945 : [dx9] Adapter #0: NVIDIA GeForce 9500 GT (Microsoft Corporation - WDDM v1.1) / 1009 (1024) MB (nvd3dum.dll, 8.15.11.8593, 20090514) 00:00:05.946 : [dx9] Using SM3X rendering path 00:00:05.946 : [gfx] Trying to set 1440x900 32bpp 60Hz (fullscreen) 00:00:06.208 : [dx9] D3D9 device sucessfully created [HWVP] 00:00:06.701 : Game viewport set to: (window aspect ratio=1.60); viewport bounds=[left=0.00 right=1440.00 bottom=0.00 top=900.00] 00:00:06.701 : UI viewport set to: viewport bounds=[left=0.00 right=1440.00 bottom=0.00 top=900.00] 00:00:07.384 : [al] device: OpenAL Soft 00:00:07.384 : [al] context extensions: ALC_ENUMERATE_ALL_EXT ALC_ENUMERATION_EXT ALC_EXT_CAPTURE ALC_EXT_DEDICATED ALC_EXT_disconnect ALC_EXT_EFX ALC_EXT_thread_local_context ALC_SOFT_loopback 00:00:11.619 : [al] vendor: OpenAL Community 00:00:11.619 : [al] version: 1.1 ALSOFT 1.14 00:00:11.619 : [al] renderer: OpenAL Soft 00:00:11.619 : [al] extensions: AL_EXT_ALAW AL_EXT_DOUBLE AL_EXT_EXPONENT_DISTANCE AL_EXT_FLOAT32 AL_EXT_IMA4 AL_EXT_LINEAR_DISTANCE AL_EXT_MCFORMATS AL_EXT_MULAW AL_EXT_MULAW_MCFORMATS AL_EXT_OFFSET AL_EXT_source_distance_model AL_LOKI_quadriphonic AL_SOFT_buffer_samples AL_SOFT_buffer_sub_data AL_SOFTX_deferred_updates AL_SOFT_direct_channels AL_SOFT_loop_points 00:00:11.619 : [snd] Started sound update thread 00:00:11.630 : [di8] Initializing device '@@keyboard@@' as 'keyboard' 00:00:11.632 : [di8] Initializing device '@@i_mouse@@' as 'mouse' 00:00:11.946 : [net] SOCK ERRO: getaddinfo('news.eut2.online.scssoft.com','80') ver 0 type 1 proto 6 failed 0x00002af9 00:00:11.946 : [net] HTTP ERRO: Unable to connect to 'http://news.eut2.online.scssoft.com/eut2/news/1.9.22s/pl_pl?i=78DA1DCDCB0E82301404D05F99252CACB7D002DD6944D18586181F6BA33521516A0A2231F7E305679693CCE9B304539CABFAE63E0D52F48942D059DF54AE462264C8A5ADDBEAFD0CF621F2F7E53159386F814579C43F4B1D110133444253B1FE72A4690CC79412EF4E9B7C33476157CE5F2DCCB0A13820D85657EF1A776F31DCBD9CBFB4A337C139CFB7E8E4E84A22C399905A4829326DE260800C69A942BEF586A552C46680C62AFE017C163849' 00:00:11.946 : [net] LINK ERRO: Unable to connect. 00:00:12.678 : [hashfs] dlc_east.scs: Mounted and validated, 746 entries (AF5067D5F6CF0DA51FA752D52761DCAB3AE22B9BD14D2FFA29732A94ED72CC6) 00:00:12.690 : dispatch 00:00:12.690 : exit 00:00:27.289 : [inp] Classifying devices 00:00:28.053 : [hashfs] dlc_east.scs: Mounted and validated, 746 entries (AF5067D5F6CF0DA51FA752D52761DCAB3AE22B9BD14D2FFA29732A94ED72CC6) 00:00:28.060 : uset s_sfx_enabled "1" 00:00:28.060 : uset s_music_enabled "1" 00:00:28.060 : uset s_sfx_volume "1.0" 00:00:28.060 : uset s_music_volume "0.8" 00:00:28.060 : uset s_master_volume "1.0" 00:00:28.060 : uset s_reverse_stereo "0" 00:00:28.060 : uset g_force_economy_reset "0" 00:00:28.060 : uset g_force_load_selector "0" 00:00:28.060 : uset g_autoload_ignore_autosave "0" 00:00:28.060 : uset g_start_in_truck "0" 00:00:28.060 : uset g_input_configured "1" 00:00:28.060 : uset g_income_factor "1.0" 00:00:28.060 : uset g_currency "0" 00:00:28.060 : uset g_bad_weather_factor "0.07" 00:00:28.060 : uset g_save_idx "1" 00:00:28.060 : uset g_adviser "0" 00:00:28.060 : uset g_desktop_tutorial "1" 00:00:28.060 : uset g_tutorial "1" 00:00:28.060 : uset g_fatigue "1" 00:00:28.060 : uset g_police "1" 00:00:28.060 : uset g_subtitles "0" 00:00:28.060 : uset g_clock_24 "1" 00:00:28.060 : uset g_oculus_no_3d_background "0" 00:00:28.060 : uset g_oculus_no_special_menu "0" 00:00:28.060 : uset g_oculus_reduced_cabin_movement "1" 00:00:28.060 : uset g_oculus_no_artifical_movement "0" 00:00:28.060 : uset i_oculus_eye_protrusion "0.09" 00:00:28.060 : uset i_oculus_eye_height "0.15" 00:00:28.060 : uset i_oculus_max_prediction "0.1" 00:00:28.060 : uset i_oculus_min_prediction "0.0" 00:00:28.060 : uset s_interior_volume "1.0" 00:00:28.060 : uset s_rumble_enabled "1" 00:00:28.060 : uset s_reverse_enabled "1" 00:00:28.060 : uset g_throttle_auto_shift "0" 00:00:28.060 : uset g_pedal_clutch_range "1.0" 00:00:28.060 : uset g_fuel_simulation "0" 00:00:28.060 : uset g_hardcore_simulation "0" 00:00:28.060 : uset g_reg_setting "reg_setting.europe" 00:00:28.060 : uset g_use_speed_limiter "1" 00:00:28.060 : uset g_engine_start_auto "1" 00:00:28.060 : uset g_motor_brake_auto "0" 00:00:28.060 : uset g_retarder_auto "0" 00:00:28.060 : uset g_brake_intensity "1.0" 00:00:28.060 : uset g_steer_autocenter "1" 00:00:28.060 : uset g_gallon "0" 00:00:28.060 : uset g_fahrenheit "0" 00:00:28.061 : uset g_pounds "kg" 00:00:28.061 : uset g_mph "0" 00:00:28.061 : uset g_hshifter_layout "0" 00:00:28.061 : uset g_trans "0" 00:00:28.061 : uset g_lang "pl_pl" 00:00:28.089 : [net] SOCK ERRO: getaddinfo('news.eut2.online.scssoft.com','80') ver 0 type 1 proto 6 failed 0x00002af9 00:00:28.089 : [net] HTTP ERRO: Unable to connect to 'http://news.eut2.online.scssoft.com/eut2/news/1.9.22s/pl_pl?i=78DA1DCDCB0E82301404D05F99252CACB7D002DD6944D18586181F6BA33521516A0A2231F7E305679693CCE9B304539CABFAE63E0D52F48942D059DF54AE462264C8A5ADDBEAFD0CF621F2F7E53159386F814579C43F4B1D110133444253B1FE72A4690CC79412EF4E9B7C33476157CE5F2DCCB0A13820D85657EF1A776F31DCBD9CBFB4A337C139CFB7E8E4E84A22C399905A4829326DE260800C69A942BEF586A552C46680C62AFE017C163849' 00:00:28.089 : [net] LINK ERRO: Unable to connect. 00:00:31.281 : Mounting extra package: C:/Users/michalik/Documents/Euro Truck Simulator 2/mod/Schmitz SKO.scs 00:00:31.304 : [zipfs] Schmitz SKO.scs: read ok, 114 entries [0x82f14877] 00:00:31.304 : Mounting extra package: C:/Users/michalik/Documents/Euro Truck Simulator 2/mod/zLIGHTS fix XENON.scs 00:00:31.304 : [zipfs] zLIGHTS fix XENON.scs: read ok, 38 entries [0xafb9805a] 00:00:34.346 : Mounting extra package: C:/Users/michalik/Documents/Euro Truck Simulator 2/mod/Scania V8 .scs 00:00:34.356 : [zipfs] Scania V8 .scs: read ok, 430 entries [0x5f15b8fd] 00:00:34.356 : Mounting extra package: C:/Users/michalik/Documents/Euro Truck Simulator 2/mod/Schmitz SKO.scs 00:00:34.358 : [zipfs] Schmitz SKO.scs: read ok, 114 entries [0x82f14877] 00:00:34.358 : Mounting extra package: C:/Users/michalik/Documents/Euro Truck Simulator 2/mod/zLIGHTS fix XENON.scs 00:00:34.359 : [zipfs] zLIGHTS fix XENON.scs: read ok, 38 entries [0xafb9805a] 00:00:36.090 : uset s_sfx_enabled "1" 00:00:36.090 : uset s_music_enabled "1" 00:00:36.090 : uset s_sfx_volume "1.0" 00:00:36.090 : uset s_music_volume "0.8" 00:00:36.090 : uset s_master_volume "1.0" 00:00:36.090 : uset s_reverse_stereo "0" 00:00:36.090 : uset g_force_economy_reset "0" 00:00:36.090 : uset g_force_load_selector "0" 00:00:36.090 : uset g_autoload_ignore_autosave "0" 00:00:36.090 : uset g_start_in_truck "0" 00:00:36.090 : uset g_input_configured "1" 00:00:36.090 : uset g_income_factor "1.0" 00:00:36.091 : uset g_currency "0" 00:00:36.091 : uset g_bad_weather_factor "0.07" 00:00:36.091 : uset g_save_idx "1" 00:00:36.091 : uset g_adviser "0" 00:00:36.091 : uset g_desktop_tutorial "1" 00:00:36.091 : uset g_tutorial "1" 00:00:36.091 : uset g_fatigue "1" 00:00:36.091 : uset g_police "1" 00:00:36.091 : uset g_subtitles "0" 00:00:36.091 : uset g_clock_24 "1" 00:00:36.091 : uset g_oculus_no_3d_background "0" 00:00:36.091 : uset g_oculus_no_special_menu "0" 00:00:36.091 : uset g_oculus_reduced_cabin_movement "1" 00:00:36.091 : uset g_oculus_no_artifical_movement "0" 00:00:36.091 : uset i_oculus_eye_protrusion "0.09" 00:00:36.091 : uset i_oculus_eye_height "0.15" 00:00:36.091 : uset i_oculus_max_prediction "0.1" 00:00:36.091 : uset i_oculus_min_prediction "0.0" 00:00:36.091 : uset s_interior_volume "1.0" 00:00:36.091 : uset s_rumble_enabled "1" 00:00:36.091 : uset s_reverse_enabled "1" 00:00:36.091 : uset g_throttle_auto_shift "0" 00:00:36.091 : uset g_pedal_clutch_range "1.0" 00:00:36.091 : uset g_fuel_simulation "0" 00:00:36.091 : uset g_hardcore_simulation "0" 00:00:36.091 : uset g_reg_setting "reg_setting.europe" 00:00:36.091 : uset g_use_speed_limiter "1" 00:00:36.091 : uset g_engine_start_auto "1" 00:00:36.091 : uset g_motor_brake_auto "0" 00:00:36.091 : uset g_retarder_auto "0" 00:00:36.091 : uset g_brake_intensity "1.0" 00:00:36.091 : uset g_steer_autocenter "1" 00:00:36.091 : uset g_gallon "0" 00:00:36.091 : uset g_fahrenheit "0" 00:00:36.091 : uset g_pounds "kg" 00:00:36.091 : uset g_mph "0" 00:00:36.091 : uset g_hshifter_layout "0" 00:00:36.091 : uset g_trans "0" 00:00:36.091 : uset g_lang "pl_pl" 00:00:36.206 : [net] SOCK ERRO: getaddinfo('news.eut2.online.scssoft.com','80') ver 0 type 1 proto 6 failed 0x00002af9 00:00:36.206 : [net] HTTP ERRO: Unable to connect to 'http://news.eut2.online.scssoft.com/eut2/news/1.9.22s/pl_pl?i=78DA1DCDCB0E82301404D05F99252CACB7D002DD6944D18586181F6BA33521516A0A2231F7E305679693CCE9B304539CABFAE63E0D52F48942D059DF54AE462264C8A5ADDBEAFD0CF621F2F7E53159386F814579C43F4B1D110133444253B1FE72A4690CC79412EF4E9B7C33476157CE5F2DCCB0A13820D85657EF1A776F31DCBD9CBFB4A337C139CFB7E8E4E84A22C399905A4829326DE260800C69A942BEF586A552C46680C62AFE017C163849' 00:00:36.207 : [net] LINK ERRO: Unable to connect. 00:00:37.584 : uset s_sfx_enabled "1" 00:00:37.584 : uset s_music_enabled "1" 00:00:37.584 : uset s_sfx_volume "1.0" 00:00:37.584 : uset s_music_volume "0.8" 00:00:37.584 : uset s_master_volume "1.0" 00:00:37.584 : uset s_reverse_stereo "0" 00:00:37.584 : uset g_force_economy_reset "0" 00:00:37.584 : uset g_force_load_selector "0" 00:00:37.584 : uset g_autoload_ignore_autosave "0" 00:00:37.584 : uset g_start_in_truck "0" 00:00:37.584 : uset g_input_configured "1" 00:00:37.584 : uset g_income_factor "1.0" 00:00:37.584 : uset g_currency "0" 00:00:37.584 : uset g_bad_weather_factor "0.07" 00:00:37.584 : uset g_save_idx "1" 00:00:37.584 : uset g_adviser "0" 00:00:37.584 : uset g_desktop_tutorial "1" 00:00:37.584 : uset g_tutorial "1" 00:00:37.584 : uset g_fatigue "1" 00:00:37.584 : uset g_police "1" 00:00:37.584 : uset g_subtitles "0" 00:00:37.584 : uset g_clock_24 "1" 00:00:37.584 : uset g_oculus_no_3d_background "0" 00:00:37.584 : uset g_oculus_no_special_menu "0" 00:00:37.584 : uset g_oculus_reduced_cabin_movement "1" 00:00:37.584 : uset g_oculus_no_artifical_movement "0" 00:00:37.584 : uset i_oculus_eye_protrusion "0.09" 00:00:37.584 : uset i_oculus_eye_height "0.15" 00:00:37.584 : uset i_oculus_max_prediction "0.1" 00:00:37.584 : uset i_oculus_min_prediction "0.0" 00:00:37.584 : uset s_interior_volume "1.0" 00:00:37.584 : uset s_rumble_enabled "1" 00:00:37.584 : uset s_reverse_enabled "1" 00:00:37.585 : uset g_throttle_auto_shift "0" 00:00:37.585 : uset g_pedal_clutch_range "1.0" 00:00:37.585 : uset g_fuel_simulation "0" 00:00:37.585 : uset g_hardcore_simulation "0" 00:00:37.585 : uset g_reg_setting "reg_setting.europe" 00:00:37.585 : uset g_use_speed_limiter "1" 00:00:37.585 : uset g_engine_start_auto "1" 00:00:37.585 : uset g_motor_brake_auto "0" 00:00:37.585 : uset g_retarder_auto "0" 00:00:37.585 : uset g_brake_intensity "1.0" 00:00:37.585 : uset g_steer_autocenter "1" 00:00:37.585 : uset g_gallon "0" 00:00:37.585 : uset g_fahrenheit "0" 00:00:37.585 : uset g_pounds "kg" 00:00:37.585 : uset g_mph "0" 00:00:37.585 : uset g_hshifter_layout "0" 00:00:37.585 : uset g_trans "0" 00:00:37.585 : uset g_lang "pl_pl" 00:00:37.597 : New profile selected: 'Dominik' 00:00:37.597 : Mounting extra package: C:/Users/michalik/Documents/Euro Truck Simulator 2/mod/Scania V8 .scs 00:00:37.603 : [zipfs] Scania V8 .scs: read ok, 430 entries [0x5f15b8fd] 00:00:37.603 : Mounting extra package: C:/Users/michalik/Documents/Euro Truck Simulator 2/mod/Schmitz SKO.scs 00:00:37.605 : [zipfs] Schmitz SKO.scs: read ok, 114 entries [0x82f14877] 00:00:37.605 : Mounting extra package: C:/Users/michalik/Documents/Euro Truck Simulator 2/mod/zLIGHTS fix XENON.scs 00:00:37.605 : [zipfs] zLIGHTS fix XENON.scs: read ok, 38 entries [0xafb9805a] 00:00:39.656 : <ERROR> Missing mods or dlcs [1]: vehicle.scs 00:00:41.633 : game /home/profiles/446F6D696E696B/save/autosave 00:00:42.118 : [bullet] Starting physics server: Bullet 00:00:42.592 : Loaded trailers: 75 00:00:42.595 : Loaded small traffic vehicles: 29 00:00:42.599 : Loaded truck traffic vehicles: 15 00:00:42.600 : Loaded traffic trailers: 14 00:00:42.601 : Loaded addon hookups: 16 00:00:42.602 : Loading resource server data .... 00:00:42.602 : Loading road data .... 00:00:42.605 : Loading terrain data .... 00:00:42.611 : Loading railing data .... 00:00:42.614 : Loading building data .... 00:00:42.620 : Loading model data .... 00:00:42.635 : Loading prefab data .... 00:00:43.602 : Loading traffic rule data .... 00:00:43.618 : Loading sign data .... 00:00:43.645 : Loading traffic semaphore data .... 00:00:43.647 : Loading vegetation data .... 00:00:43.666 : Loading hinges data .... 00:00:43.667 : Loading stamp data .... 00:00:43.670 : Loading movers data .... 00:00:43.673 : Loading ferry data .... 00:00:43.674 : Loading country data .... 00:00:43.688 : Loading sound item data .... 00:00:43.689 : Loading live stream data .... 00:00:43.690 : Loading game condition data .... 00:00:43.691 : Loading trigger action data .... 00:00:43.693 : Loading cutscene data .... 00:00:43.721 : Loading cargo data .... 00:00:43.726 : Loading company data .... 00:00:43.772 : Loading city data .... 00:00:43.939 : Resources load time: 1839ms (25 MB) 00:00:43.953 : Map '/map/europe.mbd' loading started .... 00:00:46.729 : Map successfully loaded. 00:00:46.772 : Map load time: 2818ms (55 MB) 00:00:47.183 : Road network navigation caching started. 00:00:54.944 : Road network navigation caching finished. 00:00:54.975 : Garage update started. 00:00:54.975 : Garage update finished. 00:00:54.976 : Economy load time: 12877ms (22 MB) 00:00:56.420 : <WARNING> [resource_task] Default temporary buffer is insufficient while reading '/vehicle/truck/scania_rcab_2009/truck.pmg' with size 26536952 00:00:56.560 : <WARNING> Model in old format detected '/vehicle/truck/scania_rcab_2009/truck.pmg', please upgrade format to improve load performance! 00:00:56.686 : <WARNING> Model in old format detected '/vehicle/truck/scania_rcab_2009/wipers.pmg', please upgrade format to improve load performance! 00:00:56.785 : <ERROR> [fs] Failed to open file "/vehicle/truck/scania_rcab_2009/color.dif.spec.add.mat" in the read_only mode 00:00:56.785 : <ERROR> [resource_task] Can not open '/vehicle/truck/scania_rcab_2009/color.dif.spec.add.mat' 00:00:56.785 : <ERROR> [fs] Failed to open file "/vehicle/truck/scania_rcab_2009/chrom.dif.spec.add.mat" in the read_only mode 00:00:56.785 : <ERROR> [resource_task] Can not open '/vehicle/truck/scania_rcab_2009/chrom.dif.spec.add.mat' 00:00:56.785 : <ERROR> [fs] Failed to open file "/vehicle/truck/scania_rcab_2009/chrom2.dif.spec.add.mat" in the read_only mode 00:00:56.785 : <ERROR> [resource_task] Can not open '/vehicle/truck/scania_rcab_2009/chrom2.dif.spec.add.mat' 00:00:56.785 : <ERROR> [fs] Failed to open file "/vehicle/truck/scania_rcab_2009/oklejenie.dif.spec.add.mat" in the read_only mode 00:00:56.785 : <ERROR> [resource_task] Can not open '/vehicle/truck/scania_rcab_2009/oklejenie.dif.spec.add.mat' 00:00:57.179 : <WARNING> Model in old format detected '/vehicle/truck/upgrade/doorstep/scania_rcab_2009/doorstep_01.pmg', please upgrade format to improve load performance! 00:00:57.179 : <WARNING> Model in old format detected '/vehicle/truck/upgrade/doorhandle/scania_rcab_2009/doorhandle_01.pmg', please upgrade format to improve load performance! 00:00:57.180 : <WARNING> Model in old format detected '/vehicle/truck/upgrade/mirror/scania_rcab_2009/mirror_02.pmg', please upgrade format to improve load performance! 00:01:03.415 : <ERROR> [model] Unknown variant name 'normal' on model '/vehicle/truck/scania_rcab_2009/interior/model.pmd' 00:01:03.415 : <ERROR> Falling back to first variant and look for interior model. Expect problems. 00:01:03.424 : <WARNING> Model in old format detected '/vehicle/truck/scania_rcab_2009/interior/model.pmg', please upgrade format to improve load performance! 00:01:03.480 : <WARNING> [resource_task] Default temporary buffer is insufficient while reading '/vehicle/trailer_eu/krone/cool_liner/cool_liner.pmg' with size 21318806 00:01:03.506 : <WARNING> Model in old format detected '/vehicle/trailer_eu/krone/cool_liner/cool_liner.pmg', please upgrade format to improve load performance! 00:01:03.612 : <WARNING> Model in old format detected '/vehicle/wheel/saf/wheel.pmg', please upgrade format to improve load performance! 00:01:03.623 : <ERROR> Invalid wheel index (2, 3). Rear wheels must be indexed from rear with indices 0 and 1 on rearmost axle. Model: 00:01:03.623 : <ERROR> Invalid wheel index (4, 5). Rear wheels must be indexed from rear with indices 0 and 1 on rearmost axle. Model: 00:01:03.623 : <WARNING> Model in old format detected '/model/symbol/loading.pmg', please upgrade format to improve load performance! 00:01:03.625 : Create actor: (160 MB) 00:01:03.653 : Game init finished. (264 MB) 00:01:58.779 : quit 00:01:58.781 : Creating save-game file (/home/profiles/446F6D696E696B/save/autosave/game.sii) ... 00:01:58.884 : Game has been auto-saved. 00:02:00.115 : [net] LOG INFO: Stopped 00:02:00.256 : [sys] process shutdown |
