[ETS2] Graphic Mod By Rob Viguurs V3 - Wersja do druku +- eTrucks.pl • Od 17 lat najlepsze forum z modami do ETS1, GTS, ETS2, ATS, ST (http://etrucks.pl) +-- Dział: Euro Truck Simulator 2 (/forum-288.html) +--- Dział: Download (/forum-119.html) +---- Dział: Modyfikacje do ETS 2 (/forum-124.html) +----- Dział: Mody Graficzne (/forum-414.html) +----- Wątek: [ETS2] Graphic Mod By Rob Viguurs V3 (/thread-39777.html) |
Graphic Mod By Rob Viguurs V3 - kacperek - 28/06/2016 10:33 PM Jest to mod graficzny do ETS2
Info: Changelog: Removed HD6 VIGNETTE (Requested), Edited some saturations to make it beter. – Enable/Disable the Reshade with ”0” – This Reshade uses these effects: Levels: Darkens the image, it’s sets a new black and white point. Tonemap: It’s changes the saturation, bleach and exposure. Vibrance: Intelligently saturates. Curves: Adjust contrast. Sepia: Tones the images. Reinhard Tonemapping Shader. Watchdog Tonemap. Gaussuan anamflare: Adds a horizontal light beam to bright pixels (almost no notice but it adds something to the look) Sharpening: Sharps the image (Textures are beter and the details are greater) SMAA (This is a lot more performance saving than the MLAA in ETS 2 so be sure to set Anti Aliasing in ETS 2 OFF!!) – IMPORTANT THINGS! Disable Anti Aliasing in ETS 2 (MLAA vink that off) because this reshade uses SMAA. it saves performance and quality is beter. It is highly recommanded to set resolution scaling to 150% or higher! Because the Sharpining sharpens the pixels a lot, so without SMAA or higher resolution scaling it looks pretty blocky. You can set your brightness ingame to default or you can play a little with it to make it comfort for your screen (Not every monitor displays the same image, it can look different for some people) – !INSTALLATION! Install/put all the files and folders to: C:Program Files (x86)SteamLibrarysteamappscommonEuro Truck Simulator 2binwin_x64 or where your ETS 2 is located. – If you want to ask something about it or … contact me on FB: https://www.facebook.com/ATSoffroadMAP/ – Regards, – Rob Viguurs – Credits: Mod maker: Rob Viguurs Pobieranie Modyfikacji: Goście nie widzą linków. Proszę, zarejestruj się TUTAJ, żeby zobaczyć ukrytą treść . |
