Problem z Minecraft 1.4.7 !!!
dominik_SKIPPER Offline
Bober Kubica
Liczba postów: 1,232
Reputacja: 59
Podziękował: 1320
Podziękowano mu 1138 raz(y)
Exclamation Problem z Minecraft 1.4.7 !!!
Tak jak w temacie Tongue Gdy uruchomiłem Minecrafta i gdy go włączyłem to czekam i czekam aż mi się naładuje a tu nagle coś mi wyskakuje :
Bad video card drivers!
Minecraft was unable to start because it failed to find an accelerated OpenGL mode.
This can usually be fixed by updating the video card drivers.
--- BEGIN ERROR REPORT 7fe0271 --------
Generated 25.06.14 22:01
-- System Details --
Details:
Minecraft Version: 1.4.7
Operating System: Windows 7 (x86) version 6.1
Java Version: 1.7.0, Oracle Corporation
Java VM Version: Java HotSpot™ Client VM (mixed mode), Oracle Corporation
Memory: 462541944 bytes (441 MB) / 518979584 bytes (494 MB) up to 1037959168 bytes (989 MB)
JVM Flags: 2 total; -Xms512m -Xmx1024m
AABB Pool Size: 0 (0 bytes; 0 MB) allocated, 0 (0 bytes; 0 MB) used
Suspicious classes: No suspicious classes found.
IntCache: cache: 0, tcache: 0, allocated: 0, tallocated: 0
LWJGL: 2.4.2
OpenGL: ~~ERROR~~ NullPointerException: null
Is Modded: Probably not. Jar signature remains and client brand is untouched.
Type: Client (map_client.txt)
Texture Pack: Default
Profiler Position: N/A (disabled)
Vec3 Pool Size: ~~ERROR~~ NullPointerException: null[failed to get system properties (java.lang.NullPointerException)]
org.lwjgl.LWJGLException: Pixel format not accelerated
at org.lwjgl.opengl.WindowsPeerInfo.nChoosePixelFormat(Native Method)
at org.lwjgl.opengl.WindowsPeerInfo.choosePixelFormat(WindowsPeerInfo.java:52)
at org.lwjgl.opengl.WindowsDisplay.createWindow(WindowsDisplay.java:185)
at org.lwjgl.opengl.Display.createWindow(Display.java:311)
at org.lwjgl.opengl.Display.create(Display.java:856)
at org.lwjgl.opengl.Display.create(Display.java:784)
at org.lwjgl.opengl.Display.create(Display.java:765)
at net.minecraft.client.Minecraft.a(SourceFile:232)
at asq.a(SourceFile:56)
at net.minecraft.client.Minecraft.run(SourceFile:515)
at java.lang.Thread.run(Unknown Source)
--- END ERROR REPORT 5a78831e ----------
Pomóżcie jak najszybciej błagam -.-
26/06/2014 09:41 AM
Darson Offline
Liczba postów: 1,314
Reputacja: 183
Podziękował: 296
Podziękowano mu 1295 raz(y)
RE: Problem z Minecraft 1.4.7 !!!
Wychodzi na to że coś nie halo z bibliotekami OpenGL: ~~ERROR~~,należało by sprawdzić czy karta graficzna Twoja obsługuje OpenGL jeżeli tak to za instaluj od nowa biblioteki OpenGL.
Znajdziesz tu lub na innych stronach http://opengl.softonic.pl
26/06/2014 10:39 AM
Bober Kubica
Reputacja: 59
Podziękował: 1320
(26/06/2014 10:39 AM)Darson napisał(a):  Wychodzi na to że coś nie halo z bibliotekami OpenGL: ~~ERROR~~,należało by sprawdzić czy karta graficzna Twoja obsługuje OpenGL jeżeli tak to za instaluj od nowa biblioteki OpenGL.
A wiesz ile czasami zajmuje OpenGL ( ten co mi dałeś w linku Tongue )
26/06/2014 12:09 PM
  [Minecraft] Jak dodać ten mod ? dominik_SKIPPER 1 1,683 11/10/2014 07:44 PM
Ostatni post: Kukasz
