Trucksim – Map 5.3.1
Liczba postów: 15,043
Podziękował: 34228
Podziękowano mu 15646 raz(y)
Jest to mapka do ETS2
Cytat:T R U C K S I M – M A P 5.3.1 for Patch 1.15.x
Changes against the previous version:
No new cities! The new cities from the SCS Patch are still not included in the map. We’re working on it.
Changelog from 23.12.2014 :
all reported Bugs are fixed
Map adjusted to Patch 1.15
If you want to play our map you need at least Patch 1.15!! These Mapversion cannot be played with Patchversion 1.14.xx or beforeWykrzyknik
Installation:
Cancel or finish your current delivery and edit your profile.
Deactive the old mods and activate the new ones.
Then delete the old parts from you modfolder.
We have splitted our map in six parts:
TSM_Map_5_defs&mat.scs
TSM_Map_5_map.scs
TSM_Map_5_model_01.scs
TSM_Map_5_model_02
TSM_Map_5_model_03.scs
TSM_Map_5_prefab&more.scs
The six parts are shown in the gamelog.txt as „5.3.1“
These map is not compatible with other maps!
You shouldn’t have any other map in your map directory!
Credits: (and much Thanks! to)
SCS Software for the GroundMap
50keda for the new companies Sellplan und Kaarfor
FLD/TZ for the Prefabs und Models (onyl for using in this map)
kamaz for signs
Reislord for signs
valera_t – for some Map Model
satan19990 for his great Map Models
Waggi74 for the pictures
2X2 for the new car licence plates
mAn_Trucker for companys
diverbaer for the ‚extreme bridge‘
Carinthian for the rebuilt of Frankfurt, Tripolis and Aalborg.
If we have someone forgotten here, please leave us a note. We will mention you in you next version.
We wish all users driving without any crumples and wrinkles!
Your TSM Team
All Trucksim MODS from Trucksim Map Team are offered under Attribution-NonCommercial-NoDerivs 3.0 Unported Licence.
If you require further permissions you must contact us under TruckSim – Map.
It is only allowed to supply this mod via the given downloadlinks!
It is absolutely forbidden to host this mod on any other filehosters.
It is allowed to distribute the bitly.com Bundle in public.
In this way you support our Project TruckSimMap.
NonCommercial — You may not use the material for commercial purposes.
NoDerivatives — If you remix, transform, or build upon the material, you may not distribute themodified material.
No other Download Hoster – It is only allowed to publish this work with the given Downloadlinks provided only by the TSM Team.
For Comments, Additions, Gratulations, Wishes and Suggestions you can always contact us via theforum under TruckSim – Map or sent us a mail to forum@trucksim-map.de.
Find us on facebook under facebook.com/TrucksimMap
Credits:
SCS Software, 50keda, FLD/TZ, kamaz, Reislord, valera_t, satan19990, Waggi74, 2X2, mAn_Trucker, diverbaer, Carinthian
Info:
Autorzy: SCS Software, 50keda, FLD/TZ, kamaz, Reislord, valera_t, satan19990, Waggi74, 2X2, mAn_Trucker, diverbaer, Carinthian
Wersja gry: 1.15.x
24/12/2014 06:37 PM
 Podziękowań: Rene-GAD , barzyga , przemek102705 , .:ScaniaR:. , Kris748159263 , Aras.
weqso Offline
Liczba postów: 4
Podziękował: 3
Podziękowano mu 2 raz(y)
RE: Trucksim – Map 5.3.1
Hej, czy może u kogoś też występuje błąd, że nie widzi nazw miast na mapie ?
06/01/2015 05:35 PM
Rene-GAD Offline
Forumowy GAD
Liczba postów: 2,535
Reputacja: 144
Podziękował: 3201
Podziękowano mu 3447 raz(y)
Jak to??
Nie ma opcji - pokaż screena (F10)
06/01/2015 07:15 PM
weqso Offline
Liczba postów: 4
Podziękował: 3
Może źle się wyraziłem, widać podstawowe miasta + te z rusmap. Wg. twojego poradnika (zestawy map) próbowałem wgrać : EU Map 1.9.1 / 1.10.1 (patch 1.15) LT/LV +TSM + RusMap
Wygląda to tak : Goście nie widzą linków. Zarejestruj się aby zobaczyć ukrytą treść.
06/01/2015 08:23 PM
Rene-GAD Offline
Forumowy GAD
Reputacja: 144
Podziękował: 3201
Kolejność jest taka -> RoMap + LT/LV + TSM 5.3 + RusMap
Plik LT/LV jest zmodyfikowany żeby pasował do TSM Smile
Sorrki za png ale na szybko robiłem
LT/LV + Rusmap
Romap
Reszta (część EU)
06/01/2015 09:49 PM
 Podziękowań: weqso
weqso Offline
Liczba postów: 4
Podziękował: 3
Teraz mi się nie ładuje, gra crashuje przy ekranie ładowania :
07/01/2015 09:14 AM
misiek6228 Offline
Liczba postów: 47
Podziękował: 86
Podziękowano mu 28 raz(y)
rusmap+promod port connection jest zbędny i to on może powodować wywalanie gry,jest on potrzebny do mapy pro mods a nie tsm
Mój Blaszak:
Płyta Główna: MSI X299 SLI Plus
Procesor: Intel Core i7-7820X 4.5GHz
Grafika: AORUS GeForce GTX 1080 Ti Xtreme Edition
Ram: Corsair Vengeance Led 4x8Gb 3000 MHz
Dyski: SSD Plextor M8Pe 1TB + SSD Kingston HyperX 3K 240Gb
karta dźwiękowa: Creative Sound Blaster Recon3D Fatal1ty Professional
Zasilacz: EVGA SuperNOVA G2 R 850W
Chłodzenie CPU: Thermaltake Water 3.0 Riing RGB 360
Obudowa: Thermaltake Core P5
System: Windows 10 Pro x64
Monitor: ASUS ROG PG348Q
07/01/2015 09:30 AM
weqso Offline
Liczba postów: 4
Podziękował: 3
Po usunięciu tego pliku cały czas wywala, pójdę wyłączać mody i zobaczę, ale w tej "złej" kolejności wcześniej gra mi odpalała ;p Tylko że wtedy miałem wrzucone wszystkie pliki z eu map.
// Edit. Za crashe odpowiadała mapa Ro nr. 1 z listy wyżej, ale po wyłączeniu tej mapy nie wiem dlaczego mapzoom przestał działać.
(Ten post był ostatnio modyfikowany: 07/01/2015 10:38 AM przez weqso.)
07/01/2015 10:34 AM
Rene-GAD Offline
Forumowy GAD
Reputacja: 144
Podziękował: 3201
Więc tak:
Kolejność plików map musi być jak w podpisie u mnie.
Poniżej masz linki do nowych wersji map (bo widzę, że RusMap np. masz 1.4.5 a jest już 1.4.7 :E )
Ro - http://etrucks.pl/thread-25588.html (bez fixa dla ProMods)
Rusmap - http://etrucks.pl/thread-24878.html (drugi link)
A reszta jak w poradniku na stronie z postem 109 - kliknij link w moim podpisie.
07/01/2015 10:57 AM
 Podziękowań: weqso
scaniaa12
siemka wszystkim dlaczego u mnie na tej mapie nie ma połączenia w strone grecji i nie mam połączenia w stronkę portugalii .może ktoś jak będzie wiedział jak to naprawić niech mi pomoże
07/01/2015 06:50 PM
  [ETS2] TruckSim-Map (1.34) Zwierzak 130 103,719 22/06/2020 10:32 PM
Ostatni post: TADEO
  TruckSim Map v5.2 - działa z DLC i bez DLC Michal_Z_gno 20 17,186 14/11/2014 11:14 AM
Ostatni post: Rene-GAD
  [ETS2]TruckSim Map 4.7 Śliwka 10 10,848 26/07/2014 12:44 PM
  [ETS2] TruckSim Map v5.0 Michal_Z_gno 29 26,104 16/07/2014 11:57 AM
Ostatni post: bumbumek
  [ETS2] TruckSim Map v 4.7.1 Michal_Z_gno 2 4,722 19/04/2014 05:25 PM
Ostatni post: Doriandu30
