MAD MAX
F U R Y - R O A D
Liczba postów: 4,178
Reputacja: 195
Podziękował: 2204
Podziękowano mu 2840 raz(y)
[ETS2]DAF XF Euro 6 8x4/8
Cytat:Description:
Adapted for transportation of overweight cargoes truck DAF XF Euro 6 8x4/8.
Mod adapted to patch 1.19
The basis is taken from the mod "DAF XF Euro 6 8x4/8 Chasis v 3.0" which was published 9 month ago. Many thanks to the authors.
List of changes:
Added this truck in dialer center.
Added this truck in company.
Added tuning the engine and gearbox ZF Tronic 16S 1920 TD.
Added branded headlights "DAF".
The gear ratio of drive axles, the weight of the truck and the volume of the fuel tank have real value.
As the game transmission ratios and drive axles are registered in a single file, had to do a lot of the same transmission with different gear ratios differential gear.
This means that you can easily carry heavy cargo with a mediocre engine.
In order to avoid confusion, after the name of each transmission, I have two options - FG (first transmission gear ratio) and D (differential gear ratio).
The higher differential ratio (D), the more thrust and less top speed.
The archive contains a supplement addons to the trailers from Jazzycat (Cargo Packs v3.41, Military Cargo Pack v.1.61 and Railway Cargo Pack v1.61 ) which increased the mass of more than 100 cargoes.
The main modes you can download on the website of the author.
Tested on 1.19
Since the description of mod writer made no mention of the ban on the change in this mod, as well as publication of modified versions of this mod, I think that copyright is not violated all the more that the model did not change the chassis. Changes were only specifications.
Credits:
Author model: allabouttrucksim, Henki73, Roadhunter
Parameters gearbox and chassis: Tornado
14/08/2015 06:12 PM |
