[ETS2] Sound Fixes Pack v 17.4 – Anniversary edition
truckerkrzysio38
Kod:
lub:
(Ten post był ostatnio modyfikowany: 17/04/2017 07:25 PM przez Ania.)
14/03/2016 02:18 PM
Ania Offline
Liczba postów: 4,681
Reputacja: 177
Podziękował: 2791
Podziękowano mu 5219 raz(y)
RE: Sound Fixes Pack v14.1
# Mod zaktualizowano w pierwszym poście do najnowszej wersji v14.1
11/04/2016 10:42 AM
Altair Offline
Assassins Master
Liczba postów: 241
Podziękował: 40
Podziękowano mu 98 raz(y)
Dodaje nową wersję tego modu Sound Fixes Pack v 14.2
Pack provides improvements to common sounds in the game, making the sounds feel more immersive and real.
V14.2
Overall reduction of asphalt/tarmac tire noise to reflect modern trucks
Some AI traffic trucks and buses will now run with a Cummins ISX engine sound
Ambient sound volumes fixed and enhanced for RusMap 1.6.3 off-roading areas [ETS2 edition]
Rumble strip sound fixed
New seat belt click sound for after refueling to a full tank or uncoupling the trailer
FEATURES
– Tires: enhanced asphalt tire sounds on normal roads and gravel sounds on dirt roads
– Suspension: enhanced suspension sounds to include sounds of cabin squeaking, key swinging and movement of the cabin.
– “Late music”: replaced with Nokia phone ringtone sound (volume of this sound depends on Music volume in Audio settings in-game).
– “Bing bong” chime for train loading screen sound and ferry loading screen sound.
– Reworked garage door sound and corrected its volume to a lower level.
– Reduced volume of adviser message sound.
– Reduced volume of yawn slightly for fatigue simulation.
– Classic/historic ding sound for while the fuel is pumping (circa 1960s to 1970s). The number of dings give you an idea on how much you refueled.
– Real fuel pump, fuel lid sounds, door close, seat belt click and key insertion sound effect for after refueling to a full tank.
– Mix of stock amplified gear grinding sounds and new gear grinding sounds. Can be heard when you have damaged the transmission and/or gearbox.
– Real stick/switch/button sounds for: parking brake, hazard light, blinker / indicator / turn signal, light switch.
– Retarder sound changed to real retarder sound.
– Lift axle sound now includes button press sound effect in interior.
– Real sound effect for trailer coupling. Also includes the sound of the trailer brakes connecting straight after the fifth wheel coupling.
– Driver Alert Support system sound installed on all trucks (ETS2 exclusive feature).
– AI traffic vehicles given new horn sounds. Depending on the patience of the driver, a short or long honk may be used.
– AI traffic trucks/buses given more variations of sounds (turbo, engines, gear changes, engine brakes).
– Motorcycles from Jazzycat’s AI traffic pack given proper motorcycle engine sounds.
– Motorcycles will rev engine instead of using car horn when blocked.
– You can hear the slight sound of vehicles overtaking you or passing by you in the oncoming lane.
– Wind will sound slightly faster from cabin when you drive at a high speed.
– Pattering of rain on windshield audible inside the truck during heavy rain.
– Louder volume and reworked audio for biplanes, trains (included train horn), helicopters, cable cars and Boeing planes.
COMPATIBILITY
Compatible for and tested on ETS2 version 1.23.1 + ATS version 1.1.1.
Forwards compatible with ATS version 1.2.
No errors in game log.
Fully stable mod.
Compatible with all trucks including mod trucks.
Does not replace individual truck sounds, so can be used with an unlimited amount of truck sound mods of your choice.
Compatible with all maps.
Supports compatibility with Realistic Weather Sound 1.7.5 (provides realistic thunder and exterior rain sounds).
Both mods can be enabled at the same time. Check load order image for more details.
SET TIRE AND WIND VOLUME
Wind and tire noise too loud? No problem. You can configure its volume using these developer commands. Syntax is as follows:
s_air_noise [value from 0.0 to 1.0] (default is 1)
s_wheel_noise [value from 0.0 to 1.0] (default is 1)
INSTALLATION
In most cases, mod requires highest priority in Mod Manager, above map mods, environmental mods and AI traffic mods. Otherwise correct operation of pack not guaranteed.
Check the loading order image for more details.
CREDITS
– SCS Software for base sounds
– Drive Safely for pitch, reverberation and sound edits, some sound samples and compiling mod
– antonvezdehod, Ludmilla and Katixa/Irreo for some tire sounds
– Balamut for some key swing and light suspension sounds
– AlexeyP for some trailer coupling and fuel pump sounds
– Stewen for some improved AI truck sounds
– nIGhT-SoN for raindrop definitions
18/04/2016 06:39 AM
 Podziękowań: MAD MAX
MAD MAX Offline
F U R Y - R O A D
Liczba postów: 4,178
Reputacja: 195
Podziękował: 2204
Podziękowano mu 2840 raz(y)
Wykrzyknik Wykrzyknik
18/04/2016 07:41 AM
Ania Offline
Reputacja: 177
Podziękował: 2791
RE: Sound Fixes Pack v 17.4 – Anniversary edition
# Aktualizacja modu w pierwszym poście.
16/10/2016 11:22 AM
Ania Offline
Reputacja: 177
Podziękował: 2791
#Aktualizacja modu w pierwszym poście.
17/04/2017 07:25 PM
  [ETS2] Sound Fixes Pack v 22.10 MAD MAX 11 5,873 24/03/2022 08:31 PM
Ostatni post: Jakubek
  Sound Fixes Pack v15 MrDomino79 3 1,732 22/06/2016 01:13 PM
Ostatni post: Saszu
  Sound Fixes Pack + Hot Pursuit Sounds v 11.4 abuk 1 1,806 27/12/2015 07:48 PM
Ostatni post: MAD MAX
  Sound Fixes Pack + Hot Pursuit Sounds v 9.0 MAD MAX 1 2,268 06/12/2015 12:54 PM
