Peterbilt 387 New Sound v 2.0
MAD MAX Offline
F U R Y - R O A D
Liczba postów: 4,178
Reputacja: 195
Podziękował: 2204
Podziękowano mu 2840 raz(y)
Jest to Peterbilt 387 do ATS
Cytat:Adaptation of the tractor under the ATS with the following modifications:
– Added a new version of the instrument;
– Replaced the bonnet mirror;
– Dimensions of “Dot”, “Ovalius” and “Dot Line Style” Now create a small lighting around you;
– Neon lights of two colors;
– Indicator retarder;
– The sounds are replaced by default;
– Bortovik Kirilloid22 instead of the old and the alternative bortovik “Peterbilt387_Computer + clock.scs” clock in the archive with the mod;
– Small improvements for 3d models.
For tuning from the ETS elements connect “P387_tuning_from_ETS.scs”.
Upgrading to version 1.2.1.1s.
Changes / Additions:
– Removed the cab suspension
– Fixed mat painting
– New lights
– New gear stick
– Fixed bonnet mirror
– Added blinds in salon
– New slots for accessories in the cabin
– Other minor bug fixes
New changes:
– Replacing all the old sounds new to Peterbilt 387
– Added new sounds, engine and transmission (3406E, Cat15, Cummins, IXS, N14, PACCAR)
– Corrected GPS above to the left did not close the bonnet mirror
– Corrected the bumper (tuning – does not weigh in the air)
Test version: 1.2.h – 1.2.1.1s
Credits:
Authors: – External Model: – Ch_Vitalik – Further development of the external model, external tuning, Textures, Updated bortovik: – Kirilloid22 – Interior, Alteration textures foreign models, tuning, wheels, Animation – Gosh Motor – Author oreginala [Digateley, PPC and sound]: – Kriechbaum – All new residence [Digateley, CAT and Sound] under the Peterbilt 387, repair any errors found: – Vladimir1203
Proszę nie dawanie komentarzy w stylu "Ale fajny ... - Czy działa na wersji xxx - to ściągnij i sprawdź"
Wykrzyknik Wykrzyknik
18/05/2016 11:58 PM
  [ATS] Peterbilt 387 v 2.1 for 1.32-1.34.x Jakubek 0 1,138 24/05/2019 06:42 PM
Ostatni post: Jakubek
  [ATS] Peterbilt 387 v 2.0 [1.28.x] Michal_Z_gno 0 1,900 29/09/2017 02:10 PM
Ostatni post: Michal_Z_gno
  [ATS] Perterbilt 387 for ATS v1.4.xx by H.Trucker MAD MAX 0 1,458 14/10/2016 06:45 AM
Ostatni post: MAD MAX
  Peterbilt 387 for low-end PC Marek_30 2 3,110 15/02/2016 02:58 PM
Użytkownicy przeglądający ten wątek:
