[ATS] Freightliner Argosy Reworked v 2.2.1 for ATS 1.3 by H.TRUCKER
MAD MAX Offline
F U R Y - R O A D
Liczba postów: 4,178
Reputacja: 195
Podziękował: 2204
Podziękowano mu 2840 raz(y)
Jest to Freightliner Argosy do ATS
Cytat:This truck is based on the model Freightliner Argosy v2.1 Reworked of odd_fellow but is adapted to work in version 1.3 of American Truck Simulator
Freightliner Argosy v2.1 Reworked of odd_fellow:
This is an overhaul to my old mod. Now the truck looks more like the real prototype. New interior, new exterior, new upgrade parts, new sounds, all new. The UV template is also new, so sorry about that skinmakers, i tried to retain old uv map, but too many changes were made that made it impossible.
Buy in Peterbilt dealership.
Changelog:
NEW in 2.2.1
– Added added Advanced Trailer Coupling.
You need to activate the option in Options> Gameplay> Advance trailer coupling and click the box.
Tested on version 1.3.1.1s
2.2
-Adapted to American Truck Simulator 1.3.xx (by H.Trucker)
-Fixed truck interior view
-Updated old parameters
2.1 (DONE BY FRANK_WOT)
-Fix to work on ATS v1.2
-Cummins Signature and CAT C16 engines added (own sound)
-Transmissions added with different DIFF ratios
-Company trucks added to use in Quick Job
-New 6×4 and 6×6 chassis added with heavier axles and bigger fuel tanks
2.0
-4 cabin variants
-Cabin physics enabled (may be minor clipping)
-New bumper variants
-New rear lights and mudguard variants
-New visor variants
-New front and side mirrors
-New tanks (fixed proportions)
-Reworked headlights, real life lightmask
-Additional interior tuning
-Sound inside the cabin normalized (lowered exhaust sounds), if you don’t like it you can swap sound .sii files from the previous version
-Reworked raised roof geometry to make it more smooth
-Changed interior light hookup (light still leaks to outside of cabin, but there is nothing i could do)
-New paintjobs, bumper and roof cameras, author – Piva
-UV-map finally fixed, for real this time (i hope so)
-All engines sound update (turbo, gear shift etc)
And probably something else i forgot to mention.
It would be better to sell your old truck before installing this mod, otherwise some bad things will happen.
PLEASE DO NOT UPLOAD TO ANOTHER SERVERWykrzyknik!!
Credits:
Authors: H.Trucker, SCS Software, stas556, dmitry68, odd_fellow, FRANK_WOT, Kriechbaum (sound files)
Proszę nie dawanie komentarzy w stylu "Ale fajny ... - Czy działa na wersji xxx - to ściągnij i sprawdź"
Wykrzyknik Wykrzyknik
14/10/2016 07:05 AM
  [ATS] Freightliner Cascadia ATS 1.37.x Jakubek 1 2,181 30/06/2020 11:14 AM
Ostatni post: Jakubek
  [ATS] Freightliner Coronado + Trailer for ATS 1.4.x MAD MAX 0 1,330 14/10/2016 06:46 AM
Ostatni post: MAD MAX
  Freightliner Coronado for ATS 1.2 MAD MAX 1 1,788 07/04/2016 12:11 PM
  Freightliner Argosy Reworked v2.0 for ATS MAD MAX 0 1,484 19/03/2016 11:05 PM
  Freightliner Argosy v3.0 MAD MAX 1 1,745 17/02/2016 02:46 PM
