MAD MAX
F U R Y - R O A D
Liczba postów: 4,178
Reputacja: 195
Podziękował: 2204
Podziękowano mu 2840 raz(y)
МAZ 5340/5440/6430А8 Reworked [1.26.х]
Jest to МAZ do ETS2
Cytat:Update to version 1.26. (03/12/16)
New in this version:
Improvements and corrections in the model.
Fixed position of the wiper at the sight of the cabin.
Fixed position DUMES accessories on a windshield.
Other minor improvements of the model.
Improvements and fixes residence.
Simplified name of transmissions through improved in patch 1.26
transmission parameters displayed in the list.
Notable shortcomings that still can not fix:
downed normal cab and other details.
manifested at the distance mesh of polygons in some detail (albeit
only slightly).
You may have remained unnoticed by other problems …
Tested on version: 1.26 (should work on 1.25).
Building renovation: il_86
Instal:
Copy to folder \ mods \ and connect to the profile.
IMPORTANT:
For use with DLC “Cabin Accessories” and “National Window Flags”
connect the related files with a registration component.
If you want to play with the MAZ-5340 (canopy), then connect to the
loads and modes with a priority above this fashion.
Greetings to all! I am glad to present you the updated
MAZ-5340/5440 / 6430A8.
Once this mod once touched, I do not know what it was. But after the
test drive, it was decided – although you should try to correct the
registration and remove the redness from the log. Well, then somehow
it went ? worked on it since February, and finally, today, we have
more or less significant result, with the main purpose of work – to
bring fashion to the more or less playable state, saving both original
equipment and the possibility of adequate tuning.
Unfortunately, there are very many deficiencies with the model
side, which has not yet happened eliminated because not have the
necessary skills. But I can say that to throw this thing is not going
to, and gradually, as they gain experience, I plan to continue to
bring it. So if something happens – I ask, as they say, “to understand
and forgive.”
I would also like to thank the [member = Dark_Wolf] for the
excellent voice acting. None of his works MAZ would lose at least half
of the current charisma. I would also like to thank [member =
knox_xss] – his beautiful Renault Magnum served as a good “synopsis”
by the device of the game
The tractor is purchased in a / c DAF, 2 slot.
The model has:
+ 3 types of chassis: 5440A8 (4×2); 6430A8 (6×4); 5340A8 (tent 4×2).
+ 2 types of interior (different steering wheel).
+ His own wheels and sound.
+ Painted in factory colors, including in “metallic.” Can stain
plastic parts of feathers in the cab color.
+ Extensive tuning (optics, shutter, GPS, flashing lights, etc..).
Credits:
il_86, Ols, Drzivago, Shpunt, Volk86, Nik_1MTK, Ra1ley, MiRoN, Fanis,
By_maz_man, MRD_BMZ
Proszę nie dawanie komentarzy w stylu "Ale fajny ... - Czy działa na wersji xxx - to ściągnij i sprawdź"
03/12/2016 08:57 PM |
