[ETS2] Romanian Map v9.25 [1.28.x]
Darson Offline
Liczba postów: 1,314
Reputacja: 183
Podziękował: 296
Podziękowano mu 1295 raz(y)
Jest to mapka Rumunii do ETS2
Kod:
Part I:
Part II:
Part III:
Part IV:
Należy pobrać wszystkie 4 party Wykrzyknik
Info:
Autorzy: Elyxir, Alin2008Todor
Wersja gry: 1.28.x
(Ten post był ostatnio modyfikowany: 12/09/2017 11:28 AM przez Michal_Z_gno.)
24/12/2016 11:14 AM
 Podziękowań: MAD MAX , Adam.J , err1911
Darson Offline
Reputacja: 183
Podziękował: 296
RE: Romanian Map v9.0 (1.26.x)
Map of Romania v9.1 (1.26.x)
Changes in Version 9.1
- new vehicles in traffic (new facilities)
- Trains and new coaches
- tractors with multiple trailers
- we Vehicle traffic
- restored gates animated
- part time special vehicles (with flashing lights and (or) sounds)
- Romanian vehicles are more frequent
- trains stopping places
- corrected errors in map
Changes in version 9.07
- Restores all city limits to improve traffic.
- Marit traffic where it was absent or very little.
- Marit traffic at night.
- Added animated gates to the garage's OHAHA (only trucks are parked in garages, not trailers)
- Adding water traffic.
Note: Make sure that the manager mods. map has higher priority than the way the trailer.
Changes in version 9.05
- new and redesigned vehicles in traffic frequencies.
- Only vehicles parked on roadsides are more frequent at night, except toward entertainment ..
- we animated gates.
- Corrected problem with the color of the Logan MCV.
- Exhaust fumes modified tractors.
- Modified police car drivers and passengers.
- Corrected errors in map
Changes in version 9.02
- new trailer
- corrected errors in the map
Other ways are those of version 9.0 Wykrzyknik!!
Changes in version 9.01
Important: For those who have weaker PC is recommended not to start any more ways than paper because you will have a lag.
If you activate the traffic you will notice a large consumption of resources and a stuttering. A video seen in my portions where we lag heavy traffic and where there is no traffic trouble.
- Map of Romania require activation and the trailer's way.
- The Map of Romania, if you have activated map, it is necessary to create a new profile, and game mode, select romania.mdb
- Modes season should have higher priority as a map.
- Traffic Some vehicles have attached specific engine sounds.
- The total number of drivers is increased to 494
- Name drivers are Romanian.
- There are new designs or edit existing ones.
It added a new feature in the game, changing automatic modes season. Details in Season_changer.zip
If you want a specific season, extract it from the folder Changer.zip Season mode and activate it.
It is increased maneuverability in winter, and now, you do not have snow in tunnels!
And precast intersections, as winter driving are similar to drumusile.
They are remade models, some are new map corrections and crashes are eliminated in beta due to wheel trucks and trailers.
Important Wykrzyknik Thanks to compatibility with dlc, to start a new profile must select the game mode << >> romania.mdb otherwise you will not have the map.
Check if the game mode selected will appear << >> romania.mdb If not, you have to start a new profile.
As new models are present, we recommend PCs with as much memory. For those who have not, reduce the resolution and / or graphic details to avoid memory problems.
Way to use the additional traffic, according to the resolution and graphic details, you must have at least 8 GB RAM installed in the system.
Important Wykrzyknik Because of changes to "bank" to not have problems "reimbursements" is REQUIRED to start a new profile.
Tested on 1.26
Credits: Elyxir , Alin2008Todor
Link wymieniony w pierwszym poście.
05/02/2017 04:18 PM
lukaszek34
Czy ma ktoś może save z tej mapy Map of Romania v9.1 bo u mnie gra się zawiesza jak chcę utworzyć nowy profil
01/09/2017 01:48 PM
Helmuuteq76 Offline
Liczba postów: 135
Reputacja: 6
Podziękował: 269
Podziękowano mu 117 raz(y)
(01/09/2017 01:48 PM)lukaszek34 napisał(a):  Czy ma ktoś może save z tej mapy Map of Romania v9.1 bo u mnie gra się zawiesza jak chcę utworzyć nowy profil
Ona jest na 1.26 a mamy 1.28...
Goście nie widzą linków. Zarejestruj się aby zobaczyć ukrytą treść.Goście nie widzą linków. Zarejestruj się aby zobaczyć ukrytą treść.
02/09/2017 10:19 AM
Liczba postów: 15,095
Reputacja: 640
Podziękował: 34087
Podziękowano mu 15536 raz(y)
RE: Romanian Map v9.25 [1.28.x]
# Aktualizacja mapki w pierwszym poscie.
12/09/2017 11:29 AM
 Podziękowań: err1911
lukaszek34
dał by ktoś save tej mapy jak ktoś jest chętny to na priv nie tutaj bo jest problem z utworzeniem nowego profilu gra się zawiesza słychać muzykę tylko mapę pobrałem sobie już
12/09/2017 01:36 PM
Thumbs Up Romanian Map v8.9 (1.26.x) for ETS 2 DjMrCoolkat 0 2,362 05/12/2016 09:34 PM
Ostatni post: DjMrCoolkat
  ROMANIAN MAP V5.2 + DLC darky 0 2,522 14/02/2014 10:29 AM
Ostatni post: darky
  [ETS2] Romanian Map v 4.7 + DLC Michal_Z_gno 1 2,408 07/01/2014 04:33 PM
Ostatni post: [TPI]xAdikk95
  [ETS2] Romanian Map v4.1 Michal_Z_gno 1 2,754 22/12/2013 07:21 PM
Ostatni post: bub538
  Romanian Map v2.0 for 1.4.x Michal_Z_gno 2 2,920 03/08/2013 10:27 AM
Ostatni post: JONY69
