Wątek zamknięty
Romanian Map v9.0 (1.26.x)
DjMrCoolkat Offline
Liczba postów: 29
Podziękowano mu 25 raz(y)
Changes in v9.0
- dlc France is now required.
- new traffic vehicle (using new features)
- new train and carriadge
- tractors with tandem trailers
- reworked all railroads crossing
- changed static gate in company prefabs with animated ones.
Notw: Wait gate to be fully open, otherwise will take damage Wykrzyknik!
- parked vehicles are more often on night then day.
- make season mods comnpatible with 1.26 version.
Romania map require trailer mod to be activated.
At Romanian map, if tha map it is not activated, you must create a new profile, and, at game mod, select romania.mdb
Sesons mods must have higher priority than map.
Some traffic vehicle have specific sound engine.
Hired driver number is increased to 494
Drivers names are Romanian.
Added new models or edited old ones.
You can have automatic season changer in game. Details in Season_changer.zip file
If you want only a specific season mod, extract it from Season Changer.zip file to mod folder and activate-it !
Increased traction in winter, and , from now, you don't have anymore, snow in tunnels !
Crossroads and prefabs, in winter, behave like roads.
Reworked many models, some new, correction on map, and fixed crashes on beta's due to wheels on trucks and trailers.
Important ! Due to compatibility with dlc to start a new profile must select the game mode<<romania.mdb >> otherwise you will not have the map .
Check if the game mode selected appears <<romania.mdb >> If not, you have to start a new profile.
Since present several new models , it is recommended PC memory as much . For those who have not , reduce the resolution and / or graphic details to avoid memory problems .
To use the additional traffic mode , depending on resolution and graphic details , it is necessary to have at least 8 GB RAM installed in the system.
Tested on game version 1.26.x
Download all 3 parts, extract part 1, the rest will upack itself.
Part 1:
http://sharemods.com/29s9we895zk0/Harta_...1.rar.html
Part 2:
http://sharemods.com/2d0smhca7dw6/Harta_...2.rar.html
Part 3:
http://sharemods.com/bpag1os49a8z/Harta_...3.rar.html
24/12/2016 01:04 PM
MAD MAX Offline
F U R Y - R O A D
Liczba postów: 4,855
Reputacja: 192
Podziękował: 2256
Podziękowano mu 2802 raz(y)
RE: Romanian Map v9.0 (1.26.x)
Modyfikacja już została wcześniej dodana więc daję off i kosz
Wykrzyknik Wykrzyknik
24/12/2016 02:43 PM
Wątek zamknięty
