[ATS] Realistic Roads v 1.7
Ania Offline
Liczba postów: 4,675
Reputacja: 177
Podziękował: 2782
Podziękowano mu 5207 raz(y)
Cytat:This mod replaces textures for the roads around the map of ATS. If you like taking cool pictures and want to take a fresh look at the world of ATS, then this mod is for you! Most of the road textures are new and are made based on the real world pictures.
FYI: the screenshots for this mod have been taken without graphics mods, brightness set on 40% and Color Correction turned off. Alongside with my other mods: Enhanced Vegetation and New Mountain Textures.
New in v1.7:
– Dark gray asphalt (new texture)
– Dark gray asphalt with minor lengthwise cracks (reworked)
– Gray – dark gray asphalt (2 versions, new texture)
– Dusty brown old asphalt (new texture)
– Dusty brown old asphalt with cracks (new texture)
– Light gray asphalt with patched cracks (reworked)
– Two new textures for sidewalks
– Reworked textures for road shoulders
– Some other texture corrections
In previous version:
– New, reworked textures for all roads in the game, with different kinds of asphalt
– Dark gray asphalt (reworked default texture, sharpened and darkened)
– Dark gray asphalt with minor lengthwise cracks (reworked default texture, sharpened and darkened)
– Dark gray asphalt with semi-worn pavement (new texture)
– Gray, worn, good quality pavement (new texture)
– Semi-worn gray asphalt (new texture)
– Light gray, high quality pavement (new texture)
– Light gray pavement with minor lengthwise cracks (new texture)
– Light gray pavement with a lot of patched cracks (new textrure)
– Three kinds of bright tile concrete pavement for highways and bridges (completely reworked default textures)
– Concrete pavement for narrow roads (reworked default texture)
– Dusty roads with minor cracks (reworked default texture)
– Road lines are sharpened and saturated
– Some other minor road texture corrections
Compatible with New Mexico DLC
Works with map mods. Tested on ATS version 1.28 and v1.29
Credits:
slavsan93
21/11/2017 09:21 AM
