Wątek zamknięty
Problem z Dafem
Jaszczur Offline
Liczba postów: 94
Reputacja: 2
Podziękował: 89
Podziękowano mu 108 raz(y)
Problem z Dafem
Taki błąd (dałem urywek, żeby nie kopiować całego).
Cytat:00:03:25.231 : Building routing graph.
00:03:26.876 : Route data generation started.
00:03:26.998 : Route data generation finished.
00:03:27.132 : Economy reset - save version changed, assuming map mismatch
00:03:29.415 : <ERROR> [fs] Failed to open file "/model/flare/vehicle_rearl.pmd" in the read_only mode
00:03:29.415 : <ERROR> [resource_task] Can not open '/model/flare/vehicle_rearl.pmd'
00:03:29.415 : <ERROR> [fs] Failed to open file "/model/flare/vehicle_rearl.pmg" in the read_only mode
00:03:29.415 : <ERROR> [resource_task] Can not open '/model/flare/vehicle_rearl.pmg'
00:03:30.010 : <ERROR> [model] Model descriptor '/model/flare/vehicle_rearl.pmd' is malformed.
00:03:30.010 : <ERROR> [model] Model geometry '/model/flare/vehicle_rearl.pmg' is malformed.
00:03:30.010 : <ERROR> [fs] Failed to open file "/model/flare/vehicle_brakel.pmg" in the read_only mode
00:03:30.010 : <ERROR> [fs] Failed to open file "/model/flare/vehicle_brakel.pmd" in the read_only mode
00:03:30.010 : <ERROR> [resource_task] Can not open '/model/flare/vehicle_brakel.pmd'
00:03:30.010 : <ERROR> [resource_task] Can not open '/model/flare/vehicle_brakel.pmg'
00:03:30.010 : <ERROR> [fs] Failed to open file "/model/flare/vehicle_orangel.pmd" in the read_only mode
00:03:30.010 : <ERROR> [resource_task] Can not open '/model/flare/vehicle_orangel.pmd'
00:03:30.010 : <ERROR> [fs] Failed to open file "/model/flare/vehicle_orangel.pmg" in the read_only mode
00:03:30.010 : <ERROR> [model] Model descriptor '/model/flare/vehicle_brakel.pmd' is malformed.
00:03:30.010 : <ERROR> [resource_task] Can not open '/model/flare/vehicle_orangel.pmg'
00:03:30.010 : <ERROR> [model] Model geometry '/model/flare/vehicle_brakel.pmg' is malformed.
00:03:30.010 : <ERROR> [model] Model descriptor '/model/flare/vehicle_orangel.pmd' is malformed.
00:03:30.010 : <ERROR> [model] Model geometry '/model/flare/vehicle_orangel.pmg' is malformed.
00:03:50.746 : [actor] Initialized at [-6559.3;55.6;29400.2]
00:03:50.853 : Economy reset - company mismatch
00:03:50.878 : <ERROR> [fs] Failed to open file "/model/flare/vehicle_rearl.pmd" in the read_only mode
00:03:50.878 : <ERROR> [resource_task] Can not open '/model/flare/vehicle_rearl.pmd'
00:03:50.878 : <ERROR> [fs] Failed to open file "/model/flare/vehicle_brakel.pmg" in the read_only mode
00:03:50.878 : <ERROR> [resource_task] Can not open '/model/flare/vehicle_brakel.pmg'
00:03:50.878 : <ERROR> [fs] Failed to open file "/model/flare/vehicle_rearl.pmg" in the read_only mode
00:03:50.878 : <ERROR> [resource_task] Can not open '/model/flare/vehicle_rearl.pmg'
00:03:50.878 : <ERROR> [fs] Failed to open file "/model/flare/vehicle_brakel.pmd" in the read_only mode
00:03:50.878 : <ERROR> [resource_task] Can not open '/model/flare/vehicle_brakel.pmd'
00:03:50.880 : <ERROR> [fs] Failed to open file "/model/flare/vehicle_orangel.pmd" in the read_only mode
00:03:50.880 : <ERROR> [resource_task] Can not open '/model/flare/vehicle_orangel.pmd'
00:03:50.881 : <ERROR> [model] Model descriptor '/model/flare/vehicle_rearl.pmd' is malformed.
00:03:50.881 : <ERROR> [model] Model geometry '/model/flare/vehicle_rearl.pmg' is malformed.
00:03:50.881 : <ERROR> [model] Model descriptor '/model/flare/vehicle_brakel.pmd' is malformed.
00:03:50.881 : <ERROR> [fs] Failed to open file "/model/flare/vehicle_orangel.pmg" in the read_only mode
00:03:50.881 : <ERROR> [model] Model geometry '/model/flare/vehicle_brakel.pmg' is malformed.
00:03:50.881 : <ERROR> [resource_task] Can not open '/model/flare/vehicle_orangel.pmg'
00:03:50.881 : <ERROR> [model] Model descriptor '/model/flare/vehicle_orangel.pmd' is malformed.
00:03:50.882 : <ERROR> [model] Model geometry '/model/flare/vehicle_orangel.pmg' is malformed.
00:03:50.932 : [actor] Initialized at [-6559.3;55.6;29400.2]
00:03:51.021 : <ERROR> [fs] Failed to open file "/model/flare/vehicle_rearl.pmd" in the read_only mode
00:03:51.021 : <ERROR> [resource_task] Can not open '/model/flare/vehicle_rearl.pmd'
00:03:51.021 : <ERROR> [fs] Failed to open file "/model/flare/vehicle_brakel.pmd" in the read_only mode
00:03:51.021 : <ERROR> [fs] Failed to open file "/model/flare/vehicle_brakel.pmg" in the read_only mode
00:03:51.021 : <ERROR> [resource_task] Can not open '/model/flare/vehicle_brakel.pmd'
00:03:51.021 : <ERROR> [fs] Failed to open file "/model/flare/vehicle_rearl.pmg" in the read_only mode
00:03:51.021 : <ERROR> [resource_task] Can not open '/model/flare/vehicle_brakel.pmg'
00:03:51.022 : <ERROR> [resource_task] Can not open '/model/flare/vehicle_rearl.pmg'
00:03:51.023 : <ERROR> [fs] Failed to open file "/model/flare/vehicle_orangel.pmd" in the read_only mode
00:03:51.024 : <ERROR> [resource_task] Can not open '/model/flare/vehicle_orangel.pmd'
00:03:51.024 : <ERROR> [model] Model descriptor '/model/flare/vehicle_rearl.pmd' is malformed.
00:03:51.024 : <ERROR> [model] Model geometry '/model/flare/vehicle_rearl.pmg' is malformed.
00:03:51.024 : <ERROR> [fs] Failed to open file "/model/flare/vehicle_orangel.pmg" in the read_only mode
00:03:51.024 : <ERROR> [resource_task] Can not open '/model/flare/vehicle_orangel.pmg'
00:03:51.024 : <ERROR> [model] Model descriptor '/model/flare/vehicle_brakel.pmd' is malformed.
00:03:51.024 : <ERROR> [model] Model geometry '/model/flare/vehicle_brakel.pmg' is malformed.
00:03:51.024 : <ERROR> [model] Model descriptor '/model/flare/vehicle_orangel.pmd' is malformed.
00:03:51.024 : <ERROR> [model] Model geometry '/model/flare/vehicle_orangel.pmg' is malformed.
00:03:51.076 : [actor] Initialized at [-6559.3;55.6;29400.2]
00:03:51.078 : Road network navigation caching started.
00:03:55.719 : Cached navigation loaded
00:03:55.719 : Road network navigation caching finished.
00:04:58.961 : Garage update started.
00:05:01.617 : Garage update finished.
00:05:27.965 : <ERROR> [fs] Failed to open file "/model/flare/vehicle_rearl.pmg" in the read_only mode
00:05:27.965 : <ERROR> [fs] Failed to open file "/model/flare/vehicle_rearl.pmd" in the read_only mode
00:05:27.965 : <ERROR> [fs] Failed to open file "/model/flare/vehicle_brakel.pmd" in the read_only mode
00:05:27.965 : <ERROR> [resource_task] Can not open '/model/flare/vehicle_rearl.pmg'
00:05:27.965 : <ERROR> [resource_task] Can not open '/model/flare/vehicle_rearl.pmd'
00:05:27.965 : <ERROR> [fs] Failed to open file "/model/flare/vehicle_brakel.pmg" in the read_only mode
00:05:27.966 : <ERROR> [resource_task] Can not open '/model/flare/vehicle_brakel.pmd'
00:05:27.966 : <ERROR> [resource_task] Can not open '/model/flare/vehicle_brakel.pmg'
00:05:27.967 : <ERROR> [fs] Failed to open file "/model/flare/vehicle_orangel.pmd" in the read_only mode
00:05:27.968 : <ERROR> [resource_task] Can not open '/model/flare/vehicle_orangel.pmd'
00:05:27.968 : <ERROR> [model] Model descriptor '/model/flare/vehicle_rearl.pmd' is malformed.
00:05:27.968 : <ERROR> [model] Model geometry '/model/flare/vehicle_rearl.pmg' is malformed.
00:05:27.968 : <ERROR> [fs] Failed to open file "/model/flare/vehicle_orangel.pmg" in the read_only mode
00:05:27.968 : <ERROR> [resource_task] Can not open '/model/flare/vehicle_orangel.pmg'
00:05:27.968 : <ERROR> [model] Model descriptor '/model/flare/vehicle_brakel.pmd' is malformed.
00:05:27.968 : <ERROR> [model] Model geometry '/model/flare/vehicle_brakel.pmg' is malformed.
00:05:27.968 : <ERROR> [model] Model descriptor '/model/flare/vehicle_orangel.pmd' is malformed.
00:05:27.968 : <ERROR> [model] Model geometry '/model/flare/vehicle_orangel.pmg' is malformed.
00:05:28.021 : [actor] Initialized at [-6559.3;55.6;29400.2]
00:05:28.044 : <ERROR> [fs] Failed to open file "/model/flare/vehicle_rearl.pmd" in the read_only mode
00:05:28.045 : <ERROR> [ld] Failed to open '/model/flare/vehicle_rearl.pmd'.
00:05:28.045 : <ERROR> model_template.cpp(590): ?cache_data_handler@model_template_u@prism@@UEAAXXZ: Failed to load model descriptor (.pmd) or model geometry (.pmg) for '/model/flare/vehicle_rearl.pmg'.
Niektórym działa, więc nie wiem dlaczego mi nie.
17/05/2018 06:05 PM
nikt123 Offline
Liczba postów: 64
Reputacja: 2
Podziękował: 29
Podziękowano mu 65 raz(y)
RE: Problem z Dafem
1. Wyeksportuj w zmodelerze jeszcze raz
2. Sprawdź czy model posiada swoje koła bo może trzeba wheel pack bo i takie kwiatki czasem są i koniecznie przeczytaj readme jeśli jest dołączone do modelu
3. Odpal samą grę bez modów i tego DAFa i zobacz czy działa
(Ten post był ostatnio modyfikowany: 17/05/2018 06:17 PM przez nikt123.)
17/05/2018 06:08 PM
 Podziękowań: Jaszczur
Jaszczur Offline
Liczba postów: 94
Reputacja: 2
Podziękował: 89
RE: Problem z Dafem
(17/05/2018 06:08 PM)nikt123 napisał(a):  1. Wyeksportuj w zmodelerze jeszcze raz
Opcja ze zmodem odpada, a gre wywala na samym dafie.
17/05/2018 06:17 PM
Kamyk Offline
Liczba postów: 149
Podziękował: 92
RE: Problem z Dafem
brakuje flar.
17/05/2018 06:18 PM
Jaszczur Offline
Liczba postów: 94
Reputacja: 2
Podziękował: 89
RE: Problem z Dafem
(17/05/2018 06:18 PM)Squfixowsky napisał(a):  brakuje flar.
to jakby wina moja czy tej modyfikacji ? bo niektórym działa
17/05/2018 06:20 PM
nikt123 Offline
Liczba postów: 64
Reputacja: 2
Podziękował: 29
RE: Problem z Dafem
Podasz mi link do tego DAFa ? Mógłbym przetestować i coś pokombinować.
17/05/2018 06:20 PM
Jaszczur Offline
Liczba postów: 94
Reputacja: 2
Podziękował: 89
RE: Problem z Dafem
(17/05/2018 06:20 PM)nikt123 napisał(a):  Podasz mi link do tego DAFa ? Mógłbym przetestować i coś pokombinować.
http://etrucks.pl/thread-45084-post-2866...#pid286650
17/05/2018 06:21 PM
nikt123 Offline
Liczba postów: 64
Reputacja: 2
Podziękował: 29
RE: Problem z Dafem
Pobierz https://ets2.lt/en/abasstreppas-flare-pack-v1-3/ mi bez tego wywalało a po nie.
17/05/2018 06:31 PM
Jaszczur Offline
Liczba postów: 94
Reputacja: 2
Podziękował: 89
RE: Problem z Dafem
(17/05/2018 06:31 PM)nikt123 napisał(a):  Pobierz https://ets2.lt/en/abasstreppas-flare-pack-v1-3/ mi bez tego wywalało a po nie.
Dzięki wielkie, działa !
17/05/2018 06:40 PM
Wątek zamknięty
