[ETS2] TT Truck and Driver Physics v 1.3 Hard
Ania Offline
Liczba postów: 4,675
Reputacja: 177
Podziękował: 2791
Podziękowano mu 5219 raz(y)
Cytat:This mod increases the truck’s cab oscillations. In ETS2 the drive is fixed as if it is connected to the seat. The drive head does not move. It is designed to partially simulate the movements of the driver’s body and the driver’s head.
You can adjust the trailer balance as you wish. My mode does not change your existing trailer settings.
The feature that distinguishes this version from the SOFT version is the faster damping of cab oscillations.
In your settings, realistic camera movement must be marked and the coefficient adjustment slider must be set to 50%. You can find the setting that best suits you by changing the ratio.
This mode works in ETS2 1.31 and ETS2 1.32.
All SCS trucks are compatible with Volvo trucks from Eugene and Pendragon.
(SCS will work well with all 3rd party trucks using truck chassis.)
With 900 degree steering wheels you get the best result. If you use a 180 degree steering wheel or mouse, you will see the most appropriate settings in the video below.
Have fun.
Tekteker haydar
Info:
Autor: Tekteker Haydar
Wersja gry: 1.32
31/10/2018 08:00 PM
 Podziękowań: Michal_Z_gno
  Flexible Truck Physics v1.1 Michal_Z_gno 1 2,583 13/01/2023 02:28 PM
Ostatni post: Luki
  TRUCK PHYSICS BY ALEX KAZAK | REL v 0.2.5.3 Altair 0 2,555 06/06/2020 08:56 AM
Ostatni post: Altair
  [ETS2] Truck and Cabin Physics v 1.6 Soft version (for 1.34) Ania 0 1,998 15/02/2019 10:48 AM
Ostatni post: Ania
  [ETS2] Truck and Cabin Physics v 1.6 Hard version (for 1.34) Ania 0 1,590 15/02/2019 08:33 AM
Ostatni post: Ania
  [ETS2] Improved Truck Physics v2.7 Michal_Z_gno 3 5,721 17/10/2018 03:55 PM
Ostatni post: Ania
