Kurdianeł
Tylko Scania!!!
Liczba postów: 1,203
Reputacja: 51
Podziękował: 1814
Podziękowano mu 1932 raz(y)
RE: Sound Fixes Pack v 19.9
Aktualizacja moda! Wersja 19.14
Kod:
Kod:
Moja maszyna:
Procesor: AMD Ryzen 7 2700
Grafika: MSI GeForce RTX 2070 Gaming Z
Płyta: MSI B450M Mortar Titanium
RAM: Adata XPG Gammix D10 DDR4 16GB
Dysk SSD 1: Plextor 256GB M.2 PCIe
Dysk SSD 2: Plextor 512GB M.2 PCIe
Zasilacz: be quiet! System Power 9 CM 600W
Obudowa: Sharkoon DG7000-G RGB
(Ten post był ostatnio modyfikowany: 01/07/2019 07:09 PM przez Kurdianeł.)
01/07/2019 07:08 PM |
Dawid2849
Liczba postów: 382
Reputacja: 15
Podziękował: 250
Podziękowano mu 397 raz(y)
Wersja 19.14:
Cytat:CHANGELOG 19.14
1 new real engine sound for Mercedes Econic truck in AI traffic. [ETS2 edition]
1 new real Cummins Big Cam engine sound added to array for Kenworth W900's in AI traffic. [ATS edition]
Applied real engine and horn sounds for new vehicles added in Jazzycat's Painted Truck Traffic Pack v8.1. [ETS2 edition]
1 new real suspension sound.
Reworked engine sound for Dennis Dagger courtesy of cipinho. [ETS2 edition]
Slight increase in volume for high speed tire sounds.
Description
- Pack provides improvements to common sounds in the game. It includes euphonious, relaxing and real sounds.
- The goal of the mod is to make the game's sounds feel like real life. The mod will have regular updates to cover more sounds to add immersion. Thus the Steam Workshop version is highly recommended for quicker updates.
Compatibility
* ETS2 1.35.1 + ATS 1.35.1. No errors in game log. Must have high priority in Mod Manager.
* Compatible with all maps and all trucks, including truck mods.
* Does not replace individual truck sounds, so this mod can be used with an unlimited amount of truck sound mods of your choice.
* Supports compatibility with your favorite rain sound mods as this does not alter rain/thunder sounds. Check the load order image included for more details.
* If using any of Grimes' seasonal mods, place the seasonal mod with higher priority than the Sound Fixes Pack for a more accurate seasonal experience.
* If using winter mods, please enable Frosty Winter Weather Sound addon with higher priority (in Options folder or Steam Workshop).
* Traffic density/behavior mods (in lower priority in Mod Manager) can enable the realistic sound ranges plugin from Sound Fixes Pack by inserting this line into def/traffic_data.sii: @include "traffic_data_update.sui"
Minimum requirements
Requires higher priority in Mod Manager than:
- any map mods (e.g. ProMods, RusMap, etc.)
- any AI traffic mods (e.g. Jazzycat's traffic packs)
- any AI traffic density/behavior mods (e.g. those listed in section below)
Feature list
## 1. Tire / Tyre sounds
* Real interior + exterior tire sounds. Tires will resonate in the cab depending on how fast you are accelerating and what speed you are in, giving a feel for your sense of speed.
* Heavier gravel sounds on dirt/gravel roads. Tire sounds for grass also included.
## 2. Suspension sounds
* Light and medium impacts to suspension can trigger cabin squeaking and movement sounds of the cabin.
* Hard impacts can trigger key swinging sounds in the interior view.
## 3. Gameplay / UI sounds
* "Late music" replaced with Nokia phone ringtone sound (volume of this sound depends on Music volume in the in-game Audio settings).
* "Bing bong" chime for train and ferry loading screen sounds.
* Reduced volume of garage door sound, adviser message sound and yawning sound.
* New quiet photo camera sound effect for screenshots.
* Improved UI sound effects, including a mdc1200 signal sound for escort messages with the Special Transport DLC.
## 4. Fuel / Gas station sounds
* Retro/historic ding sound for while the fuel is pumping (circa 1960s to 1970s). The number of dings can help give you an idea on how much you refueled.
* Real fuel pump, fuel lid, door close, seat belt click and key insertion sound effects for after refueling to a full tank.
## 5. Interior sounds
* PrePass weigh station signal sounds have a quieter volume in American Truck Simulator.
* Real stick/switch/button sounds for: parking brake, hazard light, wiper stick, light switch and blinker / indicator / turn signal.
* Real rumblestrip sound.
* Real retarder sound. [ATS only]
* Lane-keeping (Driver Alert Support) alert sound if you drive on to the grass too fast (as per EU legal regulations).
* Lift axle sound now includes button press sound effect.
* Improved wind sound.
* Mix of default amplified gear grinding sounds and new gear grinding sounds. Can be heard when you have damaged the transmission and/or gearbox.
* Air cutoff sounds less audible in interior.
## 6. Trailer sounds
* Real sound effects for trailer coupling + uncoupling.
* Included air brake hose deattachment sound when uncoupling.
## 7. AI Traffic sounds
* More refined generic AI traffic car sounds. Less buzz noise and more tire sounds and quiet engine sounds.
* AI traffic vehicles given new horn sounds. Depending on the patience of the driver, a short or long honk may be used.
* Carefully detailed real AI engine/horn sounds for individual vehicles from the base game as well as AI traffic mods.
* You can hear the slight sound of vehicles overtaking you or passing by you in the oncoming lane.
## 8. Mover sounds
* Improved audio for a vast amount of moving objects including biplanes, trains (included train horns) etc.
* Enabled sound for a vast amount of movers that don't originally come with sound (e.g. F22 jet fighters, ocean waves, tugboats, hot air balloons, you name it!).
## 9. Location based ambience
* Appropriate volumes for prefab soundscape in American Truck Simulator.
* Suitable volumes for the sounds of the environment in various map mods.
* Reduced volume for gate sounds in the Animated Gates mod by Schumi (both ETS2 and ATS).
## 10. Air horn sounds
* Improved air horn sounds for American Truck Simulator available at the service station (replacing existing ones).
* Air horn sounds available for ATS are: Used air horn (low price), a sweet and deep air horn, and a train horn. WARNING: Not recommended to use more than two air horns at a time. [ATS only]
## 11. Voice navigation
* Unrealistic phrases removed from English Doug and Skye UK and US voice navigation.
Other changes
The mod also provides real top speeds and real colors for the AI vehicles which are modded with custom sounds.
This is due to the top speed and color settings being shared in the same file as the sound settings for each AI vehicle.
However in the interest in bringing realism, the AI vehicle colors are 100% verifiable using real paint codes, colors from the paintref website, and photos.
Rarer colors (e.g. purple) will have a lower probability to be seen.
Credits
* SCS Software for base sounds
* Drive Safely for sound edits, some sound samples, and for compiling mod
* antonvezdehod, Ludmilla and Katixa/Irreo for some tire sounds
* Balamut for some key swing and light suspension sounds
* AlexeyP for some trailer coupling, gate/barrier and fuel pump sounds, and sounds from Improved Environment Sound
* cipinho for some AI traffic sounds
* kriechbaum for light switch, blinker off, and high beam stick sounds
* Slider_556 for cleaning suspension sound effects
(Ten post był ostatnio modyfikowany: 02/07/2019 01:57 PM przez Dawid2849.)
02/07/2019 01:57 PM |
