ETS2 - Błąd aplikacji : "Wyjątek unknown software exception"
SpedytorEU Offline
Liczba postów: 6
"Wyjątek unknown software exception (0xc0000025) w aplikacji lokalizacja 0x0007FF8EBEB9E08.
************ : log created on : Tuesday November 12 2019 @ 02:49:49
00:00:00.000 : [sys] running on x86_64 / Windows 7 x64 (version 6.1)
00:00:00.000 : [sys] Command line: C:\Program Files (x86)\SCS Software\Euro Truck Simulator 2\Euro Truck Simulator 2\bin\win_x64\eurotrucks2.exe
00:00:00.000 : [cpu] CPU0: GenuineIntel [Intel® Pentium® CPU G4520 @ 3.60GHz] with 2 cores (2 threads) at ~3600MHz.
00:00:00.000 : [sys] plus 1 real-time worker threads.
00:00:00.000 : [sys] using QPC / TSC invariant timer, frequency 3515628Hz
00:00:00.000 : [mem] physical total: 8140M
00:00:00.000 : [mem] physical avail: 5792M
00:00:00.000 : [mem] virtual total: 134217727M
00:00:00.000 : [mem] virtual avail: 134217239M
00:00:00.000 : [mem] Trying to allocate memory pool (819200K)
00:00:00.000 : [mem] Allocated 5 temporary loading buffer(s)
00:00:00.431 : [xinput] Using XInput version 1.4.0
00:00:02.017 : [hashfs] effect.scs: Mounted, 10066 entries
00:00:02.150 : [hashfs] base.scs: Mounted and validated, 79566 entries (8A2CFFFFE91C606526CA865A4596780D47D7FD4698D4450DDA1BC9DEAC1C648E)
00:00:02.182 : [hashfs] core.scs: Mounted and validated, 9 entries (17BDA07D85A5D2560755BB07B5E8AD04349C4FA41922C46C0D72265CE9498E8F)
00:00:02.362 : [hashfs] def.scs: Mounted and validated, 14598 entries (6E2B79F7F551480F0A589E5E4660C9B9055F3C6F22DB31803286504B11BBE93D)
00:00:02.813 : [hashfs] locale.scs: Mounted and validated, 172 entries (2281B6B69E50ADFB0D84665F026519306232708AE145CF8300F77229F7E37625)
00:00:02.852 : [hashfs] base_cfg.scs: Mounted and validated, 1 entries (70294AB66590630BDF24649D9FE2F68A974327D2083722FFA2081F4199B061B5)
00:00:02.852 : [ufs] Home directory: 'C:/Users/PC/Documents/Euro Truck Simulator 2'.
00:00:02.857 : <ERROR> [steamfs_device_t] Cannot initialize directories structure with the file profiles/4164616D/config.cfg
00:00:02.857 : <ERROR> core_game_proc.cpp(4644): ?setup_ufs@core_game_proc_t@prism@@UEAAXXZ: Cannot create steam fs device
(Ten post był ostatnio modyfikowany: 12/11/2019 02:55 AM przez SpedytorEU.)
11/11/2019 08:19 PM
Adam.J Offline
Map Maker na Emeryturze.
Liczba postów: 1,026
Reputacja: 84
Podziękował: 2658
Podziękowano mu 1173 raz(y)
RE: ETS2 - Błąd aplikacji : "Wyjątek unknown software exception"
(11/11/2019 08:19 PM)SpedytorEU napisał(a):  Tak jak w temacie, występuje błąd przy uruchamianiu ETS 2.
"Wyjątek unknown software exception (0xc0000025) w aplikacji w lokalizacji 0x0007FF8EBEB9E08.
Proponuje poczytać a potem prosić o pomoc.
http://etrucks.pl/thread-35737.html
http://etrucks.pl/thread-48455.html
12/11/2019 12:38 AM
  Błąd software exception 0xc0000025 szymeq21453 4 1,856 07/08/2022 08:45 PM
Ostatni post: Matekones
  Bład w Logu Ets2 Janek 2 1,464 22/03/2020 06:27 PM
Ostatni post: Adam.J
