Problem z Krone Megaliner
lukasre Offline
Liczba postów: 8
Witam
Znów wracam z problemem ,mam już kupioną w grze tą naczepę ,lecz gdy chce ją wybrać by np. modernizować lub sprzedać po około 2 sekundach gra wraca do pulpitu ,gdy chce ją kupić jako nową to tego problemu nie ma ,próbowałem pobrać wszystkie naczepy jakie mam od nowa, to dalej nie pomaga Sad
Cytat:00:08:19.261 : Incompatible save loaded. Respawning player truck in safe location...
00:08:19.291 : [actor] Teleported from [7623.5;10.4;-28913.5] to [7624.6;10.6;-28912.9]
00:08:19.326 : [app_lcl] Localization module '/locale/pl_pl/local_module.polreb.sii' has been applied.
00:08:19.327 : [app_lcl] Localization module '/locale/pl_pl/local_module.pm_cargo.sii' has been applied.
00:08:19.340 : [app_lcl] Localization module '/locale/pl_pl/local_module.pm_cities.sii' has been applied.
00:08:19.341 : [app_lcl] Localization module '/locale/pl_pl/local_module.pm_legend.sii' has been applied.
00:08:20.325 : Incompatible save game loaded.
00:09:17.003 : <WARNING> [model] Model geometry '/vehicle/truck/volvo_fh16_2012/truck_ld.pmg' has incorrect file version 506d6714 - expected version 506d6715. Converting...
00:09:17.011 : <WARNING> [model] Model geometry '/vehicle/truck/upgrade/wheel/disc/50k_steel_9inch/front_9inch.pmg' has incorrect file version 506d6714 - expected version 506d6715. Converting...
00:09:17.023 : <WARNING> [model] Model geometry '/vehicle/truck/upgrade/wheel/nuts/50k_front/chrome.pmg' has incorrect file version 506d6714 - expected version 506d6715. Converting...
00:09:17.035 : <WARNING> [model] Model geometry '/vehicle/truck/upgrade/wheel/hub/50k_rear/volvo.pmg' has incorrect file version 506d6714 - expected version 506d6715. Converting...
00:09:17.053 : <WARNING> [model] Model geometry '/vehicle/truck/upgrade/wheel/disc/50k_steel_11inch/rear_11inch.pmg' has incorrect file version 506d6714 - expected version 506d6715. Converting...
00:09:17.054 : <WARNING> [model] Model geometry '/vehicle/truck/upgrade/wheel/nuts/50k_rear/chrome_rear.pmg' has incorrect file version 506d6714 - expected version 506d6715. Converting...
00:09:17.118 : <WARNING> [model] Model geometry '/vehicle/truck/upgrade/wheel/tire/50k_rear/295_60.pmg' has incorrect file version 506d6714 - expected version 506d6715. Converting...
00:09:17.120 : <WARNING> [model] Model geometry '/vehicle/truck/upgrade/wheel/tire/50k_front/295_60.pmg' has incorrect file version 506d6714 - expected version 506d6715. Converting...
00:09:17.152 : <WARNING> [model] Model geometry '/vehicle/truck/upgrade/front_license_plate/platec.pmg' has incorrect file version 506d6713 - expected version 506d6715. Converting...
00:09:17.152 : <WARNING> [model] Model geometry '/vehicle/truck/upgrade/r_bumper/volvo_fh16_2012/stock_4x_led.pmg' has incorrect file version 506d6714 - expected version 506d6715. Converting...
00:09:17.252 : <WARNING> [model] Model geometry '/vehicle/truck/upgrade/s_intake_cab/new_volvo/intake_b2.pmg' has incorrect file version 506d6714 - expected version 506d6715. Converting...
00:09:17.268 : <WARNING> [model] Model geometry '/vehicle/truck/upgrade/frame/volvo_fh16_2012/frame_03.pmg' has incorrect file version 506d6714 - expected version 506d6715. Converting...
00:09:17.285 : <WARNING> [model] Model geometry '/vehicle/truck/upgrade/fl_cover/new_volvo/fl_cover2.pmg' has incorrect file version 506d6714 - expected version 506d6715. Converting...
00:09:17.385 : <WARNING> [model] Model geometry '/vehicle/truck/upgrade/cab_ffender/new_volvo/cab_ffender4.pmg' has incorrect file version 506d6714 - expected version 506d6715. Converting...
00:09:17.385 : <WARNING> [model] Model geometry '/vehicle/truck/upgrade/chs_ffender/new_volvo/chs_ffender4.pmg' has incorrect file version 506d6714 - expected version 506d6715. Converting...
00:09:17.402 : <WARNING> [model] Model geometry '/vehicle/truck/upgrade/r_fender/new_volvo/r_fender2.pmg' has incorrect file version 506d6714 - expected version 506d6715. Converting...
00:09:17.402 : <WARNING> [model] Model geometry '/vehicle/truck/upgrade/spoiler/spoiler_b_ld.pmg' has incorrect file version 506d6714 - expected version 506d6715. Converting...
00:09:22.885 : <WARNING> [model] Model geometry '/vehicle/truck/upgrade/wheel/tire/50k_rear/295_80.pmg' has incorrect file version 506d6714 - expected version 506d6715. Converting...
00:09:22.904 : <WARNING> [model] Model geometry '/vehicle/truck/upgrade/wheel/tire/50k_front/315_80.pmg' has incorrect file version 506d6714 - expected version 506d6715. Converting...
00:09:26.219 : <ERROR> [fs] Failed to open file '/obel/lampa/wsteczna/lampa_a.pmd' in the read_only mode.
00:09:26.219 : <ERROR> [resource_task] Can not open '/obel/lampa/wsteczna/lampa_a.pmd'
00:09:26.235 : <ERROR> [model] Model descriptor '/obel/lampa/wsteczna/lampa_a.pmd' is malformed.
00:09:26.236 : <ERROR> [fs] Failed to open file '/obel/lampa/wsteczna/lampa_a.pmg' in the read_only mode.
00:09:26.236 : <ERROR> [resource_task] Can not open '/obel/lampa/wsteczna/lampa_a.pmg'
00:09:26.252 : <ERROR> [model] Model geometry '/obel/lampa/wsteczna/lampa_a.pmg' is malformed.
00:09:26.252 : <ERROR> [fs] Failed to open file '/obel/lampa/wsteczna/lampa_a.pmd' in the read_only mode.
00:09:26.253 : <ERROR> [ld] Failed to open '/obel/lampa/wsteczna/lampa_a.pmd'.
00:09:26.253 : <ERROR> model_template.cpp(590): ?cache_data_handler@model_template_u@prism@@UEAAXXZ: Failed to load model descriptor (.pmd) or model geometry (.pmg) for '/obel/lampa/wsteczna/lampa_a.pmg'.
Proszę o pomoc
04/01/2020 02:08 PM
  Krone Profiliner SDP27 & Megaliner _Y0ogi_ 0 748 25/02/2024 12:55 PM
Ostatni post: _Y0ogi_
  Krone megaliner Konsonex 3 1,289 19/07/2021 08:04 AM
Ostatni post: Konsonex
  Problem Krone dersal 0 943 17/03/2020 11:46 PM
Ostatni post: dersal
  Problem z dlc.krone mateusz990 13 5,737 08/06/2019 05:53 PM
Ostatni post: mateusz990
