  • 1 głosów - 1 średnio
[ETS2] PW Engines Classic Sounds Pack V.1.4 para ETS2 1.40.XX
Rockeropsiempre Offline
Rockeropasiempre
Liczba postów: 61
Reputacja: 3
Podziękowano mu 102 raz(y)
Mod update
If your engine doesn't ring, just go to the store and choose the engine again.
The problem is solved.
Please do not upload the mod to another server, respect the author's original link.
TIP: If you use this mod, or any other engine or gearbox mod, and decide to disable it or remove it,
before doing so go into the store and assign a game engine and gearbox.
This way you will not have errors in the console in the future.
Description:
- Independent mod.
- It can be combined with Powerful Engines + Gearboxes ETS2 V.14.XX Pack.
- If you combine them, you will get a total of 28 engines and 14 gearboxes.
- This mod consists of 7 normal power motors + 7 very high power motors.
- Lower turbo sound.
- 14 different engines; 440, 460, 500, 540, 600, 640, 700, 760, 1000, 1500, 2000, 2500, 3000 and 3500 Cv.
- 14 Gearboxes.
- The gearboxes incorporate models of 6, 12, 15, 16 and 18 gears.
Some models include several reverse positions and also several retarder positions.
You just have to read the description of the mod, or read in the store before buying.
Different engine sounds: 17
Truck brands with SCS sound take these references:
- Daf XF105 MX-13 engine sound ((Kriechbaum original Audios). Thank you friend for your kindness.
- Daf XF Euro 6, MX-13 engine sound.
- Iveco Hiway, engines with Cursor 9 sound.
- Iveco Stralis, Cursor 13 sounds.
- Man TGX, Euro 6 engine sounds. From the companion "Leen".
- Man TGX Euro 6 with sounds based on the D38.
- Mercedes Actros, OM V6 BlueTec 5 sounds.
- Mercedes New Actros, engines with OM Euro 6 sound.
- Renault Magnum, uses a sound based on the DXi.
- Renault Premium. DXi base engine sounds.
- Renault Range T, sounds DTI Euro 6. From "Kriechbaum".
- Scania R 2009, sounds DC16 Euro 5 EEV V8.
- Scania R and S 2016, with DC16 Euro 6 V8 sounds.
- Scania Streamline, sound based on DC13 Euro 5, very smooth sound, and calm.
- Volvo FH16 Classico, sound based on D16G Euro 5.
- Volvo FH16 2012, sound based on D13 Euro 6.
Changes version 1.4:
- Adapted the engine def files for version 1.40.
- Small adjustments in some def files of RPM of the gearboxes.
- Readjusted engine sounds for Iveco Hiway and Stralis with Fmod.
- Tested on stable version 1.40.
With which trucks can I use this mod? BOXES AND ENGINES ARE ADAPTED FOR ALL ORIGINAL TRUCKS IN THE GAME.
- Daf XF
- Daf XF Euro6
- Iveco Hiway
- Iveco Stralis
- Man TGX
- Man TGX Euro 6
- Mercedes Actros
- Renault Magnum
- Renault Premium
- Renault T
- Scania R
- Scania Streamline
- Scania R 2016
- Scania S 2016
- Volvo FH16
- Volvo FH16 2012.
Thanks: Robinicus and Kriechbaum for technical support with Fmod.
Credits:
Models: Scs.
Sounds: Scs, Kriechbaum and Leen.
Creation and assembly of benches: Rockeropasiempre
Testers: Cupido, Alejandro R35.
Author: Rockeropasiempre
File weight: 27.3 Mb
a greeting
pozdrowienia
Todos somos suaves. Wszyscy jesteśmy miękkie
(Ten post był ostatnio modyfikowany: 02/05/2021 12:54 PM przez Rockeropsiempre.)
26/06/2020 10:52 AM
 Podziękowań: Michal_Z_gno
Bozo Online
Zimol
Liczba postów: 4,132
Reputacja: 82
Podziękował: 4003
Podziękowano mu 6452 raz(y)
RE: PW Engines Classic Sounds Pack V.1.4 para ETS2 1.40.XX
Aktualizacja do wersji 1.4 w post #1.
Punk to brudas, punk to śmieć
03/05/2021 08:54 AM
  [ETS2] Pack Powerful engines + gearboxes V.14.0 for 1.40.XX Rockeropsiempre 4 5,234 03/05/2021 08:53 AM
Ostatni post: Bozo
  [ETS2] Mod para volante de 180-270 Grados. 1.31.XX Rockeropsiempre 0 2,706 18/06/2018 01:50 AM
Ostatni post: Rockeropsiempre
