Wątek zamknięty
Late Autumn/Mild Winter v3.8 (1.39) by Grimes
Marcin D Offline
Menda forumowa :P
Liczba postów: 668
Reputacja: 31
Podziękował: 87
Podziękowano mu 459 raz(y)
This is a graphics and weather mod that simulates a late autumn/mild winter environment and transforms older parts of the map with newer high resolution graphics.
Features
Low resolution roads, fields, grass, terrain, sidewalks, kerbs, hedges, railings, treewalls and other textures replaced with higher resolution versions
Old tree models replaced by new ones across maps
More sky textures
Random grey sky, foggy and sunny weather
Improved rain and wheel spray
No thunder or lightning
Leafless vegetation
HDR Bloom reduced
Late Autumn/Mild Winter daylight hours
Appropriate temperature readings
No harvesters
Compatibility latest version: 1.39
Works with Promods, Rusmap, TSM, MHA and many others.
Compatible with all map DLCs.
Changes in 3.8
Updated for 1.39
Weather improvements
Other fixes and improvements
Recommended settings
HDR: Enabled
Vegetation Detail: High
Grass Density: High
Important!!
Late Autumn/Mild Winter is a weather and graphics mod so other graphics, weather and HDR mods should be disabled to avoid conflicts, issues and crashes.
If you are using Next-Gen only use the base part of that mod.
Late Autumn/Mild Winter should be given a HIGH priority in Mod Manager.
Notatka od Bozo, Wczoraj 05:42 PM:
Dubel tematu = kosz.
(Ten post był ostatnio modyfikowany: 22/11/2020 01:52 PM przez Marcin D.)
22/11/2020 01:50 PM
 Podziękowań: Michal_Z_gno , adamets2
Wątek zamknięty
