Nie mogę włączyć gry
niQuitiNN Offline
Liczba postów: 3
Witam zakupiłem dziś grę i niestety nie chce się włączyć przez DX11
(Wyskakuje taki błąd https://imgur.com/a/PRupM7m )
Gra normalnie odpala na OpenGL ale nie wiem czy ktoś chciałby grać na takiej grafice ;/
Spec pcta - https://imgur.com/a/lABqqra
Gra również nie odpala się w safe modzie
logi
************ : log created on : Saturday December 12 2020 @ 22:39:50
00:00:00.000 : [sys] running on x86_64 / Windows 10 x64 (version 10.0)
00:00:00.000 : [sys] Command line: C:\Users\Martin\Desktop\steam\steamapps\common\Euro Truck Simulator 2\bin\win_x64\eurotrucks2.exe
00:00:00.000 : [cpu] CPU0: GenuineIntel [Intel® Core™ i7-4790 CPU @ 3.60GHz] with 4 cores (8 threads) at ~3600MHz.
00:00:00.000 : [sys] using 3 worker thread(s)
00:00:00.000 : [sys] plus 3 real-time worker threads.
00:00:00.000 : [sys] using QPC / TSC invariant timer, frequency 3515639Hz
00:00:00.024 : [mem] physical total: 8134M
00:00:00.024 : [mem] physical avail: 4721M
00:00:00.024 : [mem] virtual total: 134217727M
00:00:00.024 : [mem] virtual avail: 134217143M
00:00:00.024 : [mem] Trying to allocate memory pool (819200K)
00:00:00.024 : [mem] Allocated 5 temporary loading buffer(s)
00:00:00.037 : [xinput] Using XInput version 1.4.0
00:00:00.058 : [hashfs] effect.scs: Created and validated, 13977 entries (F4F8F9B662203DE90D34D52B522F538212E61A2472ADA7655C1E39957298E99A)
00:00:00.058 : [fs] device effect.scs mounted.
00:00:00.135 : [hashfs] base.scs: Created and validated, 105119 entries (BCE6F25AB83485B2B4571B8875DBF29B0F8C9DAA96CC03843DA37A53545A4DB1)
00:00:00.135 : [fs] device base.scs mounted.
00:00:00.136 : [hashfs] core.scs: Created and validated, 9 entries (B657A3A1EC68921290FF73429D79120DA821DFB8BFFEC608D47B736D4D8F5D54)
00:00:00.136 : [fs] device core.scs mounted.
00:00:00.362 : [hashfs] def.scs: Created and validated, 19008 entries (E6820B1EA1D623DCD03C6DD66F1A8DE84B848C0B84EB6CD6A07B11FA9AF1491F)
00:00:00.362 : [fs] device def.scs mounted.
00:00:00.512 : [hashfs] locale.scs: Created and validated, 214 entries (BC4BAFD5CA1B97356A6332F021575780E6859CB4D3528EA06FBAF0295F97A00B)
00:00:00.512 : [fs] device locale.scs mounted.
00:00:00.513 : [hashfs] base_cfg.scs: Created and validated, 1 entries (4B95E7E20BEECF7507064BAEC99DB20CA6584B2DA1E60381E7CE0C5EC41BFB22)
00:00:00.513 : [fs] device base_cfg.scs mounted.
00:00:00.513 : [ufs] Home directory: 'C:/Users/Martin/Documents/Euro Truck Simulator 2'.
00:00:00.513 : [fs] device C:/Users/Martin/Documents/Euro Truck Simulator 2 mounted.
00:00:00.514 : [hashfs] dlc_rocket_league.scs: Created and validated, 142 entries (CD31D4159A9C60AE8E22CA624C1E5FC3257630E9687D7B0DF1390F4CF38C2CCA)
00:00:00.515 : [mod_package_manager] Requesting Steam Workshop content..
00:00:00.515 : exec /home/config.cfg
00:00:00.515 : [sys] Executing /home/config.cfg ...
00:00:00.515 : uset s_init_intro_music_mute "0"
00:00:00.515 : uset s_init_intro_music_volume "0.5"
00:00:00.515 : uset s_init_ui_music_mute "0"
00:00:00.515 : uset s_init_ui_music_volume "0.5"
00:00:00.515 : uset s_init_master_mute "0"
00:00:00.515 : uset s_init_master_volume "0.75"
00:00:00.515 : uset s_output_driver ""
00:00:00.515 : uset s_live_update "0"
00:00:00.515 : uset s_suspend_sound "1"
00:00:00.515 : uset r_hide_helpers "0"
00:00:00.515 : uset r_full_resolution_corrections "0"
00:00:00.515 : uset g_mm_help_shown "0"
00:00:00.515 : uset g_frame_image_fmt "jpg"
00:00:00.515 : uset g_frames_path ""
00:00:00.515 : uset g_map_note_user_id "0"
00:00:00.515 : uset g_color_feedback "1"
00:00:00.515 : uset g_disable_hud_activation "0"
00:00:00.515 : uset r_wireframe "0"
00:00:00.516 : uset g_interior_camera_zero_pitch "0"
00:00:00.516 : uset r_multimon_exterior_in_aux "0"
00:00:00.516 : uset r_multimon_interior_in_main "1"
00:00:00.516 : uset r_multimon_rotation_aux "0"
00:00:00.516 : uset r_multimon_rotation_right "0"
00:00:00.516 : uset r_multimon_rotation_left "0"
00:00:00.516 : uset r_multimon_rotation_center "0"
00:00:00.516 : uset r_multimon_vert_offset_right "0"
00:00:00.516 : uset r_multimon_vert_offset_left "0"
00:00:00.516 : uset r_multimon_border_fov_right "0"
00:00:00.516 : uset r_multimon_border_fov_left "0"
00:00:00.516 : uset r_multimon_fov_vertical "0"
00:00:00.516 : uset r_multimon_fov_horizontal "50"
00:00:00.516 : uset r_multimon_mode "0"
00:00:00.516 : uset r_use_depth_bounds "1"
00:00:00.516 : uset r_show_light_pixel_coverage "0"
00:00:00.516 : uset r_buffer_page_size "10"
00:00:00.516 : uset r_deferred_debug "0"
00:00:00.516 : uset r_mirror_scale_y "1"
00:00:00.516 : uset r_mirror_scale_x "1"
00:00:00.516 : uset r_scale_y "0.75"
00:00:00.516 : uset r_scale_x "0.75"
00:00:00.516 : uset r_normal_maps "0"
00:00:00.516 : uset r_sunshafts "0"
00:00:00.516 : uset r_color_saturation "1.0"
00:00:00.516 : uset r_color_yellow_blue "0.0"
00:00:00.516 : uset r_color_magenta_green "0.0"
00:00:00.516 : uset r_color_cyan_red "0.0"
00:00:00.516 : uset r_color_correction "0"
00:00:00.516 : uset r_cloud_shadows "1"
00:00:00.516 : uset r_dof_filter_size "0.5"
00:00:00.516 : uset r_dof_transition "400.0"
00:00:00.516 : uset r_dof_start "200.0"
00:00:00.516 : uset r_dof "0"
00:00:00.516 : uset r_ssao "0"
00:00:00.516 : uset r_smaa "0"
00:00:00.516 : uset r_hdr "0"
00:00:00.516 : uset r_fake_shadows "1"
00:00:00.516 : uset r_sun_shadow_texture_size "2048"
00:00:00.516 : uset r_sun_shadow_quality "0"
00:00:00.516 : uset r_mirror_group "3"
00:00:00.516 : uset r_mirror_view_distance "80"
00:00:00.516 : uset r_deferred_mirrors "0"
00:00:00.516 : uset r_deferred "1"
00:00:00.516 : uset r_nowmi "1"
00:00:00.516 : uset r_startup_progress "1"
00:00:00.516 : uset r_setup_done "1"
00:00:00.516 : uset r_gamma "1.0"
00:00:00.516 : uset r_manual_stereo_buffer_scale "1.0"
00:00:00.516 : uset r_manual_stereo_ui_fov_game "100"
00:00:00.517 : uset r_manual_stereo_ui_fov "80"
00:00:00.517 : uset r_manual_stereo_ui_dist_game "0.5"
00:00:00.517 : uset r_manual_stereo_ui_dist "0.8"
00:00:00.517 : uset r_manual_stereo_in_menu "1"
00:00:00.517 : uset r_minimal_unfinished_frames "0"
00:00:00.517 : uset r_no_frame_tracking "0"
00:00:00.517 : uset r_fullscreen "1"
00:00:00.517 : uset r_mode_refresh "0"
00:00:00.517 : uset r_mode_height "1050"
00:00:00.517 : uset r_mode_width "1680"
00:00:00.517 : uset r_path ""
00:00:00.517 : uset r_device "dx11"
00:00:00.517 : uset i_virtual_cursor_speed "500.0"
00:00:00.517 : uset g_tobii "1"
00:00:00.517 : uset g_trackir "1"
00:00:00.517 : uset g_lod_factor_pedestrian "1"
00:00:00.517 : uset g_pedestrian "0"
00:00:00.517 : uset g_light_span_factor "0"
00:00:00.517 : uset g_light_distance_factor "0"
00:00:00.517 : uset g_vehicle_flare_lights "0"
00:00:00.517 : uset g_auto_traffic_headlights "0"
00:00:00.517 : uset g_lod_factor_parked "1"
00:00:00.517 : uset g_lod_factor_traffic "1"
00:00:00.517 : uset g_traffic "1.0"
00:00:00.517 : uset g_kdop_preview "0"
00:00:00.517 : uset g_screenshot_on_bug_quality "100"
00:00:00.517 : uset g_screenshot_on_bug "0"
00:00:00.517 : uset g_shoulder_block_coloring "0"
00:00:00.517 : uset g_debug_map_limits "0"
00:00:00.517 : uset g_city_name_move "0"
00:00:00.517 : uset g_developer "0"
00:00:00.517 : uset g_semantical_pause_inactivity "120"
00:00:00.517 : uset g_pause_on_disconnect "1"
00:00:00.517 : uset g_semantical_ff_inactivity "300"
00:00:00.517 : uset g_steam_rich_presence "1"
00:00:00.517 : uset g_steam_browser "1"
00:00:00.517 : uset g_steam_screenshots "2"
00:00:00.517 : uset g_artist_id "0"
00:00:00.517 : uset g_save_format "0"
00:00:00.517 : uset g_trailer_cables_mode "2"
00:00:00.517 : uset g_spec_trans_refill_tank "1"
00:00:00.517 : uset g_flyspeed "100.0"
00:00:00.517 : uset g_online_loading_screens "-1"
00:00:00.517 : uset g_news "-1"
00:00:00.517 : uset g_colbox "0"
00:00:00.517 : uset g_radio_mode "1"
00:00:00.517 : uset g_ignore_low_fps "0"
00:00:00.517 : uset g_truck_light_quality "1"
00:00:00.517 : uset g_truck_light_specular "1"
00:00:00.517 : uset g_gfx_all_scales "0"
00:00:00.517 : uset g_gfx_advanced "0"
00:00:00.517 : uset g_gfx_quality "-1"
00:00:00.518 : uset g_hq_3d_scale "0.0"
00:00:00.518 : uset g_hq_3d_screenshot "0"
00:00:00.518 : uset g_menu_aa_limit "8"
00:00:00.518 : uset g_additional_water_fov "20.0f"
00:00:00.518 : uset g_rain_reflect_hookups "0"
00:00:00.518 : uset g_rain_reflect_actor "0"
00:00:00.518 : uset g_rain_reflect_traffic "0"
00:00:00.518 : uset g_rain_reflect_cache "0"
00:00:00.518 : uset g_rain_reflection "0"
00:00:00.518 : uset g_reflection "0"
00:00:00.518 : uset g_grass_density "0"
00:00:00.518 : uset g_veg_detail "0"
00:00:00.518 : uset g_save_indicator "1"
00:00:00.518 : uset g_game_version "0"
00:00:00.518 : uset g_force_online_lscrs "0"
00:00:00.518 : uset g_hw_info "1"
00:00:00.518 : uset g_glass_debugging_level "0"
00:00:00.518 : uset g_line_sort "0"
00:00:00.518 : uset g_cargo_sort "0"
00:00:00.518 : uset g_bloom_standard_deviation "0.5"
00:00:00.518 : uset g_bloom_filter_radius "6"
00:00:00.518 : uset g_bloom_resizing_steps "3"
00:00:00.518 : uset g_bloom_override "0"
00:00:00.518 : uset g_bloom "1.0"
00:00:00.518 : uset g_global_force_load_selector "0"
00:00:00.518 : uset g_desktop_fadeout "60"
00:00:00.518 : uset g_minicon "0"
00:00:00.518 : uset g_console "0"
00:00:00.518 : uset g_texture_usage_stats "0"
00:00:00.518 : uset g_fps "0"
00:00:00.518 : uset ui_tooltip_delay "0.4"
00:00:00.518 : uset g_stream_exts ".ogg;.mp3"
00:00:00.518 : uset r_output "-1"
00:00:00.518 : uset r_adapter "-1"
00:00:00.518 : uset r_vsync "1"
00:00:00.518 : uset r_color_mode "0"
00:00:00.518 : uset r_anisotropy_factor "0"
00:00:00.518 : uset r_texture_detail "2"
00:00:00.518 : uset cf_asus_aura "1"
00:00:00.518 : uset cf_razer_chroma "1"
00:00:00.518 : uset v_bug_break "0"
00:00:00.518 : uset t_locked_fps "0"
00:00:00.518 : uset t_averaging_window_length "20"
00:00:00.523 : <WARNING> It looks like the game did crash during last startup, triggering safe mode
00:00:00.529 : [lang] Language autodetection: 415
00:00:00.539 : Selected language: pl_pl
00:00:00.539 : Euro Truck Simulator 2 init ver.1.39.1.5s (rev. c3e92e6b39de)
00:00:00.545 : [gfx] Selected rendering device: dx11
00:00:00.545 : [gfx] NVAPI not detected. (-2)
00:00:00.699 : [gfx] AGS initialized
00:00:00.699 : [ags] GPU: 0 (AMD Radeon ™ R9 380 Series)
00:00:00.699 : [ags] AMD EyeFinity disabled
00:00:00.716 : [net] LOG INFO: Started
00:00:00.718 : [fs] device mounted.
00:00:00.719 : Setting UI reference mode to: 1440x900...
00:00:00.720 : [dxgi] Detected following adapters:
00:00:00.721 : [dxgi] 0 - AMD Radeon ™ R9 380 Series (27.20.14501.28009) [4067 MB]
00:00:00.722 : [gfx] Using the DXGI display backend
00:00:00.757 : [dxgi] Using adapter: AMD Radeon ™ R9 380 Series (27.20.14501.28009) [4067 MB]
00:00:00.763 : [dx11] Using SM5X rendering path
00:00:00.770 : <ERROR> [dxgi] Failed to match output mode! (0x887a0001)
00:00:00.770 : <ERROR> [gfx] failed to initialize device! (dx11)
00:00:00.785 : [sound] Available drivers: #2
00:00:00.786 : [sound] Driver 0 = Głośniki (Realtek High Definition Audio) (48000 Hz) ({0e6f25e9-d568-4a25-b4d9-ece49190c7e7})
00:00:00.786 : [sound] Driver 1 = Realtek Digital Output (Realtek High Definition Audio) (48000 Hz) ({24f46b3a-ea1d-42a9-abb0-044b2584e190})
00:00:00.952 : [sound] Selecting default audio driver (0).
00:00:04.494 : [sound] Sound library - shutdown.
00:00:04.494 : [sound] Sound system - shutdown.
00:00:04.812 : [sound] FMOD libraries released.
00:00:04.816 : [net] LOG INFO: Stopped
00:00:04.820 : [hashfs] dlc_rocket_league.scs: Unmounted.
00:00:04.820 : [hashfs] base_cfg.scs: Unmounted.
00:00:04.820 : [hashfs] locale.scs: Unmounted.
00:00:04.820 : [hashfs] def.scs: Unmounted.
00:00:04.821 : [hashfs] core.scs: Unmounted.
00:00:04.821 : [hashfs] base.scs: Unmounted.
00:00:04.821 : [hashfs] effect.scs: Unmounted.
00:00:04.974 : [sys] Process manager shutdown.
(Ten post był ostatnio modyfikowany: 12/12/2020 10:55 PM przez niQuitiNN.)
12/12/2020 10:46 PM
niQuitiNN Offline
Liczba postów: 3
RE: Nie mogę włączyć gry
ps. zrobiłem wszystko co na 1 screenie
również dodam że tekstury są kolorowe np zielona jezdnia, zielone budynki itp.
(Ten post był ostatnio modyfikowany: 13/12/2020 12:15 AM przez niQuitiNN.)
12/12/2020 10:53 PM
niQuitiNN Offline
Liczba postów: 3
wersja gry 1.35 działa bez problemu
13/12/2020 12:16 AM
Question Jak włączyć Map Editora na 1.43? jasiorek_smigorek 1 623 27/12/2021 09:47 PM
Ostatni post: Bytnarek
  nie wczytuje gry danielex 8 1,949 29/09/2019 08:35 PM
Ostatni post: danielex
  Nie mogę wgrać Poland Rebuiding 2.1 hazeR 15 4,239 06/06/2018 09:47 PM
Ostatni post: hazeR
