Error w game log Ets2
Marhen Offline
Liczba postów: 4
Witam.
Miałem spore problemy z zacinaniem sie gry. Doczytałem, że powodem są brakujące mody które były w tunninu a nie zostały sprzedane a mod usuniety. Gra ich wciąz szukała. Załozyłem nowy profil. Wgrałem mapy te co miałem czyli z forum roextender Normal Map Combo - Promods based[1.40] V3. Wszystko smiga, czasem sie przytnie ale nie juz tak jak było. Ale zajrzałem w game log a tam mam Error wciaz powtarzający się:
00:01:36.056 : <ERROR> load_unit_tree() - Failed to load unit tree from file (/def/sign/template/gas_nl_big.sii)
00:01:36.057 : <ERROR> [unit] File '<../../def.scs | >/def/sign/template/gas_nl_big.sii':
00:01:36.057 : <ERROR> [unit] The unit '_nameless.205.bd24.52f0' of type 'sign_template_board_binding' has dangling pointer (to 'sign_board.107') in the attribute named 'linked_board'.
00:01:36.057 : <ERROR> [unit] The unit '_nameless.205.bd24.5470' of type 'sign_template_board_binding' has dangling pointer (to 'sign_board.108') in the attribute named 'linked_board'.
00:01:36.057 : <ERROR> [unit] The unit '_nameless.205.bd24.56b0' of type 'sign_template_board_binding' has dangling pointer (to 'sign_board.107') in the attribute named 'linked_board'.
00:01:36.057 : <ERROR> [unit] The unit '_nameless.205.bd24.4d50' of type 'sign_template_board_binding' has dangling pointer (to 'sign_board.108') in the attribute named 'linked_board'.
00:01:36.057 : <ERROR> [unit] The unit '_nameless.205.bd24.58c0' of type 'sign_template_board_binding' has dangling pointer (to 'sign_board.147') in the attribute named 'linked_board'.
00:01:36.057 : <ERROR> [unit] The unit '_nameless.205.bd24.54d0' of type 'sign_template_board_binding' has dangling pointer (to 'sign_board.147') in the attribute named 'linked_board'.
00:01:36.058 : <WARNING> [unit] The pointer to 'sign_board.107' looks like dangling pointer.
00:01:36.058 : <ERROR> [unit] File '<../../def.scs | >/def/sign/template/gas_nl_big.sii':
00:01:36.058 : <WARNING> [unit] The pointer to 'sign_board.108' looks like dangling pointer.
00:01:36.058 : <WARNING> [unit] The pointer to 'sign_board.147' looks like dangling pointer.
00:01:36.058 : <ERROR> load_unit_tree() - Failed to load unit tree from file (/def/sign/template/gas_nl_big.sii)
********** The log file exceeded its limit size, truncated.
Nie moge zlinkowac game loga jak w FAQ bo jest limit.
Dodam ze na tym profilu mam poziom 4 i nie posiadam wlasnego auta, naczepy, jedynie garaż.
Może ktos mi powiedzieć o co tutaj chodzi?
07/05/2021 03:44 PM
superpiotr4 Offline
Liczba postów: 414
Reputacja: 19
Podziękował: 303
Podziękowano mu 422 raz(y)
RE: Error w game log Ets2
Jak nie możesz zlinkować to użyj chociaż code. Przykład:
Kod:
Kod:
Goście nie widzą linków. Proszę, zarejestruj się TUTAJ, żeby zobaczyć ukrytą treść . [/code] - tak zamykasz kod jak przekopiujesz.
Ale wracając do tematu, widzę, że może być problem jeszcze z innym modem i stawiam, że jest to jakiś mod na tuning ciężarówki. Podejrzewam, że to może generować jakieś błędy w logu, może modyfikacja jest nieaktualna. Jednak widzę masz sporo modów, dlatego mam dla ciebie poradę:
1 . Załóż nowy profil bez modów, załaduj grę i przejdź samouczek.
2. Wyjdź z ets2 i sprawdź czy nie masz tych błędów w logu. Jeżeli ich nie masz, przejdź do kroku 3, a jak masz to przeprowadź operację sprawdzenia spójności plików na Steam. Może czegoś brakuje. Aby to zrobić, wchodzisz na Steam i: PPM na grę
------> Wybierasz zakładkę Pliki ------> Wybierasz opcję "Sprawdź spójność plików"
Jak wszystko zadziała możesz olać 3 punkt, a jak nie spróbuj reinstalacji gry, robiąc sobie kopię profilu.
3. Wchodzisz do ETS2 i po kolej leć z modami, za każdym razem włączaj jeden mod, pograj chwilę, sprawdź game.log i potem włącz kolejny mod. Rób tak dopóki jakieś błędy się nie pojawią. Jak się pojawią tę błędy o których mówisz to są dwa rozwiązania, albo wywal tą modyfikację, albo zaktualizuj do nowszej wersji, o ile to możliwe.
Pozdrawiam:
superpiotr4
Daj znać, czy działa.
Dzień 24 lutego 2022 r na zawsze wpisze się w kartę XXI wieku. Rosjanie zaatakowali o wiele mniejsze państwo, tylko dlatego, że chcieli należeć do dzisiejszej Europy! Podczas, gdy my klepiemy się po pełnych brzuchach, Ukraińcy wiążą koniec z końcem. Nie maja dostępu do bieżącej wody, prądu, a nawet żywności. Nie pozwólmy na to, aby biedny naród musiał cierpieć, przez ambicje PutinaWykrzyknik
Ty też możesz pomagać. Wystarczy, że za symboliczne 3,59 złotych zakupisz DLC Ukrainian Paint Jobs Dochody w 100% zostaną przekazane fundacji People in Need zaangażowanej na rzecz Wschodu! Nie czekaj! Pomóż im już dzisiaj!
Pomożesz, bo możesz. Masz to w genach Smile
08/05/2021 12:09 PM
Marhen Offline
Liczba postów: 4
Bez modów nie ma błędów, modów mam 100 łacznie z mapami. Troche roboty a walcze z tym juz 2 tygodnie. Wcoąśz jakies dodaje i odejmuje dlatego myslalem ze da sie rozpoznac po game logu. Sporo modów wywaliłem. Spójnośc juz sprawdzałem z 2 razy mam okej.
Jak widac wciaz ten sam error sie powtarza i wtedy wlasnie chyba przycina mi gre
08/05/2021 01:00 PM
Marhen Offline
Liczba postów: 4
Goście nie widzą linków. Zarejestruj się aby zobaczyć ukrytą treść.************ : log created on : Saturday May 08 2021 @ 13:31:26
00:00:00.000 : [sys] running on x86_64 / Windows 10 x64 (version 10.0)
00:00:00.000 : [sys] Command line: F:\GRY\steamapps\common\Euro Truck Simulator 2\bin\win_x64\eurotrucks2.exe
00:00:00.000 : [cpu] CPU0: GenuineIntel [Intel® Core™ i7-8700 CPU @ 3.20GHz] with 6 cores (12 threads) at ~3192MHz.
00:00:00.000 : [sys] using 4 worker thread(s)
00:00:00.000 : [sys] plus 3 real-time worker threads.
00:00:00.000 : [sys] using QPC / HPET timer, frequency 10000000Hz
00:00:00.005 : [mem] physical total: 16333M
00:00:00.005 : [mem] physical avail: 11799M
00:00:00.005 : [mem] virtual total: 134217727M
00:00:00.005 : [mem] virtual avail: 134213026M
00:00:00.005 : [mem] Trying to allocate memory pool (2097152K)
00:00:00.006 : [mem] Allocated 5 temporary loading buffer(s)
00:00:00.071 : [xinput] Using XInput version 1.4.0
00:00:00.097 : [hashfs] effect.scs: Created and validated, 14066 entries (488B2DF33AFB4FDCB029121C4C41494D16A5D9C04FE423E79F065CA4F8893C59)
00:00:00.097 : [fs] device effect.scs mounted.
00:00:00.198 : [hashfs] base.scs: Created and validated, 116157 entries (08EBF31A4FC251ADA7BDCA44DAA0E6D8187DCCFAD5C67629CAD4B3059E221A17)
00:00:00.198 : [fs] device base.scs mounted.
00:00:00.204 : [hashfs] core.scs: Created and validated, 9 entries (AEFC57B51DD96D1E711234B4C68A064C9ECD964EAEC23142A4EDF59B342BC180)
00:00:00.204 : [fs] device core.scs mounted.
00:00:00.622 : [hashfs] def.scs: Created and validated, 22872 entries (8982724DF98D624CE78425550559FDDE9DBDF158DB0ED30EB4B45BF01E342386)
00:00:00.622 : [fs] device def.scs mounted.
00:00:00.872 : [hashfs] locale.scs: Created and validated, 214 entries (FCD9F749557D335EE78FDA9C1AE154C8ADB38FDE5F49C99E21254CA82323851C)
00:00:00.872 : [fs] device locale.scs mounted.
00:00:00.876 : [hashfs] base_cfg.scs: Created and validated, 1 entries (8482637DACBF3C2F66FA2F1E1BF4A4E1D9C989E32666528F7E728D5575B7978B)
00:00:00.876 : [fs] device base_cfg.scs mounted.
00:00:00.876 : [ufs] Home directory: 'C:/Users/1/Documents/Euro Truck Simulator 2'.
00:00:00.877 : [fs] device C:/Users/1/Documents/Euro Truck Simulator 2 mounted.
00:00:00.899 : [hashfs] dlc_actros_tuning.scs: Created and validated, 2612 entries (E5476598060FC66A72E7A8BAF7734F26DC3A2605BB1BAC2B1BCE2A59A3B13B85)
00:00:01.052 : [hashfs] dlc_balkan_e.scs: Created and validated, 10793 entries (F1DF9F9F7BF05BA5D22835969F51AB12AE29D1A6470FFB97EFD9B5D8E60F66CE)
00:00:01.205 : [hashfs] dlc_balt.scs: Created and validated, 11657 entries (FC37C12807F7D2EC8B09808A115334526D7A4BC4F273B492DED0CF7A9CF46271)
00:00:01.216 : [hashfs] dlc_east.scs: Created and validated, 969 entries (6EAC5C07B801B0164A103CD008CF524D7D92D52047A9343E7D57DB456FC52B66)
00:00:01.224 : [hashfs] dlc_flags_pl.scs: Created and validated, 898 entries (699F17C5CF2930BA8381DB1EB487B03D0BBF53E60C207E43950FB1D14CCA57ED)
00:00:01.274 : [hashfs] dlc_fr.scs: Created and validated, 3872 entries (D1922B53594FAF781F068B376DE226A9C59EF06E9DCBD33EFCFF095EDCE63ED8)
00:00:01.292 : [hashfs] dlc_goodyear.scs: Created and validated, 1403 entries (5DD696A3415841381D162D177D93F26FAFEEC2E9E09291E65BE2265C08FEA1FB)
00:00:01.309 : [hashfs] dlc_heavy_cargo.scs: Created and validated, 838 entries (37D7A947490830C937F61DA8C34A29D32C3BF446F8882F499CB1120697AC0252)
00:00:01.323 : [hashfs] dlc_hs_schoch.scs: Created and validated, 1538 entries (9707312D885FCB3CFB269DCAD487D9BAA8C228FE97380FB00AE498FDFD774272)
00:00:01.437 : [hashfs] dlc_iberia.scs: Created and validated, 12249 entries (B740B8111B8E557DB0D06C087FECBE9F991390C53402158BD67A6F9B3D7657AA)
00:00:01.490 : [hashfs] dlc_it.scs: Created and validated, 4533 entries (A729610E7F1E64FA00C2277A7604AD09871787F40AFC7B2F4136181D15722AB8)
00:00:01.522 : [hashfs] dlc_krone.scs: Created and validated, 3505 entries (0E73B364A11216DC3B5205657FE68CF994D5DFAA1FD29F5E5710D5DAD80B2E12)
00:00:01.535 : [hashfs] dlc_metallics.scs: Created and validated, 568 entries (D28F43D83BB5554A517C3D9CCCE7718A58A52C1A302781B259EAB160E290554E)
00:00:01.547 : [hashfs] dlc_michelin.scs: Created and validated, 1184 entries (C788FDD1AD63FDCE79BA30D2CBFFAC435298785C81D1669DCCB84050BE1D8CFB)
00:00:01.573 : [hashfs] dlc_mighty_griffin.scs: Created and validated, 2955 entries (6F0761A923F4902E18597F4F387CD9243CE1F1A044FD645432D37E8E0C84B8C2)
00:00:01.646 : [hashfs] dlc_north.scs: Created and validated, 5581 entries (0FF7EB61B7422A50B9D5F58DD617AE2A2CA6FDEE102B87B848F2DB8006A18251)
00:00:01.661 : [hashfs] dlc_oversize.scs: Created and validated, 673 entries (2D5A6A7E2126228DCF8E08B6CA87BA89C3A03D188159D60A038DC8D7E30DE1B2)
00:00:01.840 : [hashfs] dlc_phys_flags.scs: Created and validated, 10558 entries (ABBA19D3CBA59651A8A71C4E797F3EC88490068D3A0D9829981FDD594093EF9E)
00:00:01.853 : [hashfs] dlc_prehistoric.scs: Created and validated, 2326 entries (EC322C1CE2237FA5B814807B83963173AD699C29FB672276315FE0D0061E8AAE)
00:00:01.861 : [hashfs] dlc_rims.scs: Created and validated, 837 entries (251386FE33AF26BE9BDFBD8E62D88CF41CC0D6A53C3C1AE15E9C53D87C58A861)
00:00:01.866 : [hashfs] dlc_rocket_league.scs: Created and validated, 142 entries (B1C6466920064BB439CD0BCEF148DEEFC2F600837E7928139AE91344E0BCBC73)
00:00:01.895 : [hashfs] dlc_schwarzmuller.scs: Created and validated, 3803 entries (ECE9A1AFEEFA3159328368053B2BEBF3ED163DBCD48047B71CECB1986D22BDA0)
00:00:01.932 : [hashfs] dlc_toys.scs: Created and validated, 2567 entries (AC3AD59BA5D3C988481B2EB0D25A030DCAA17E32933CE7A3289C45A5379CD6EC)
00:00:01.957 : [hashfs] dlc_trailers.scs: Created and validated, 2246 entries (E382233224D083F242B6FFDE9D1FABC0CF641A083408C06259243166786FF6DD)
00:00:01.967 : [hashfs] dlc_vikings.scs: Created and validated, 1564 entries (79B7C663DDC09904FBB75A2B9D701C68BC2992480FF98657CD15C38CBAAC1F77)
00:00:01.986 : [hashfs] dlc_volvo_tuning_pack.scs: Created and validated, 2571 entries (348A829456F54684198578C3ABA2C6F9DF788344CC60E67BDB437FD355950224)
00:00:02.007 : <WARNING> [mod] Mod package 'automat' does not contain a manifest file 'manifest.sii', creating default information set.
00:00:02.007 : <WARNING> [mod] Mod package 'def' does not contain a manifest file 'manifest.sii', creating default information set.
00:00:02.017 : <WARNING> [mod] Mod package 'kogel' does not contain a manifest file 'manifest.sii', creating default information set.
00:00:02.020 : <ERROR> [mods] Cannot find '/mod_description.txt' description file for mod 'krone naczepy'.
00:00:02.020 : <WARNING> [mod] Mod package 'orange-оранжевый' does not contain a manifest file 'manifest.sii', creating default information set.
00:00:02.021 : <WARNING> [mod] Mod package 'platedds' does not contain a manifest file 'manifest.sii', creating default information set.
00:00:02.024 : <ERROR> [unit] File '<UNKNOWNFS>/manifest.sii', line 23:
00:00:02.024 : <ERROR> Expecting attribute name or closing bracket, found ':'
00:00:02.024 : <ERROR> load_unit_tree() - Failed to load unit tree from file ()
00:00:02.024 : <WARNING> [mod] Mod package 'schmitz' does not contain a manifest file 'manifest.sii', creating default information set.
00:00:02.031 : <WARNING> [mod] Mod package 'tandem' does not contain a manifest file 'manifest.sii', creating default information set.
00:00:02.035 : <WARNING> [mod] Mod package 'vehicle' does not contain a manifest file 'manifest.sii', creating default information set.
00:00:02.045 : [zipfs] 2Macedonia_rework_def.scs: Created, 1125 entries
00:00:02.052 : [zipfs] 2Macedonia_rework_def_st.scs: Created, 1125 entries
00:00:02.063 : [zipfs] 2Macedonia_rework_map.scs: Created, 205 entries
00:00:02.070 : [zipfs] 2Macedonia_rework_mat&asset.scs: Created, 283 entries
00:00:02.077 : [zipfs] 50k_addons_1_40.scs: Created, 464 entries
00:00:02.083 : [zipfs] Abrir_Portas_Scania.scs: Created, 405 entries
00:00:02.094 : [zipfs] AfroMap.scs: Created, 2690 entries
00:00:02.094 : <ERROR> [mods] Cannot find '/AfroMap.txt' description file for mod 'AfroMap'.
00:00:02.103 : [zipfs] All_Volvo_Trucks_Door_Animation_Mod.scs: Created, 596 entries
00:00:02.111 : [zipfs] Arnooks SCS Container Skinpack V8.scs: Created, 5293 entries
00:00:02.111 : <WARNING> [mods] No valid categories defined for Arnooks SCS Container Skinpack V8. Setting defaults.
00:00:02.120 : [zipfs] Brutal Traffic V1.3 By Kass.scs: Created, 19 entries
00:00:02.126 : [zipfs] CRASHFIX_HUGE_COMBOS.scs: Created, 6 entries
00:00:02.132 : [zipfs] CustomKogelTrailerv2.scs: Created, 283 entries
00:00:02.132 : <ERROR> [mods] Cannot find '/description.txt' description file for mod 'CustomKogelTrailerv2'.
00:00:02.141 : [zipfs] daf_95_ati.scs: Created, 3641 entries
00:00:02.147 : [zipfs] daf_95_ati_bdf_trailer.scs: Created, 350 entries
00:00:02.153 : [zipfs] daf_95_ati_cabin_accessories.scs: Created, 76 entries
00:00:02.159 : [zipfs] daf_95_ati_tuning.scs: Created, 30 entries
00:00:02.159 : <WARNING> [mods] Mod 'DAF 95ATi DLC tuning pack' dependency DLC 'dlc_daf_tuning_pack' is missing. Marking mod as incompatible.
00:00:02.170 : [zipfs] daf_ntt.scs: Created, 3058 entries
00:00:02.176 : [zipfs] daf_ntt_cabin_accessories.zip: Created, 69 entries
00:00:02.183 : [zipfs] Dark_brown_Interior_scania_s_0.8_beta.scs: Created, 118 entries
00:00:02.189 : [zipfs] DSV_Tandem_v1.2___REWORK__.scs: Created, 59 entries
00:00:02.195 : [zipfs] DSV_Transport.scs: Created, 48 entries
00:00:02.202 : [zipfs] EAA6.1CAPSFIX.scs: Created, 424 entries
00:00:02.207 : [zipfs] EAA_6.1_Promods_2.55_FIX.scs: Created, 94 entries
00:00:02.213 : [zipfs] EAA_6.1_RUSMAP_2.4.0_FIX.scs: Created, 8 entries
00:00:02.213 : <ERROR> [mods] Cannot find '/description.txt' description file for mod 'EAA_6.1_RUSMAP_2.4.0_FIX'.
00:00:02.224 : [zipfs] Ekeri_full_trailer_addon_by_Kast.scs: Created, 2893 entries
00:00:02.229 : [zipfs] ENROEX.scs: Created, 71 entries
00:00:02.234 : [zipfs] ETS2_LAMB_EU-AF-AS-OC_SAT_BG.scs: Created, 32 entries
00:00:02.247 : [zipfs] ets2_signs_on_your_truck.scs: Created, 5131 entries
00:00:02.253 : [zipfs] finnmark_exp1617019615.scs: Created, 257 entries
00:00:02.258 : [hashfs] G6 DD 8x2-v4 - PE -42.scs: Created, 56 entries
00:00:02.258 : <WARNING> [mod] Mod package 'G6 DD 8x2-v4 - PE -42' does not contain a manifest file 'manifest.sii', creating default information set.
00:00:02.262 : [hashfs] G6 DD 8x2-v4.scs: Created, 1860 entries
00:00:02.262 : <WARNING> [mod] Mod package 'G6 DD 8x2-v4' does not contain a manifest file 'manifest.sii', creating default information set.
00:00:02.269 : [zipfs] Improved_SCS_Rain_v0.1_for_1.40.scs: Created, 48 entries
00:00:02.275 : [zipfs] interior_addon_v1.0.scs: Created, 787 entries
00:00:02.282 : [zipfs] interior_addons_v1.1.scs: Created, 1678 entries
00:00:02.291 : [zipfs] KamAZ 54-64-65.scs: Created, 2766 entries
00:00:02.298 : [zipfs] KamAZ_NEFAZ_Dirt.scs: Created, 409 entries
00:00:02.305 : [zipfs] Kögel Old Paylaşım.scs: Created, 138 entries
00:00:02.305 : <ERROR> [unit] File '<C:/Users/1/Documents/Euro Truck Simulator 2/mod/Kögel Old Paylaşım.scs | >/manifest.sii', line 3:
00:00:02.305 : <ERROR> Expecting '{', found 'k'
00:00:02.305 : <ERROR> load_unit_tree() - Failed to load unit tree from file (/manifest.sii)
00:00:02.309 : [hashfs] latvia_rebuild-v127-for-pm_v252.scs: Created, 738 entries
00:00:02.315 : [zipfs] LED_Trucklight_V1.40.scs: Created, 977 entries
00:00:02.321 : [zipfs] Luxury Scania SR 2016 Interior – ETS2 1.39,1.40.scs: Created, 154 entries
00:00:02.378 : [zipfs] MAPA_EAA_6-1.scs: Created, 37740 entries
00:00:02.460 : [zipfs] MAPA_EAA_6-1_BASE.scs: Created, 56749 entries
00:00:02.472 : [zipfs] MedMap_0.1_-_Def.scs: Created, 7414 entries
00:00:02.479 : [zipfs] C:/Users/1/Documents/Euro Truck Simulator 2/mod/Mercedes Actros MP1 (lock).scs: AEM¨ľ¸ŃŔŁĽŇ˛ŐPK
00:00:02.479 : [zipfs] Mercedes Actros MP1 (lock).scs: Created, 727 entries
00:00:02.489 : [zipfs] Mercedes Actros MP1 (unlock).scs: Created, 1473 entries
00:00:02.499 : [zipfs] mercedes_sk.scs: Created, 3093 entries
00:00:02.506 : [zipfs] METALSUR_STARBUS_3_ACTIVADOR_MODBUSARGVIP_1.40.scs: Created, 188 entries
00:00:02.521 : [zipfs] METALSUR_STARBUS_3_v3.4_MODBUSARGVIP_1.40.scs: Created, 4050 entries
00:00:02.531 : [zipfs] NEFAZ 8332.scs: Created, 1147 entries
00:00:02.537 : [zipfs] paris_rebuild_v2_6.scs: Created, 441 entries
00:00:02.544 : [zipfs] Piter_for_RusMap_2.4.0.scs: Created, 148 entries
00:00:02.551 : [zipfs] PM252_RM2.4.0_roadconnection.scs: Created, 355 entries
00:00:02.557 : [zipfs] PM_RM_sign_fix.scs: Created, 8 entries
00:00:02.557 : <WARNING> [mod] Mod package 'PM_RM_sign_fix' does not contain a manifest file 'manifest.sii', creating default information set.
00:00:02.564 : [zipfs] polonus.scs: Created, 27 entries
00:00:02.571 : [zipfs] Project Balkans 5.1 - Assets.scs: Created, 2755 entries
00:00:02.578 : [zipfs] Project Balkans 5.1 - Def.scs: Created, 797 entries
00:00:02.584 : [zipfs] Project Balkans 5.1 - Map.scs: Created, 114 entries
00:00:02.590 : [zipfs] Project Greenland - Promods Ferry.scs: Created, 9 entries
00:00:02.598 : [zipfs] Project Greenland.scs: Created, 183 entries
00:00:02.607 : [hashfs] promods-assets-v255.scs: Created, 36239 entries
00:00:02.617 : [zipfs] promods-def-st-v255 (2).scs: Created, 2412 entries
00:00:02.685 : [zipfs] promods-map-v255.scs: Created, 36422 entries
00:00:02.697 : [hashfs] promods-me-assets-v255a.scs: Created, 3777 entries
00:00:02.711 : [zipfs] promods-me-defmap-v255a.scs: Created, 1290 entries
00:00:02.715 : [hashfs] promods-media-v255.scs: Created, 11 entries
00:00:02.718 : [hashfs] promods-model1-v255.scs: Created, 15792 entries
00:00:02.722 : [hashfs] promods-model2-v255.scs: Created, 22202 entries
00:00:02.725 : [hashfs] promods-model3-v255.scs: Created, 7424 entries
00:00:02.735 : [zipfs] real company logo.scs: Created, 5581 entries
00:00:02.741 : [zipfs] Realistic Brutal Weather Unforgiving V6.4 By Kass.scs: Created, 877 entries
00:00:02.749 : [zipfs] RedseaV1-2-2.scs: Created, 2787 entries
00:00:02.756 : [zipfs] ReMoled Next Gen.zip: Created, 2496 entries
00:00:02.763 : [zipfs] Rhodes_1.0.scs: Created, 111 entries
00:00:02.790 : [zipfs] Rigid_Chassis_Addon_for_Eugene_Scania_NG_by_Kast.scs: Created, 13007 entries
00:00:02.793 : [hashfs] ROEX1model265.scs: Created, 4168 entries
00:00:02.798 : [hashfs] ROEX265RusMap240RC (1).scs: Created, 271 entries
00:00:02.803 : [hashfs] ROEX265RusMap240RC.scs: Created, 271 entries
00:00:02.811 : [hashfs] ROEX295SR10RC.scs: Created, 48 entries
00:00:02.811 : <WARNING> [unit] Ignored unknown attribute compatible_version[] =
00:00:02.858 : [zipfs] ROEX2model265.scs: Created, 35669 entries
00:00:02.864 : [hashfs] ROEXallPM255RC.scs: Created, 1183 entries
00:00:02.868 : [hashfs] ROEXassets265.scs: Created, 12487 entries
00:00:02.873 : [hashfs] ROEXdefmap265.scs: Created, 2771 entries
00:00:02.876 : [hashfs] ROEXprefab265.scs: Created, 11045 entries
00:00:02.883 : [zipfs] Route_Advisor_09.12.2019.scs: Created, 43 entries
00:00:02.901 : [zipfs] RusMap-def_v2.4.1.scs: Created, 8250 entries
00:00:02.908 : [zipfs] RusMap-map_v2.4.1.scs: Created, 1015 entries
00:00:02.927 : [zipfs] RusMap-model2_v2.4.1.scs: Created, 9029 entries
00:00:02.950 : [zipfs] RusMap-model_v2.4.1.scs: Created, 20039 entries
00:00:02.958 : [zipfs] Scania_Door_Animation.scs: Created, 405 entries
00:00:02.967 : [zipfs] Scania_S_Krone_Tandem_BIG_Pack.scs: Created, 363 entries
00:00:02.977 : [zipfs] C:/Users/1/Documents/Euro Truck Simulator 2/mod/Scania_Touring__1.39_.scs: This file has been downloaded from http://www.modshost.com
00:00:02.977 : [zipfs] C:/Users/1/Documents/Euro Truck Simulator 2/mod/Scania_Touring__1.39_.scs: Visit http://www.modshost.com to download mods
00:00:02.977 : [zipfs] C:/Users/1/Documents/Euro Truck Simulator 2/mod/Scania_Touring__1.39_.scs: Free storage your for mods: http://www.modshost.com/upload
00:00:02.977 : [zipfs] C:/Users/1/Documents/Euro Truck Simulator 2/mod/Scania_Touring__1.39_.scs: Follow us on social networks:
00:00:02.977 : [zipfs] C:/Users/1/Documents/Euro Truck Simulator 2/mod/Scania_Touring__1.39_.scs: https://www.facebook.com/modshostcom
00:00:02.977 : [zipfs] C:/Users/1/Documents/Euro Truck Simulator 2/mod/Scania_Touring__1.39_.scs: https://twitter.com/host_mods
00:00:02.977 : [zipfs] C:/Users/1/Documents/Euro Truck Simulator 2/mod/Scania_Touring__1.39_.scs: https://www.youtube.com/channel/UCfu8HSx...VA8VaGYs7A
00:00:02.977 : [zipfs] Scania_Touring__1.39_.scs: Created, 988 entries
00:00:02.977 : <WARNING> [mods] Unknown category 'bus' defined for Scania_Touring__1.39_. Ignoring.
00:00:02.977 : <WARNING> [mods] No valid categories defined for Scania_Touring__1.39_. Setting defaults.
00:00:02.977 : <WARNING> [mods] Incompatible mod - Scania_Touring__1.39_
00:00:02.986 : [zipfs] sibirmap2.1.1.mapdef.scs: Created, 2076 entries
00:00:03.010 : [zipfs] sibirmap2.1.1.model.scs: Created, 15051 entries
00:00:03.018 : [zipfs] sibirmap2.1.1.undersrm.scs: Created, 509 entries
00:00:03.024 : [zipfs] Skin_Edit_STARBUS_3_MODBUSARGVIP.scs: Created, 5 entries
00:00:03.024 : <WARNING> [mod] Mod package 'Skin_Edit_STARBUS_3_MODBUSARGVIP' does not contain a manifest file 'manifest.sii', creating default information set.
00:00:03.034 : [zipfs] SRmap_[Def and Map].scs: Created, 3716 entries
00:00:03.104 : [zipfs] SRmap_[Model1].scs: Created, 46120 entries
00:00:03.143 : [zipfs] SRmap_[Model2].scs: Created, 22976 entries
00:00:03.151 : [zipfs] SRmap__Hot_Fix__10.0.1.scs: Created, 128 entries
00:00:03.157 : [zipfs] SuperZoomvPM135.scs: Created, 5 entries
00:00:03.165 : [zipfs] SwedishIslandsMap_v1.10-Wombat.scs: Created, 378 entries
00:00:03.173 : [zipfs] SZM_Addon_2v.scs: Created, 775 entries
00:00:03.241 : [zipfs] The Great Steppe-def-v2.0.scs: Created, 45191 entries
00:00:03.247 : [zipfs] The Great Steppe-map-v2.0.scs: Created, 672 entries
00:00:03.261 : [zipfs] The Great Steppe-model-v2.0.scs: Created, 8939 entries
00:00:03.430 : [zipfs] TM135LITE.scs: Created, 35961 entries
00:00:03.436 : [hashfs] TML135ME255RC.scs: Created, 47 entries
00:00:03.442 : [zipfs] trailers kogel.scs: Created, 1349 entries
00:00:03.448 : [zipfs] trailers schmitz.scs: Created, 998 entries
00:00:03.456 : [zipfs] TurkeyRhodesFIXv2.scs: Created, 14 entries
00:00:03.460 : [hashfs] ULFIX140v2.scs: Created, 375 entries
00:00:03.465 : [hashfs] Urban_Truck.scs: Created, 1739 entries
00:00:03.465 : <WARNING> [mods] Incompatible mod - Urban_Truck
00:00:03.473 : [zipfs] C:/Users/1/Documents/Euro Truck Simulator 2/mod/volga_def.scs: Created with ETS2 Studio v.0.7.0.1
00:00:03.473 : [zipfs] C:/Users/1/Documents/Euro Truck Simulator 2/mod/volga_def.scs: http://www.ets2studio.com
00:00:03.473 : [zipfs] volga_def.scs: Created, 2535 entries
00:00:03.479 : [zipfs] volga_map.scs: Created, 54 entries
00:00:03.496 : [zipfs] volga_model.scs: Created, 9514 entries
00:00:03.496 : [mod_package_manager] Requesting Steam Workshop content..
00:00:03.500 : exec /home/config.cfg
00:00:03.500 : [sys] Executing /home/config.cfg ...
00:00:03.504 : uset s_init_intro_music_mute "0"
00:00:03.504 : uset s_init_intro_music_volume "0.5"
00:00:03.504 : uset s_init_ui_music_mute "1"
00:00:03.504 : uset s_init_ui_music_volume "0.02"
00:00:03.504 : uset s_init_master_mute "0"
00:00:03.504 : uset s_init_master_volume "0.52"
00:00:03.504 : uset s_output_driver ""
00:00:03.504 : uset s_live_update "0"
00:00:03.505 : uset s_suspend_sound "1"
00:00:03.505 : uset s_sound_debug "0"
00:00:03.505 : uset r_show_sun_cascades "0"
00:00:03.505 : uset r_tonemap_debug "0"
00:00:03.505 : uset r_drr_strength "8.0"
00:00:03.505 : uset r_hide_helpers "0"
00:00:03.505 : uset r_full_resolution_corrections "0"
00:00:03.505 : uset g_mm_help_shown "1"
00:00:03.505 : uset g_frame_image_fmt "jpg"
00:00:03.505 : uset g_frames_path ""
00:00:03.505 : uset g_map_note_user_id "0"
00:00:03.505 : uset g_color_feedback "1"
00:00:03.505 : uset g_disable_hud_activation "0"
00:00:03.505 : uset r_wireframe "0"
00:00:03.505 : uset g_interior_camera_zero_pitch "0"
00:00:03.505 : uset r_multimon_exterior_in_aux "0"
00:00:03.505 : uset r_multimon_interior_in_main "1"
00:00:03.505 : uset r_multimon_rotation_aux "0"
00:00:03.505 : uset r_multimon_rotation_right "0"
00:00:03.505 : uset r_multimon_rotation_left "0"
00:00:03.505 : uset r_multimon_rotation_center "0"
00:00:03.505 : uset r_multimon_vert_offset_right "0"
00:00:03.505 : uset r_multimon_vert_offset_left "0"
00:00:03.505 : uset r_multimon_border_fov_right "0"
00:00:03.505 : uset r_multimon_border_fov_left "0"
00:00:03.506 : uset r_multimon_fov_vertical "0"
00:00:03.506 : uset r_multimon_fov_horizontal "50"
00:00:03.506 : uset r_multimon_mode "0"
00:00:03.506 : uset r_use_depth_bounds "1"
00:00:03.506 : uset r_buffer_page_size "10"
00:00:03.506 : uset r_deferred_debug "0"
00:00:03.506 : uset r_mirror_scale_y "2"
00:00:03.506 : uset r_mirror_scale_x "2"
00:00:03.506 : uset r_scale_y "1.25"
00:00:03.506 : uset r_scale_x "1"
00:00:03.506 : uset r_normal_maps "1"
00:00:03.506 : uset r_sunshafts "1"
00:00:03.506 : uset r_color_saturation "1.0"
00:00:03.506 : uset r_color_yellow_blue "0.0"
00:00:03.506 : uset r_color_magenta_green "0.0"
00:00:03.506 : uset r_color_cyan_red "0.0"
00:00:03.506 : uset r_color_correction "1"
00:00:03.506 : uset r_light_flares "1"
00:00:03.506 : uset r_cloud_shadows "1"
00:00:03.506 : uset r_dof_filter_size "0.5"
00:00:03.506 : uset r_dof_transition "400.0"
00:00:03.506 : uset r_dof_start "200.0"
00:00:03.506 : uset r_dof "1"
00:00:03.506 : uset r_ssao "3"
00:00:03.506 : uset r_smaa "3"
00:00:03.506 : uset r_fake_shadows "2"
00:00:03.506 : uset r_sun_shadow_texture_size "4096"
00:00:03.506 : uset r_sun_shadow_quality "3"
00:00:03.506 : uset r_mirror_group "3"
00:00:03.506 : uset r_mirror_view_distance "400"
00:00:03.506 : uset r_deferred_mirrors "2"
00:00:03.506 : uset r_nowmi "0"
00:00:03.506 : uset r_startup_progress "0"
00:00:03.506 : uset r_setup_done "1"
00:00:03.506 : uset r_gamma "0.87"
00:00:03.506 : uset r_manual_stereo_buffer_scale "1.0"
00:00:03.506 : uset r_manual_stereo_ui_fov_game "100"
00:00:03.506 : uset r_manual_stereo_ui_fov "80"
00:00:03.506 : uset r_manual_stereo_ui_dist_game "0.5"
00:00:03.506 : uset r_manual_stereo_ui_dist "0.8"
00:00:03.506 : uset r_manual_stereo_in_menu "1"
00:00:03.507 : uset r_minimal_unfinished_frames "0"
00:00:03.507 : uset r_no_frame_tracking "0"
00:00:03.507 : uset r_fullscreen "1"
00:00:03.507 : uset r_mode_refresh "74"
00:00:03.507 : uset r_mode_height "1440"
00:00:03.507 : uset r_mode_width "2560"
00:00:03.507 : uset r_path ""
00:00:03.507 : uset r_device "dx11"
00:00:03.507 : uset i_virtual_cursor_speed "500.0"
00:00:03.507 : uset g_stream_exts ".ogg;.mp3"
00:00:03.507 : uset g_tobii "1"
00:00:03.507 : uset g_trackir "1"
00:00:03.507 : uset g_lod_factor_pedestrian "1"
00:00:03.507 : uset g_pedestrian "1"
00:00:03.507 : uset g_light_span_factor "1"
00:00:03.507 : uset g_light_distance_factor "1"
00:00:03.507 : uset g_vehicle_flare_lights "1"
00:00:03.507 : uset g_auto_traffic_headlights "1"
00:00:03.507 : uset g_lod_factor_parked "1.0"
00:00:03.507 : uset g_lod_factor_traffic "1.0"
00:00:03.507 : uset g_traffic "1.0"
00:00:03.507 : uset g_kdop_preview "0"
00:00:03.507 : uset g_screenshot_on_bug_quality "100"
00:00:03.507 : uset g_screenshot_on_bug "0"
00:00:03.507 : uset g_shoulder_block_coloring "0"
00:00:03.507 : uset g_debug_map_limits "0"
00:00:03.507 : uset g_city_name_move "0"
00:00:03.507 : uset g_developer "0"
00:00:03.507 : uset g_semantical_pause_inactivity "120"
00:00:03.507 : uset g_pause_on_disconnect "1"
00:00:03.507 : uset g_semantical_ff_inactivity "300"
00:00:03.507 : uset g_steam_rich_presence "1"
00:00:03.507 : uset g_steam_browser "1"
00:00:03.507 : uset g_steam_screenshots "2"
00:00:03.507 : uset g_artist_id "0"
00:00:03.507 : uset g_save_format "0"
00:00:03.507 : uset g_trailer_cables_mode "2"
00:00:03.507 : uset g_spec_trans_refill_tank "1"
00:00:03.507 : uset g_flyspeed "100.0"
00:00:03.507 : uset g_online_loading_screens "1"
00:00:03.507 : uset g_news "1"
00:00:03.508 : uset g_colbox "0"
00:00:03.508 : uset g_radio_mode "1"
00:00:03.508 : uset g_ignore_low_fps "0"
00:00:03.508 : uset g_truck_light_specular "1"
00:00:03.508 : uset g_gfx_all_scales "0"
00:00:03.508 : uset g_gfx_advanced "1"
00:00:03.508 : uset g_gfx_quality "-1"
00:00:03.508 : uset g_hq_3d_scale "0.0"
00:00:03.508 : uset g_hq_3d_screenshot "0"
00:00:03.508 : uset g_menu_aa_limit "8"
00:00:03.508 : uset g_additional_water_fov "20.0f"
00:00:03.508 : uset g_rain_reflect_hookups "1"
00:00:03.508 : uset g_rain_reflect_actor "1"
00:00:03.508 : uset g_rain_reflect_traffic "1"
00:00:03.508 : uset g_rain_reflect_cache "1"
00:00:03.508 : uset g_rain_reflection "3"
00:00:03.508 : uset g_reflection_scale "0"
00:00:03.508 : uset g_reflection "3"
00:00:03.508 : uset g_grass_density "2"
00:00:03.508 : uset g_veg_detail "2"
00:00:03.508 : uset g_save_indicator "1"
00:00:03.508 : uset g_game_version "1.40.3.34"
00:00:03.508 : uset g_force_online_lscrs "0"
00:00:03.508 : uset g_hw_info "1"
00:00:03.508 : uset g_glass_debugging_level "0"
00:00:03.508 : uset g_line_sort "0"
00:00:03.508 : uset g_cargo_sort "0"
00:00:03.508 : uset g_bloom_standard_deviation "0.5"
00:00:03.508 : uset g_bloom_override "0"
00:00:03.508 : uset g_bloom "1.0"
00:00:03.508 : uset g_global_force_load_selector "0"
00:00:03.508 : uset g_desktop_fadeout "60"
00:00:03.508 : uset g_minicon "0"
00:00:03.508 : uset g_console_state "0"
00:00:03.508 : uset g_console "0"
00:00:03.508 : uset g_texture_usage_stats "0"
00:00:03.508 : uset g_fps "0"
00:00:03.508 : uset ui_tooltip_delay "0.4"
00:00:03.508 : uset r_output "-1"
00:00:03.509 : uset r_adapter "-1"
00:00:03.509 : uset r_vsync "0"
00:00:03.509 : uset r_color_mode "0"
00:00:03.509 : uset r_anisotropy_factor "1"
00:00:03.509 : uset r_texture_detail "0"
00:00:03.509 : uset cf_asus_aura "1"
00:00:03.509 : uset cf_razer_chroma "1"
00:00:03.509 : uset v_bug_break "0"
00:00:03.509 : uset t_locked_fps "0"
00:00:03.509 : uset t_averaging_window_length "20"
00:00:03.521 : [lang] Language autodetection: 415
00:00:03.530 : Selected language: pl_pl
00:00:03.530 : Euro Truck Simulator 2 init ver.1.40.3.34s (rev. 1379452c11f0)
00:00:03.530 : [gfx] Selected rendering device: dx11
00:00:03.540 : [gfx] NVAPI initialized
00:00:03.542 : [gfx] AGS not detected. (6)
00:00:03.650 : [net] LOG INFO: Started
00:00:03.654 : [fs] device mounted.
00:00:03.655 : Setting UI reference mode to: 1440x900...
00:00:03.656 : [dxgi] Detected following adapters:
00:00:03.658 : [dxgi] 0 - NVIDIA GeForce RTX 2060 SUPER (27.21.14.6627) [8031 MB]
00:00:03.658 : [gfx] Using the DXGI display backend
00:00:03.802 : [dxgi] Using adapter: NVIDIA GeForce RTX 2060 SUPER (27.21.14.6627) [8031 MB]
00:00:03.809 : [dx11] Using SM5X rendering path
00:00:03.967 : [disp] Adapter 0: on DXGI backend
00:00:03.967 : [disp] Output 0 : \\.\DISPLAY2 - CRTC @ (0, 0, 2560, 1440)
00:00:03.967 : [disp] Detected color modes:
00:00:03.967 : [disp] Mode 0 - SDR
00:00:03.967 : [disp] Display MinLum: 0.500000, MaxLum 270.000000, MaxAvgLum: 270.000000
00:00:03.967 : [disp] Mode 0 - 640x480 (32bpp) [59Hz]
00:00:03.967 : [disp] Mode 1 - 640x480 (32bpp) [60Hz]
00:00:03.967 : [disp] Mode 2 - 640x480 (32bpp) [72Hz]
00:00:03.967 : [disp] Mode 3 - 640x480 (32bpp) [75Hz]
00:00:03.967 : [disp] Mode 4 - 720x480 (32bpp) [59Hz]
00:00:03.967 : [disp] Mode 5 - 720x480 (32bpp) [60Hz]
00:00:03.967 : [disp] Mode 6 - 720x576 (32bpp) [50Hz]
00:00:03.967 : [disp] Mode 7 - 800x600 (32bpp) [56Hz]
00:00:03.967 : [disp] Mode 8 - 800x600 (32bpp) [60Hz]
00:00:03.967 : [disp] Mode 9 - 800x600 (32bpp) [72Hz]
00:00:03.967 : [disp] Mode 10 - 800x600 (32bpp) [75Hz]
00:00:03.967 : [disp] Mode 11 - 1024x768 (32bpp) [60Hz]
00:00:03.967 : [disp] Mode 12 - 1024x768 (32bpp) [70Hz]
00:00:03.967 : [disp] Mode 13 - 1024x768 (32bpp) [75Hz]
00:00:03.967 : [disp] Mode 14 - 1152x864 (32bpp) [59Hz]
00:00:03.967 : [disp] Mode 15 - 1152x864 (32bpp) [59Hz]
00:00:03.968 : [disp] Mode 16 - 1176x664 (32bpp) [50Hz]
00:00:03.968 : [disp] Mode 17 - 1176x664 (32bpp) [50Hz]
00:00:03.968 : [disp] Mode 18 - 1176x664 (32bpp) [59Hz]
00:00:03.968 : [disp] Mode 19 - 1176x664 (32bpp) [59Hz]
00:00:03.968 : [disp] Mode 20 - 1176x664 (32bpp) [60Hz]
00:00:03.968 : [disp] Mode 21 - 1176x664 (32bpp) [60Hz]
00:00:03.968 : [disp] Mode 22 - 1280x720 (32bpp) [50Hz]
00:00:03.968 : [disp] Mode 23 - 1280x720 (32bpp) [59Hz]
00:00:03.968 : [disp] Mode 24 - 1280x720 (32bpp) [60Hz]
00:00:03.968 : [disp] Mode 25 - 1280x768 (32bpp) [59Hz]
00:00:03.968 : [disp] Mode 26 - 1280x768 (32bpp) [59Hz]
00:00:03.968 : [disp] Mode 27 - 1280x800 (32bpp) [59Hz]
00:00:03.968 : [disp] Mode 28 - 1280x800 (32bpp) [59Hz]
00:00:03.968 : [disp] Mode 29 - 1280x960 (32bpp) [60Hz]
00:00:03.968 : [disp] Mode 30 - 1280x1024 (32bpp) [60Hz]
00:00:03.968 : [disp] Mode 31 - 1280x1024 (32bpp) [75Hz]
00:00:03.968 : [disp] Mode 32 - 1280x1440 (32bpp) [59Hz]
00:00:03.968 : [disp] Mode 33 - 1360x768 (32bpp) [59Hz]
00:00:03.968 : [disp] Mode 34 - 1360x768 (32bpp) [59Hz]
00:00:03.968 : [disp] Mode 35 - 1366x768 (32bpp) [59Hz]
00:00:03.968 : [disp] Mode 36 - 1366x768 (32bpp) [59Hz]
00:00:03.968 : [disp] Mode 37 - 1440x900 (32bpp) [59Hz]
00:00:03.968 : [disp] Mode 38 - 1600x900 (32bpp) [59Hz]
00:00:03.968 : [disp] Mode 39 - 1600x900 (32bpp) [59Hz]
00:00:03.968 : [disp] Mode 40 - 1600x1024 (32bpp) [59Hz]
00:00:03.968 : [disp] Mode 41 - 1600x1024 (32bpp) [59Hz]
00:00:03.968 : [disp] Mode 42 - 1600x1200 (32bpp) [59Hz]
00:00:03.968 : [disp] Mode 43 - 1600x1200 (32bpp) [59Hz]
00:00:03.968 : [disp] Mode 44 - 1600x1200 (32bpp) [74Hz]
00:00:03.968 : [disp] Mode 45 - 1600x1200 (32bpp) [74Hz]
00:00:03.968 : [disp] Mode 46 - 1680x1050 (32bpp) [59Hz]
00:00:03.968 : [disp] Mode 47 - 1920x1080 (32bpp) [50Hz]
00:00:03.968 : [disp] Mode 48 - 1920x1080 (32bpp) [59Hz]
00:00:03.969 : [disp] Mode 49 - 1920x1080 (32bpp) [60Hz]
00:00:03.969 : [disp] Mode 50 - 1920x1200 (32bpp) [59Hz]
00:00:03.969 : [disp] Mode 51 - 1920x1200 (32bpp) [59Hz]
00:00:03.969 : [disp] Mode 52 - 1920x1200 (32bpp) [74Hz]
00:00:03.969 : [disp] Mode 53 - 1920x1200 (32bpp) [74Hz]
00:00:03.969 : [disp] Mode 54 - 1920x1440 (32bpp) [59Hz]
00:00:03.969 : [disp] Mode 55 - 1920x1440 (32bpp) [59Hz]
00:00:03.969 : [disp] Mode 56 - 1920x1440 (32bpp) [74Hz]
00:00:03.969 : [disp] Mode 57 - 1920x1440 (32bpp) [74Hz]
00:00:03.969 : [disp] Mode 58 - 2560x1440 (32bpp) [59Hz]
00:00:03.969 : [disp] Mode 59 - 2560x1440 (32bpp) [74Hz]
00:00:03.969 : [disp] Output 1 : \\.\DISPLAY1 - CRTC @ (2560, 0, 1920, 1080)
00:00:03.969 : [disp] Detected color modes:
00:00:03.969 : [disp] Mode 0 - SDR
00:00:03.969 : [disp] Display MinLum: 0.500000, MaxLum 270.000000, MaxAvgLum: 270.000000
00:00:03.969 : [disp] Mode 0 - 640x480 (32bpp) [59Hz]
00:00:03.969 : [disp] Mode 1 - 640x480 (32bpp) [60Hz]
00:00:03.969 : [disp] Mode 2 - 720x480 (32bpp) [59Hz]
00:00:03.969 : [disp] Mode 3 - 720x480 (32bpp) [60Hz]
00:00:03.969 : [disp] Mode 4 - 720x576 (32bpp) [50Hz]
00:00:03.969 : [disp] Mode 5 - 800x600 (32bpp) [60Hz]
00:00:03.969 : [disp] Mode 6 - 1024x768 (32bpp) [60Hz]
00:00:03.969 : [disp] Mode 7 - 1152x864 (32bpp) [59Hz]
00:00:03.969 : [disp] Mode 8 - 1152x864 (32bpp) [59Hz]
00:00:03.969 : [disp] Mode 9 - 1176x664 (32bpp) [50Hz]
00:00:03.969 : [disp] Mode 10 - 1176x664 (32bpp) [50Hz]
00:00:03.969 : [disp] Mode 11 - 1176x664 (32bpp) [59Hz]
00:00:03.969 : [disp] Mode 12 - 1176x664 (32bpp) [59Hz]
00:00:03.969 : [disp] Mode 13 - 1176x664 (32bpp) [60Hz]
00:00:03.969 : [disp] Mode 14 - 1176x664 (32bpp) [60Hz]
00:00:03.969 : [disp] Mode 15 - 1280x720 (32bpp) [50Hz]
00:00:03.970 : [disp] Mode 16 - 1280x720 (32bpp) [59Hz]
00:00:03.970 : [disp] Mode 17 - 1280x720 (32bpp) [60Hz]
00:00:03.970 : [disp] Mode 18 - 1280x768 (32bpp) [59Hz]
00:00:03.970 : [disp] Mode 19 - 1280x768 (32bpp) [59Hz]
00:00:03.970 : [disp] Mode 20 - 1280x800 (32bpp) [59Hz]
00:00:03.970 : [disp] Mode 21 - 1280x960 (32bpp) [60Hz]
00:00:03.970 : [disp] Mode 22 - 1280x960 (32bpp) [60Hz]
00:00:03.970 : [disp] Mode 23 - 1280x1024 (32bpp) [60Hz]
00:00:03.970 : [disp] Mode 24 - 1360x768 (32bpp) [59Hz]
00:00:03.970 : [disp] Mode 25 - 1360x768 (32bpp) [59Hz]
00:00:03.970 : [disp] Mode 26 - 1366x768 (32bpp) [59Hz]
00:00:03.970 : [disp] Mode 27 - 1366x768 (32bpp) [59Hz]
00:00:03.970 : [disp] Mode 28 - 1440x900 (32bpp) [59Hz]
00:00:03.970 : [disp] Mode 29 - 1600x900 (32bpp) [60Hz]
00:00:03.970 : [disp] Mode 30 - 1600x1024 (32bpp) [59Hz]
00:00:03.970 : [disp] Mode 31 - 1600x1024 (32bpp) [59Hz]
00:00:03.970 : [disp] Mode 32 - 1680x1050 (32bpp) [59Hz]
00:00:03.970 : [disp] Mode 33 - 1920x1080 (32bpp) [50Hz]
00:00:03.970 : [disp] Mode 34 - 1920x1080 (32bpp) [60Hz]
00:00:03.970 : [disp] Mode 35 - 1920x1080 (32bpp) [59Hz]
00:00:04.220 : [sound] Available drivers: #4
00:00:04.221 : [sound] Driver 0 = Głośniki (Sound BlasterX AE-5) (48000 Hz) ({559445c6-adcf-4340-9b68-49c44d2c6691})
00:00:04.222 : [sound] Driver 1 = SPDIF-Out (Sound BlasterX AE-5) (48000 Hz) ({5cb8cbd9-a746-4988-a71d-465b2ebc6b69})
00:00:04.222 : [sound] Driver 2 = Q3279WG5B (NVIDIA High Definition Audio) (48000 Hz) ({741de0db-eef5-4205-942e-5987a63cd82e})
00:00:04.223 : [sound] Driver 3 = CABLE Input (VB-Audio Virtual Cable) (48000 Hz) ({79fac6bc-387f-4d4e-b64e-4d10cb5351f1})
00:00:04.387 : [sound] Selecting default audio driver (0).
00:00:04.495 : [di8] Initializing device '@@keyboard@@' as 'keyboard'
00:00:04.496 : [di8] Initializing device '@@i_mouse@@' as 'mouse'
00:00:04.552 : [di8] Initializing device 'Logitech G920 Driving Force Racing Wheel USB' as '{7B062CF0-8675-11EB-8003-444553540000}|{C262046D-0000-0000-0000-504944564944}'
00:00:04.554 : [di8] FF Constant force supported
00:00:04.554 : [di8] FF Ramp force supported
00:00:04.554 : [di8] FF Square force supported
00:00:04.554 : [di8] FF Sine force supported
00:00:04.555 : [di8] FF Triangle force supported
00:00:04.555 : [di8] FF SawtoothUp force supported
00:00:04.555 : [di8] FF SawtoothDown force supported
00:00:04.555 : [di8] FF Spring force supported
00:00:04.555 : [di8] FF Damper force supported
00:00:04.555 : [di8] FF Inertia force supported
00:00:04.555 : [di8] FF Friction force supported
00:00:04.556 : [di8] FF Axis 'x' 'Wheel axis' reports force 10N with resolution of 256
00:00:04.696 : [fs] device F:/GRY/steamapps/workshop/content/227300/1997286093 mounted.
00:00:04.701 : [fs] device F:/GRY/steamapps/workshop/content/227300/1997286093/interiorimp mounted.
00:00:04.706 : [fs] device F:/GRY/steamapps/workshop/content/227300/2391590113 mounted.
00:00:04.710 : [fs] device F:/GRY/steamapps/workshop/content/227300/2391590113/universal mounted.
00:00:04.714 : [fs] device F:/GRY/steamapps/workshop/content/227300/2445507846 mounted.
00:00:04.718 : [fs] device F:/GRY/steamapps/workshop/content/227300/2445507846/universal mounted.
00:00:04.764 : [fs] device F:/GRY/steamapps/workshop/content/227300/668698544 mounted.
00:00:04.769 : [fs] device F:/GRY/steamapps/workshop/content/227300/668698544/drivers mounted.
00:00:04.774 : [fs] device F:/GRY/steamapps/workshop/content/227300/1203474845 mounted.
00:00:04.785 : [zipfs] 140.zip: Created, 198 entries
00:00:04.785 : [fs] device F:/GRY/steamapps/workshop/content/227300/1203474845/140.zip mounted.
00:00:04.786 : [zipfs] 140.zip: Unmounted
00:00:04.786 : [fs] device F:/GRY/steamapps/workshop/content/227300/1307030705 mounted.
00:00:04.792 : [fs] device F:/GRY/steamapps/workshop/content/227300/1307030705/universal mounted.
00:00:04.796 : [fs] device F:/GRY/steamapps/workshop/content/227300/2100753543 mounted.
00:00:04.797 : [fs] device F:/GRY/steamapps/workshop/content/227300/2100753543/universal mounted.
00:00:04.802 : [fs] device F:/GRY/steamapps/workshop/content/227300/2440528569 mounted.
00:00:04.805 : [fs] device F:/GRY/steamapps/workshop/content/227300/2440528569/universal mounted.
00:00:04.810 : [fs] device F:/GRY/steamapps/workshop/content/227300/703424203 mounted.
00:00:04.814 : [fs] device F:/GRY/steamapps/workshop/content/227300/703424203/ultimate mounted.
00:00:04.817 : <WARNING> [mods] No valid categories defined for mod_workshop_package.0000000029ED66CB. Setting defaults.
00:00:04.818 : [fs] device F:/GRY/steamapps/workshop/content/227300/2118463356 mounted.
00:00:04.819 : [fs] device F:/GRY/steamapps/workshop/content/227300/2118463356/universal mounted.
00:00:04.823 : [fs] device F:/GRY/steamapps/workshop/content/227300/620915774 mounted.
00:00:04.827 : [fs] device F:/GRY/steamapps/workshop/content/227300/620915774/universal mounted.
00:00:04.831 : [fs] device F:/GRY/steamapps/workshop/content/227300/926118980 mounted.
00:00:04.837 : [fs] device F:/GRY/steamapps/workshop/content/227300/926118980/universal mounted.
00:00:04.841 : [fs] device F:/GRY/steamapps/workshop/content/227300/731256324 mounted.
00:00:04.842 : [fs] device F:/GRY/steamapps/workshop/content/227300/731256324/universal mounted.
00:00:04.846 : [fs] device F:/GRY/steamapps/workshop/content/227300/1915802227 mounted.
00:00:04.864 : [zipfs] base140.zip: Created, 1943 entries
00:00:04.864 : [fs] device F:/GRY/steamapps/workshop/content/227300/1915802227/base140.zip mounted.
00:00:04.864 : [zipfs] base140.zip: Unmounted
00:00:04.864 : [fs] device F:/GRY/steamapps/workshop/content/227300/2434996023 mounted.
00:00:04.872 : [zipfs] universal.zip: Created, 47 entries
00:00:04.872 : [fs] device F:/GRY/steamapps/workshop/content/227300/2434996023/universal.zip mounted.
00:00:04.872 : [zipfs] universal.zip: Unmounted
00:00:04.872 : [fs] device F:/GRY/steamapps/workshop/content/227300/2445384221 mounted.
00:00:04.884 : [zipfs] ets2gfhilo_140.zip: Created, 140 entries
00:00:04.884 : [fs] device F:/GRY/steamapps/workshop/content/227300/2445384221/ets2gfhilo_140.zip mounted.
00:00:04.884 : [zipfs] ets2gfhilo_140.zip: Unmounted
00:00:04.885 : [fs] device F:/GRY/steamapps/workshop/content/227300/2450370538 mounted.
00:00:04.889 : [fs] device F:/GRY/steamapps/workshop/content/227300/2450370538/zeemods mounted.
00:00:04.893 : [fs] device F:/GRY/steamapps/workshop/content/227300/2435008284 mounted.
00:00:04.906 : [zipfs] base140.zip: Created, 233 entries
00:00:04.906 : [fs] device F:/GRY/steamapps/workshop/content/227300/2435008284/base140.zip mounted.
00:00:04.906 : [zipfs] base140.zip: Unmounted
00:00:04.907 : [fs] device F:/GRY/steamapps/workshop/content/227300/1709544505 mounted.
00:00:04.917 : [zipfs] universal.zip: Created, 2748 entries
00:00:04.917 : [fs] device F:/GRY/steamapps/workshop/content/227300/1709544505/universal.zip mounted.
00:00:04.918 : [zipfs] universal.zip: Unmounted
00:00:04.918 : [fs] device F:/GRY/steamapps/workshop/content/227300/2462551115 mounted.
00:00:04.919 : [fs] device F:/GRY/steamapps/workshop/content/227300/2462551115/universal mounted.
00:00:04.923 : [fs] device F:/GRY/steamapps/workshop/content/227300/2462561509 mounted.
00:00:04.924 : [fs] device F:/GRY/steamapps/workshop/content/227300/2462561509/universal mounted.
00:00:04.928 : [fs] device F:/GRY/steamapps/workshop/content/227300/2421393956 mounted.
00:00:04.944 : [zipfs] universal.zip: Created, 4567 entries
00:00:04.944 : [fs] device F:/GRY/steamapps/workshop/content/227300/2421393956/universal.zip mounted.
00:00:04.944 : [zipfs] universal.zip: Unmounted
00:00:04.944 : [fs] device F:/GRY/steamapps/workshop/content/227300/2378677514 mounted.
00:00:04.949 : [fs] device F:/GRY/steamapps/workshop/content/227300/2378677514/139 mounted.
00:00:04.953 : [fs] device F:/GRY/steamapps/workshop/content/227300/2450152010 mounted.
00:00:04.964 : [zipfs] F:/GRY/steamapps/workshop/content/227300/2450152010/combo.zip: AEM¨ľ¸ŃŔŁĽŇ˛ŐPK
00:00:04.964 : [zipfs] combo.zip: Created, 4064 entries
00:00:04.964 : [fs] device F:/GRY/steamapps/workshop/content/227300/2450152010/combo.zip mounted.
00:00:04.964 : [zipfs] combo.zip: Unmounted
00:00:04.965 : [fs] device F:/GRY/steamapps/workshop/content/227300/2462431555 mounted.
00:00:04.969 : [fs] device F:/GRY/steamapps/workshop/content/227300/2462431555/actros_mp3 mounted.
00:00:04.974 : [fs] device F:/GRY/steamapps/workshop/content/227300/1970024898 mounted.
00:00:04.978 : [fs] device F:/GRY/steamapps/workshop/content/227300/1970024898/universal mounted.
00:00:04.982 : [fs] device F:/GRY/steamapps/workshop/content/227300/2100157424 mounted.
00:00:04.992 : [zipfs] universal.zip: Created, 1943 entries
00:00:04.992 : [fs] device F:/GRY/steamapps/workshop/content/227300/2100157424/universal.zip mounted.
00:00:04.992 : [zipfs] universal.zip: Unmounted
00:00:04.992 : [fs] device F:/GRY/steamapps/workshop/content/227300/1764268887 mounted.
00:00:04.997 : [fs] device F:/GRY/steamapps/workshop/content/227300/1764268887/nextgenscaniarework mounted.
00:00:05.002 : [fs] device F:/GRY/steamapps/workshop/content/227300/2229578154 mounted.
00:00:05.006 : [fs] device F:/GRY/steamapps/workshop/content/227300/2229578154/latest mounted.
00:00:05.010 : [fs] device F:/GRY/steamapps/workshop/content/227300/1122486287 mounted.
00:00:05.017 : [zipfs] universal.zip: Created, 181 entries
00:00:05.017 : [fs] device F:/GRY/steamapps/workshop/content/227300/1122486287/universal.zip mounted.
00:00:05.018 : [zipfs] universal.zip: Unmounted
00:00:05.018 : [fs] device F:/GRY/steamapps/workshop/content/227300/2389970942 mounted.
00:00:05.064 : [zipfs] universal.zip: Created, 26390 entries
00:00:05.064 : [fs] device F:/GRY/steamapps/workshop/content/227300/2389970942/universal.zip mounted.
00:00:05.064 : [zipfs] universal.zip: Unmounted
00:00:05.064 : [fs] device F:/GRY/steamapps/workshop/content/227300/2392027171 mounted.
00:00:05.068 : [fs] device F:/GRY/steamapps/workshop/content/227300/2392027171/latest mounted.
00:00:05.073 : [fs] device F:/GRY/steamapps/workshop/content/227300/713338424 mounted.
00:00:05.074 : [fs] device F:/GRY/steamapps/workshop/content/227300/713338424/universal mounted.
00:00:05.078 : [fs] device F:/GRY/steamapps/workshop/content/227300/2466514780 mounted.
00:00:05.102 : [zipfs] 140_content.zip: Created, 8848 entries
00:00:05.102 : [fs] device F:/GRY/steamapps/workshop/content/227300/2466514780/140_content.zip mounted.
00:00:05.102 : [zipfs] 140_content.zip: Unmounted
00:00:05.103 : [fs] device F:/GRY/steamapps/workshop/content/227300/2466522174 mounted.
00:00:05.124 : [zipfs] 140_content.zip: Created, 7618 entries
00:00:05.124 : [fs] device F:/GRY/steamapps/workshop/content/227300/2466522174/140_content.zip mounted.
00:00:05.124 : [zipfs] 140_content.zip: Unmounted
00:00:05.125 : [fs] device F:/GRY/steamapps/workshop/content/227300/2402651339 mounted.
00:00:05.129 : [fs] device F:/GRY/steamapps/workshop/content/227300/2402651339/universal mounted.
00:00:05.133 : [fs] device F:/GRY/steamapps/workshop/content/227300/2386294767 mounted.
00:00:05.134 : [fs] device F:/GRY/steamapps/workshop/content/227300/2386294767/universal mounted.
00:00:05.138 : [fs] device F:/GRY/steamapps/workshop/content/227300/2417935800 mounted.
00:00:05.142 : [fs] device F:/GRY/steamapps/workshop/content/227300/2417935800/universal mounted.
00:00:05.147 : [fs] device F:/GRY/steamapps/workshop/content/227300/2470832575 mounted.
00:00:05.151 : [fs] device F:/GRY/steamapps/workshop/content/227300/2470832575/lightsaddscpack mounted.
00:00:05.155 : <WARNING> [mods] No valid categories defined for mod_workshop_package.000000009345E9BF. Setting defaults.
00:00:05.155 : [fs] device F:/GRY/steamapps/workshop/content/227300/1765159059 mounted.
00:00:05.156 : [fs] device F:/GRY/steamapps/workshop/content/227300/1765159059/universal mounted.
00:00:05.161 : [fs] device F:/GRY/steamapps/workshop/content/227300/2107281834 mounted.
00:00:05.169 : [zipfs] universal.zip: Created, 139 entries
00:00:05.169 : [fs] device F:/GRY/steamapps/workshop/content/227300/2107281834/universal.zip mounted.
00:00:05.170 : [zipfs] universal.zip: Unmounted
00:00:05.170 : [fs] device F:/GRY/steamapps/workshop/content/227300/1552985188 mounted.
00:00:05.184 : [zipfs] ets2_signs_on_your_trailer.zip: Created, 3825 entries
00:00:05.184 : [fs] device F:/GRY/steamapps/workshop/content/227300/1552985188/ets2_signs_on_your_trailer.zip mounted.
00:00:05.185 : [zipfs] ets2_signs_on_your_trailer.zip: Unmounted
00:00:05.185 : [fs] device F:/GRY/steamapps/workshop/content/227300/688277995 mounted.
00:00:05.197 : [zipfs] ets2_signs_on_your_truck.zip: Created, 5153 entries
00:00:05.197 : [fs] device F:/GRY/steamapps/workshop/content/227300/688277995/ets2_signs_on_your_truck.zip mounted.
00:00:05.197 : [zipfs] ets2_signs_on_your_truck.zip: Unmounted
00:00:05.198 : [fs] device F:/GRY/steamapps/workshop/content/227300/645553604 mounted.
00:00:05.270 : [zipfs] smp3_3_140.zip: Created, 36503 entries
00:00:05.270 : [fs] device F:/GRY/steamapps/workshop/content/227300/645553604/smp3_3_140.zip mounted.
00:00:05.270 : [zipfs] smp3_3_140.zip: Unmounted
00:00:05.270 : [fs] device F:/GRY/steamapps/workshop/content/227300/842257514 mounted.
00:00:05.289 : [zipfs] sisltrlmain140.zip: Created, 6550 entries
00:00:05.290 : [fs] device F:/GRY/steamapps/workshop/content/227300/842257514/sisltrlmain140.zip mounted.
00:00:05.290 : [zipfs] sisltrlmain140.zip: Unmounted
00:00:05.290 : [fs] device F:/GRY/steamapps/workshop/content/227300/2436047420 mounted.
00:00:05.298 : [zipfs] universal.zip: Created, 437 entries
00:00:05.298 : [fs] device F:/GRY/steamapps/workshop/content/227300/2436047420/universal.zip mounted.
00:00:05.298 : [zipfs] universal.zip: Unmounted
00:00:05.298 : [fs] device F:/GRY/steamapps/workshop/content/227300/2379937608 mounted.
00:00:05.303 : [fs] device F:/GRY/steamapps/workshop/content/227300/2379937608/140version mounted.
00:00:05.307 : [fs] device F:/GRY/steamapps/workshop/content/227300/2436703856 mounted.
00:00:05.311 : [fs] device F:/GRY/steamapps/workshop/content/227300/2436703856/universal mounted.
00:00:05.315 : [mod_package_manager] Received list of the steam workshop subscribed mods. (received 48 mods total, 48 loaded, 0 scheduled for download)
00:00:05.315 : dispatch
00:00:05.315 : exit
00:00:05.436 : [bullet] Starting physics server: Bullet
00:00:23.388 : mm_flush_repeatedly
00:00:23.389 : [zipfs] volga_model.scs: Unmounted
00:00:23.389 : [zipfs] volga_map.scs: Unmounted
00:00:23.389 : [zipfs] volga_def.scs: Unmounted
00:00:23.389 : [hashfs] Urban_Truck.scs: Unmounted.
00:00:23.389 : [hashfs] ULFIX140v2.scs: Unmounted.
00:00:23.389 : [zipfs] TurkeyRhodesFIXv2.scs: Unmounted
00:00:23.390 : [zipfs] trailers schmitz.scs: Unmounted
00:00:23.390 : [zipfs] trailers kogel.scs: Unmounted
00:00:23.390 : [hashfs] TML135ME255RC.scs: Unmounted.
00:00:23.390 : [zipfs] TM135LITE.scs: Unmounted
00:00:23.390 : [zipfs] The Great Steppe-model-v2.0.scs: Unmounted
00:00:23.390 : [zipfs] The Great Steppe-map-v2.0.scs: Unmounted
00:00:23.390 : [zipfs] The Great Steppe-def-v2.0.scs: Unmounted
00:00:23.391 : [zipfs] SZM_Addon_2v.scs: Unmounted
00:00:23.391 : [zipfs] SwedishIslandsMap_v1.10-Wombat.scs: Unmounted
00:00:23.391 : [zipfs] SuperZoomvPM135.scs: Unmounted
00:00:23.391 : [zipfs] SRmap__Hot_Fix__10.0.1.scs: Unmounted
00:00:23.391 : [zipfs] SRmap_[Model2].scs: Unmounted
00:00:23.391 : [zipfs] SRmap_[Model1].scs: Unmounted
00:00:23.391 : [zipfs] SRmap_[Def and Map].scs: Unmounted
00:00:23.391 : [zipfs] Skin_Edit_STARBUS_3_MODBUSARGVIP.scs: Unmounted
00:00:23.392 : [zipfs] sibirmap2.1.1.undersrm.scs: Unmounted
00:00:23.392 : [zipfs] sibirmap2.1.1.model.scs: Unmounted
00:00:23.392 : [zipfs] sibirmap2.1.1.mapdef.scs: Unmounted
00:00:23.392 : [zipfs] Scania_Touring__1.39_.scs: Unmounted
00:00:23.392 : [zipfs] Scania_S_Krone_Tandem_BIG_Pack.scs: Unmounted
00:00:23.392 : [zipfs] Scania_Door_Animation.scs: Unmounted
00:00:23.392 : [zipfs] RusMap-model_v2.4.1.scs: Unmounted
00:00:23.392 : [zipfs] RusMap-model2_v2.4.1.scs: Unmounted
00:00:23.392 : [zipfs] RusMap-map_v2.4.1.scs: Unmounted
00:00:23.392 : [zipfs] RusMap-def_v2.4.1.scs: Unmounted
00:00:23.392 : [zipfs] Route_Advisor_09.12.2019.scs: Unmounted
00:00:23.392 : [hashfs] ROEXprefab265.scs: Unmounted.
00:00:23.392 : [hashfs] ROEXdefmap265.scs: Unmounted.
00:00:23.392 : [hashfs] ROEXassets265.scs: Unmounted.
00:00:23.392 : [hashfs] ROEXallPM255RC.scs: Unmounted.
00:00:23.392 : [zipfs] ROEX2model265.scs: Unmounted
00:00:23.392 : [hashfs] ROEX295SR10RC.scs: Unmounted.
00:00:23.392 : [hashfs] ROEX265RusMap240RC.scs: Unmounted.
00:00:23.392 : [hashfs] ROEX265RusMap240RC (1).scs: Unmounted.
00:00:23.392 : [hashfs] ROEX1model265.scs: Unmounted.
00:00:23.392 : [zipfs] Rigid_Chassis_Addon_for_Eugene_Scania_NG_by_Kast.scs: Unmounted
00:00:23.392 : [zipfs] Rhodes_1.0.scs: Unmounted
00:00:23.392 : [zipfs] ReMoled Next Gen.zip: Unmounted
00:00:23.393 : [zipfs] RedseaV1-2-2.scs: Unmounted
00:00:23.393 : [zipfs] Realistic Brutal Weather Unforgiving V6.4 By Kass.scs: Unmounted
00:00:23.393 : [zipfs] real company logo.scs: Unmounted
00:00:23.393 : [hashfs] promods-model3-v255.scs: Unmounted.
00:00:23.393 : [hashfs] promods-model2-v255.scs: Unmounted.
00:00:23.393 : [hashfs] promods-model1-v255.scs: Unmounted.
00:00:23.393 : [hashfs] promods-media-v255.scs: Unmounted.
00:00:23.393 : [zipfs] promods-me-defmap-v255a.scs: Unmounted
00:00:23.393 : [hashfs] promods-me-assets-v255a.scs: Unmounted.
00:00:23.393 : [zipfs] promods-map-v255.scs: Unmounted
00:00:23.393 : [zipfs] promods-def-st-v255 (2).scs: Unmounted
00:00:23.393 : [hashfs] promods-assets-v255.scs: Unmounted.
00:00:23.393 : [zipfs] Project Greenland.scs: Unmounted
00:00:23.393 : [zipfs] Project Greenland - Promods Ferry.scs: Unmounted
00:00:23.393 : [zipfs] Project Balkans 5.1 - Map.scs: Unmounted
00:00:23.394 : [zipfs] Project Balkans 5.1 - Def.scs: Unmounted
00:00:23.394 : [zipfs] Project Balkans 5.1 - Assets.scs: Unmounted
00:00:23.394 : [zipfs] polonus.scs: Unmounted
00:00:23.394 : [zipfs] PM_RM_sign_fix.scs: Unmounted
00:00:23.394 : [zipfs] PM252_RM2.4.0_roadconnection.scs: Unmounted
00:00:23.394 : [zipfs] Piter_for_RusMap_2.4.0.scs: Unmounted
00:00:23.394 : [zipfs] paris_rebuild_v2_6.scs: Unmounted
00:00:23.394 : [zipfs] NEFAZ 8332.scs: Unmounted
00:00:23.394 : [zipfs] METALSUR_STARBUS_3_v3.4_MODBUSARGVIP_1.40.scs: Unmounted
00:00:23.394 : [zipfs] METALSUR_STARBUS_3_ACTIVADOR_MODBUSARGVIP_1.40.scs: Unmounted
00:00:23.394 : [zipfs] mercedes_sk.scs: Unmounted
00:00:23.394 : [zipfs] Mercedes Actros MP1 (unlock).scs: Unmounted
00:00:23.394 : [zipfs] Mercedes Actros MP1 (lock).scs: Unmounted
00:00:23.394 : [zipfs] MedMap_0.1_-_Def.scs: Unmounted
00:00:23.394 : [zipfs] MAPA_EAA_6-1_BASE.scs: Unmounted
00:00:23.394 : [zipfs] MAPA_EAA_6-1.scs: Unmounted
00:00:23.394 : [zipfs] Luxury Scania SR 2016 Interior – ETS2 1.39,1.40.scs: Unmounted
00:00:23.394 : [zipfs] LED_Trucklight_V1.40.scs: Unmounted
00:00:23.394 : [hashfs] latvia_rebuild-v127-for-pm_v252.scs: Unmounted.
00:00:23.394 : [zipfs] Kögel Old Paylaşım.scs: Unmounted
00:00:23.394 : [zipfs] KamAZ_NEFAZ_Dirt.scs: Unmounted
00:00:23.394 : [zipfs] KamAZ 54-64-65.scs: Unmounted
00:00:23.394 : [zipfs] interior_addons_v1.1.scs: Unmounted
00:00:23.394 : [zipfs] interior_addon_v1.0.scs: Unmounted
00:00:23.394 : [zipfs] Improved_SCS_Rain_v0.1_for_1.40.scs: Unmounted
00:00:23.394 : [hashfs] G6 DD 8x2-v4.scs: Unmounted.
00:00:23.395 : [hashfs] G6 DD 8x2-v4 - PE -42.scs: Unmounted.
00:00:23.395 : [zipfs] finnmark_exp1617019615.scs: Unmounted
00:00:23.395 : [zipfs] ets2_signs_on_your_truck.scs: Unmounted
00:00:23.395 : [zipfs] ETS2_LAMB_EU-AF-AS-OC_SAT_BG.scs: Unmounted
00:00:23.395 : [zipfs] ENROEX.scs: Unmounted
00:00:23.395 : [zipfs] Ekeri_full_trailer_addon_by_Kast.scs: Unmounted
00:00:23.395 : [zipfs] EAA_6.1_RUSMAP_2.4.0_FIX.scs: Unmounted
00:00:23.395 : [zipfs] EAA_6.1_Promods_2.55_FIX.scs: Unmounted
00:00:23.395 : [zipfs] EAA6.1CAPSFIX.scs: Unmounted
00:00:23.395 : [zipfs] DSV_Transport.scs: Unmounted
00:00:23.395 : [zipfs] DSV_Tandem_v1.2___REWORK__.scs: Unmounted
00:00:23.395 : [zipfs] Dark_brown_Interior_scania_s_0.8_beta.scs: Unmounted
00:00:23.395 : [zipfs] daf_ntt_cabin_accessories.zip: Unmounted
00:00:23.395 : [zipfs] daf_ntt.scs: Unmounted
00:00:23.395 : [zipfs] daf_95_ati_tuning.scs: Unmounted
00:00:23.395 : [zipfs] daf_95_ati_cabin_accessories.scs: Unmounted
00:00:23.395 : [zipfs] daf_95_ati_bdf_trailer.scs: Unmounted
00:00:23.395 : [zipfs] daf_95_ati.scs: Unmounted
00:00:23.395 : [zipfs] CustomKogelTrailerv2.scs: Unmounted
00:00:23.395 : [zipfs] CRASHFIX_HUGE_COMBOS.scs: Unmounted
00:00:23.395 : [zipfs] Brutal Traffic V1.3 By Kass.scs: Unmounted
00:00:23.395 : [zipfs] Arnooks SCS Container Skinpack V8.scs: Unmounted
00:00:23.395 : [zipfs] All_Volvo_Trucks_Door_Animation_Mod.scs: Unmounted
00:00:23.395 : [zipfs] AfroMap.scs: Unmounted
00:00:23.395 : [zipfs] Abrir_Portas_Scania.scs: Unmounted
00:00:23.396 : [zipfs] 50k_addons_1_40.scs: Unmounted
00:00:23.396 : [zipfs] 2Macedonia_rework_mat&asset.scs: Unmounted
00:00:23.396 : [zipfs] 2Macedonia_rework_map.scs: Unmounted
00:00:23.396 : [zipfs] 2Macedonia_rework_def_st.scs: Unmounted
00:00:23.396 : [zipfs] 2Macedonia_rework_def.scs: Unmounted
00:00:23.406 : [fs] device dlc_actros_tuning.scs mounted.
00:00:23.406 : [fs] device dlc_balkan_e.scs mounted.
00:00:23.406 : [fs] device dlc_balt.scs mounted.
00:00:23.407 : [fs] device dlc_east.scs mounted.
00:00:23.407 : [fs] device dlc_flags_pl.scs mounted.
00:00:23.407 : [fs] device dlc_fr.scs mounted.
00:00:23.407 : [fs] device dlc_goodyear.scs mounted.
00:00:23.407 : [fs] device dlc_heavy_cargo.scs mounted.
00:00:23.407 : [fs] device dlc_hs_schoch.scs mounted.
00:00:23.407 : [fs] device dlc_iberia.scs mounted.
00:00:23.407 : [fs] device dlc_it.scs mounted.
00:00:23.407 : [fs] device dlc_krone.scs mounted.
00:00:23.407 : [fs] device dlc_metallics.scs mounted.
00:00:23.407 : [fs] device dlc_michelin.scs mounted.
00:00:23.407 : [fs] device dlc_mighty_griffin.scs mounted.
00:00:23.408 : [fs] device dlc_north.scs mounted.
00:00:23.408 : [fs] device dlc_oversize.scs mounted.
00:00:23.408 : [fs] device dlc_phys_flags.scs mounted.
00:00:23.408 : [fs] device dlc_prehistoric.scs mounted.
00:00:23.408 : [fs] device dlc_rims.scs mounted.
00:00:23.408 : [fs] device dlc_rocket_league.scs mounted.
00:00:23.408 : [fs] device dlc_schwarzmuller.scs mounted.
00:00:23.408 : [fs] device dlc_toys.scs mounted.
00:00:23.408 : [fs] device dlc_trailers.scs mounted.
00:00:23.408 : [fs] device dlc_vikings.scs mounted.
00:00:23.408 : [fs] device dlc_volvo_tuning_pack.scs mounted.
00:00:23.454 : uset s_voiceover_mute "0"
00:00:23.454 : uset s_intro_music_mute "0"
00:00:23.455 : uset s_ui_music_mute "1"
00:00:23.455 : uset s_ui_mute "0"
00:00:23.455 : uset s_navigation_mute "0"
00:00:23.455 : uset s_music_mute "1"
00:00:23.455 : uset s_radio_mute "0"
00:00:23.455 : uset s_interior_mute "0"
00:00:23.455 : uset s_ambient_mute "0"
00:00:23.455 : uset s_world_mute "0"
00:00:23.455 : uset s_traffic_mute "0"
00:00:23.455 : uset s_trailer_mute "0"
00:00:23.455 : uset s_truck_noise_mute "0"
00:00:23.456 : uset s_truck_effects_mute "0"
00:00:23.456 : uset s_truck_turbo_mute "0"
00:00:23.456 : uset s_truck_exhaust_mute "0"
00:00:23.456 : uset s_truck_engine_mute "0"
00:00:23.456 : uset s_master_mute "0"
00:00:23.456 : uset s_voiceover_volume "0.5"
00:00:23.456 : uset s_intro_music_volume "0.5"
00:00:23.456 : uset s_ui_music_volume "0.02"
00:00:23.456 : uset s_ui_volume "0.49"
00:00:23.456 : uset s_navigation_volume "0.41"
00:00:23.456 : uset s_music_volume "0"
00:00:23.456 : uset s_radio_volume "0.17"
00:00:23.456 : uset s_interior_volume "0.49"
00:00:23.456 : uset s_ambient_volume "0.5"
00:00:23.456 : uset s_world_volume "0.5"
00:00:23.456 : uset s_traffic_volume "0.58"
00:00:23.456 : uset s_trailer_volume "0.47"
00:00:23.456 : uset s_truck_noise_volume "0.53"
00:00:23.456 : uset s_truck_effects_volume "0.51"
00:00:23.456 : uset s_truck_turbo_volume "0.59"
00:00:23.456 : uset s_truck_exhaust_volume "0.5"
00:00:23.456 : uset s_truck_engine_volume "0.5"
00:00:23.456 : uset s_master_volume "0.52"
00:00:23.456 : uset i_oculus_eye_protrusion "0.09"
00:00:23.456 : uset i_oculus_eye_height "0.15"
00:00:23.456 : uset i_hmd_max_prediction "0.1"
00:00:23.456 : uset i_hmd_min_prediction "0.0"
00:00:23.456 : uset r_interior "1"
00:00:23.456 : uset r_steering_wheel "1"
00:00:23.456 : uset g_eye_preset_5 ""
00:00:23.456 : uset g_eye_preset_4 ""
00:00:23.456 : uset g_eye_preset_3 ""
00:00:23.456 : uset g_eye_preset_2 ""
00:00:23.456 : uset g_eye_preset_1 ""
00:00:23.456 : uset g_eye_enable "0"
00:00:23.456 : uset g_cam_window_block "0.0"
00:00:23.456 : uset g_toy_physics "1"
00:00:23.456 : uset g_cam_steering_reverse "1.0"
00:00:23.456 : uset g_cam_steering_value "1.0"
00:00:23.456 : uset g_cam_steering "1"
00:00:23.457 : uset g_pedal_clutch_range "1.0"
00:00:23.457 : uset g_brake_intensity "2.2056"
00:00:23.457 : uset g_steer_autocenter "1"
00:00:23.457 : uset g_clutch_brake "0"
00:00:23.457 : uset g_hshifter_synchronized "1"
00:00:23.457 : uset g_hshifter_split "3"
00:00:23.457 : uset g_hshifter_layout_shifting "1"
00:00:23.457 : uset g_hshifter_layout "splitter"
00:00:23.457 : uset g_trans "3"
00:00:23.457 : uset g_baked_vehicle "1"
00:00:23.457 : uset g_force_economy_reset "0"
00:00:23.457 : uset g_input_configured "1"
00:00:23.458 : uset s_reverb_world "1"
00:00:23.458 : uset s_reverb_cabin "1"
00:00:23.458 : uset s_noise_aero "1"
00:00:23.458 : uset s_noise_windows "1"
00:00:23.458 : uset s_rumble_enabled "1"
00:00:23.458 : uset s_reverse_enabled "1"
00:00:23.458 : uset g_disable_beacons "0"
00:00:23.458 : uset g_show_game_elements "1"
00:00:23.458 : uset g_hmd_no_3d_background "0"
00:00:23.458 : uset g_hmd_no_special_menu "0"
00:00:23.458 : uset g_hmd_reduced_cabin_movement "1"
00:00:23.458 : uset g_hmd_no_artifical_movement "0"
00:00:23.458 : uset g_eye_pause_gaze "3000"
00:00:23.458 : uset g_eye_pause "0"
00:00:23.458 : uset g_cam_blinker "0"
00:00:23.458 : uset g_cam_physics_value "1.0"
00:00:23.458 : uset g_cam_physics "1"
00:00:23.458 : uset g_blinker_auto_off "1"
00:00:23.458 : uset g_cruise_control_smart "5.0"
00:00:23.458 : uset g_cruise_control_grid "5.0"
00:00:23.458 : uset g_adaptive_shift "0.0"
00:00:23.458 : uset g_fuel_simulation "0"
00:00:23.458 : uset g_hardcore_simulation "0"
00:00:23.458 : uset g_reg_setting ""
00:00:23.458 : uset g_brake_light_all "0"
00:00:23.458 : uset g_use_speed_limiter "1"
00:00:23.458 : uset g_hud_speed_warning "0"
00:00:23.458 : uset g_hud_speed_limit "1"
00:00:23.459 : uset g_axle_drop_auto "1"
00:00:23.459 : uset g_engine_start_auto "1"
00:00:23.459 : uset g_motor_brake_auto "0"
00:00:23.459 : uset g_retarder_auto "0"
00:00:23.459 : uset g_cabin_suspension_stiffness "1.0"
00:00:23.459 : uset g_suspension_stiffness "1.0"
00:00:23.459 : uset g_trailer_stability "0.5"
00:00:23.459 : uset g_truck_stability "0.5"
00:00:23.459 : uset g_mpg "0"
00:00:23.459 : uset g_gallon "0"
00:00:23.459 : uset g_fahrenheit "0"
00:00:23.459 : uset g_pounds "kg"
00:00:23.459 : uset g_mph "0"
00:00:23.459 : uset g_road_events "1.0"
00:00:23.459 : uset g_detours "1.0"
00:00:23.459 : uset g_name_localization_secondary "0"
00:00:23.459 : uset g_name_localization "1"
00:00:23.459 : uset g_lang_set "1"
00:00:23.459 : uset g_lang "pl_pl"
00:00:23.459 : uset g_cutscenes "1"
00:00:23.459 : uset g_phys_mirrors "0"
00:00:23.459 : uset g_world_map_zoom "4"
00:00:23.459 : uset g_cargo_load_require_park_brake "0"
00:00:23.459 : uset g_cargo_load_require_engine_off "1"
00:00:23.459 : uset g_show_always_wotr_event "0"
00:00:23.459 : uset g_last_wotr_event_start "0"
00:00:23.459 : uset g_force_load_selector "0"
00:00:23.459 : uset g_autoload_ignore_autosave "0"
00:00:23.459 : uset g_start_in_truck "0"
00:00:23.459 : uset g_park_brake_init "0"
00:00:23.459 : uset g_trailer_advanced_coupling "0"
00:00:23.459 : uset g_parking_difficulty "0"
00:00:23.459 : uset g_simple_parking_doubles "1"
00:00:23.459 : uset g_speed_warning "0"
00:00:23.459 : uset g_voice_navigation_pack "polish_eryk"
00:00:23.460 : uset g_voice_navigation "1"
00:00:23.460 : uset g_job_distance "1.0"
00:00:23.460 : uset g_job_distance_limit "-1.0"
00:00:23.460 : uset g_income_factor "1.0"
00:00:23.460 : uset g_currency "4"
00:00:23.460 : uset g_bad_weather_factor "0.07"
00:00:23.460 : uset g_truck_analysis_fold "0"
00:00:23.460 : uset g_desktop_rnd "0"
00:00:23.460 : uset g_desktop_bcg "config"
00:00:23.460 : uset g_save_idx "1"
00:00:23.460 : uset g_ui_map_align "1"
00:00:23.460 : uset g_gps_routing_mode "0"
00:00:23.460 : uset g_gps_navigation "3"
00:00:23.460 : uset g_heavy_cargo_popup "1"
00:00:23.460 : uset g_mirrors "1"
00:00:23.460 : uset g_adviser_eta "1"
00:00:23.460 : uset g_adviser_running_message "1"
00:00:23.460 : uset g_adviser_auto_parking "1"
00:00:23.460 : uset g_adviser_keep_hidden "0"
00:00:23.460 : uset g_adviser "0"
00:00:23.460 : uset g_desktop_tutorial "1"
00:00:23.460 : uset g_tutorial "1"
00:00:23.460 : uset g_fatigue "0"
00:00:23.460 : uset g_time_zones "0"
00:00:23.460 : uset g_police "0"
00:00:23.460 : uset g_subtitles "0"
00:00:23.460 : uset g_clock_24 "1"
00:00:23.462 : uset s_voiceover_mute "0"
00:00:23.462 : uset s_intro_music_mute "0"
00:00:23.462 : uset s_ui_music_mute "1"
00:00:23.462 : uset s_ui_mute "0"
00:00:23.462 : uset s_navigation_mute "0"
00:00:23.462 : uset s_music_mute "1"
00:00:23.462 : uset s_radio_mute "0"
00:00:23.462 : uset s_interior_mute "0"
00:00:23.462 : uset s_ambient_mute "0"
00:00:23.462 : uset s_world_mute "0"
00:00:23.462 : uset s_traffic_mute "0"
00:00:23.462 : uset s_trailer_mute "0"
00:00:23.462 : uset s_truck_noise_mute "0"
00:00:23.462 : uset s_truck_effects_mute "0"
00:00:23.462 : uset s_truck_turbo_mute "0"
00:00:23.462 : uset s_truck_exhaust_mute "0"
00:00:23.462 : uset s_truck_engine_mute "0"
00:00:23.462 : uset s_master_mute "0"
00:00:23.462 : uset s_voiceover_volume "0.5"
00:00:23.462 : uset s_intro_music_volume "0.5"
00:00:23.462 : uset s_ui_music_volume "0.02"
00:00:23.462 : uset s_ui_volume "0.49"
00:00:23.462 : uset s_navigation_volume "0.41"
00:00:23.462 : uset s_music_volume "0"
00:00:23.462 : uset s_radio_volume "0.17"
00:00:23.462 : uset s_interior_volume "0.49"
00:00:23.462 : uset s_ambient_volume "0.5"
00:00:23.462 : uset s_world_volume "0.5"
00:00:23.462 : uset s_traffic_volume "0.58"
00:00:23.462 : uset s_trailer_volume "0.47"
00:00:23.462 : uset s_truck_noise_volume "0.53"
00:00:23.463 : uset s_truck_effects_volume "0.51"
00:00:23.463 : uset s_truck_turbo_volume "0.59"
00:00:23.463 : uset s_truck_exhaust_volume "0.5"
00:00:23.463 : uset s_truck_engine_volume "0.5"
00:00:23.463 : uset s_master_volume "0.52"
00:00:23.463 : uset i_oculus_eye_protrusion "0.09"
00:00:23.463 : uset i_oculus_eye_height "0.15"
00:00:23.463 : uset i_hmd_max_prediction "0.1"
00:00:23.463 : uset i_hmd_min_prediction "0.0"
00:00:23.463 : uset r_interior "1"
00:00:23.463 : uset r_steering_wheel "1"
00:00:23.463 : uset g_eye_preset_5 ""
00:00:23.463 : uset g_eye_preset_4 ""
00:00:23.463 : uset g_eye_preset_3 ""
00:00:23.463 : uset g_eye_preset_2 ""
00:00:23.463 : uset g_eye_preset_1 ""
00:00:23.463 : uset g_eye_enable "0"
00:00:23.463 : uset g_cam_window_block "0.0"
00:00:23.463 : uset g_toy_physics "1"
00:00:23.463 : uset g_cam_steering_reverse "1.0"
00:00:23.463 : uset g_cam_steering_value "1.0"
00:00:23.463 : uset g_cam_steering "1"
00:00:23.463 : uset g_pedal_clutch_range "1.0"
00:00:23.463 : uset g_brake_intensity "2.2056"
00:00:23.463 : uset g_steer_autocenter "1"
00:00:23.463 : uset g_clutch_brake "0"
00:00:23.463 : uset g_hshifter_synchronized "1"
00:00:23.463 : uset g_hshifter_split "3"
00:00:23.463 : uset g_hshifter_layout_shifting "1"
00:00:23.463 : uset g_hshifter_layout "splitter"
00:00:23.463 : uset g_trans "3"
00:00:23.463 : uset g_baked_vehicle "1"
00:00:23.463 : uset g_force_economy_reset "0"
00:00:23.463 : uset g_input_configured "1"
00:00:23.464 : uset s_reverb_world "1"
00:00:23.464 : uset s_reverb_cabin "1"
00:00:23.464 : uset s_noise_aero "1"
00:00:23.464 : uset s_noise_windows "1"
00:00:23.464 : uset s_rumble_enabled "1"
00:00:23.464 : uset s_reverse_enabled "1"
00:00:23.464 : uset g_disable_beacons "0"
00:00:23.464 : uset g_show_game_elements "1"
00:00:23.464 : uset g_hmd_no_3d_background "0"
00:00:23.464 : uset g_hmd_no_special_menu "0"
00:00:23.464 : uset g_hmd_reduced_cabin_movement "1"
00:00:23.464 : uset g_hmd_no_artifical_movement "0"
00:00:23.464 : uset g_eye_pause_gaze "3000"
00:00:23.464 : uset g_eye_pause "0"
00:00:23.464 : uset g_cam_blinker "0"
00:00:23.465 : uset g_cam_physics_
(Ten post był ostatnio modyfikowany: 08/05/2021 01:02 PM przez Marhen.)
08/05/2021 01:01 PM
Marhen Offline
Liczba postów: 4
RE: Error w game log Ets2
Ok sprawdziłem, że za error odpowiada ktoraś mapa, zostawiłem tylko ulubione promods i rusmap. lekko sie przycina czasem i mam w game logu takie coś Insufficient buffer size when generating '' icon. Nie mama pojecia o jaki bufor chodzi i o jaka ikone.
08/05/2021 02:30 PM
superpiotr4 Offline
Liczba postów: 414
Reputacja: 19
Podziękował: 303
Podziękowano mu 422 raz(y)
(08/05/2021 02:30 PM)Marhen napisał(a):  Ok sprawdziłem, że za error odpowiada ktoraś mapa, zostawiłem tylko ulubione promods i rusmap. lekko sie przycina czasem i mam w game logu takie coś Insufficient buffer size when generating '' icon. Nie mama pojecia o jaki bufor chodzi i o jaka ikone.
Trochę się nie udzielałem, ale widzę, że częściowo sobie poradziłeś. Nie wiem, czy już się uporałeś z problemem, czy nie, ale być może to jest jeszcze jakiś mod na tuning. Spróbuj wszystkie wywalić i włączaj po kolei.
Dzień 24 lutego 2022 r na zawsze wpisze się w kartę XXI wieku. Rosjanie zaatakowali o wiele mniejsze państwo, tylko dlatego, że chcieli należeć do dzisiejszej Europy! Podczas, gdy my klepiemy się po pełnych brzuchach, Ukraińcy wiążą koniec z końcem. Nie maja dostępu do bieżącej wody, prądu, a nawet żywności. Nie pozwólmy na to, aby biedny naród musiał cierpieć, przez ambicje PutinaWykrzyknik
Ty też możesz pomagać. Wystarczy, że za symboliczne 3,59 złotych zakupisz DLC Ukrainian Paint Jobs Dochody w 100% zostaną przekazane fundacji People in Need zaangażowanej na rzecz Wschodu! Nie czekaj! Pomóż im już dzisiaj!
Pomożesz, bo możesz. Masz to w genach Smile
21/06/2021 11:39 AM
  Crash gry wywala mi ets 2 przesylam game log PawelSiedlce 4 1,375 22/02/2021 09:15 AM
Ostatni post: Nicko
  Wersja 1.36 fatal error tomber90 7 2,916 08/12/2019 04:35 PM
Ostatni post: RadolSzczecin
  Fatal error Ets 2 1.35 melonik-74 10 3,318 15/07/2019 11:17 AM
Ostatni post: melonik-74
Brick ERROR gry lulok7 4 2,402 11/12/2018 08:05 PM
Ostatni post: Tedy
  ERROR gry ferNDawid 2 2,085 10/12/2018 12:04 PM
Ostatni post: ferNDawid
