Problem z matami...
FarmerGamer Offline
Farmerrro :D
Liczba postów: 108
Reputacja: 14
Podziękował: 90
Podziękowano mu 116 raz(y)
Problem z matami...
Cześć wam. Około 5 miesięcy temu jeszcze umiałem dość dobrze zmoda no powiedzmy, ale teraz sporo pozapominałem i jak exportuję do gry trucka to wywala mi maty chociaż ich nie ruszałem w ogóle. Dla czego tak jest? Wycinek z loga gry:
Cytat: <WARNING> [resource_task] Default temporary buffer is insufficient while reading '/vehicle/truck/volvo_fh16_2012/truck.pmg' with size 37232160
00:01:40.575 : <WARNING> Model in old format detected '/vehicle/truck/volvo_fh16_2012/truck.pmg', please upgrade format to improve load performance!
00:01:40.708 : <ERROR> [fs] Failed to open file "/vehicle/truck/volvo_fh16_2012/chrom2.dif.spec.add.env.mat" in the read_only mode
00:01:40.708 : <ERROR> [fs] Failed to open file "/vehicle/truck/volvo_fh16_2012/color.dif.spec.add.mat" in the read_only mode
00:01:40.708 : <ERROR> [resource_task] Can not open '/vehicle/truck/volvo_fh16_2012/color.dif.spec.add.mat'
00:01:40.708 : <ERROR> [resource_task] Can not open '/vehicle/truck/volvo_fh16_2012/chrom2.dif.spec.add.env.mat'
00:01:40.708 : <ERROR> [fs] Failed to open file "/vehicle/truck/volvo_fh16_2012/chrom.dif.spec.add.env.mat" in the read_only mode
00:01:40.708 : <ERROR> [resource_task] Can not open '/vehicle/truck/volvo_fh16_2012/chrom.dif.spec.add.env.mat'
00:01:40.708 : <ERROR> [fs] Failed to open file "/vehicle/truck/volvo_fh16_2012/lpl.dif.spec.add.mat" in the read_only mode
00:01:40.708 : <ERROR> [resource_task] Can not open '/vehicle/truck/volvo_fh16_2012/lpl.dif.spec.add.mat'
00:01:40.709 : <ERROR> [fs] Failed to open file "/vehicle/truck/volvo_fh16_2012/czesci3.dif.mat" in the read_only mode
00:01:40.709 : <ERROR> [resource_task] Can not open '/vehicle/truck/volvo_fh16_2012/czesci3.dif.mat'
00:01:40.709 : <ERROR> [fs] Failed to open file "/vehicle/truck/volvo_fh16_2012/truck.dif.mat" in the read_only mode
00:01:40.709 : <ERROR> [resource_task] Can not open '/vehicle/truck/volvo_fh16_2012/truck.dif.mat'
00:01:40.709 : <ERROR> [fs] Failed to open file "/vehicle/truck/volvo_fh16_2012/baki.dif.spec.add.env.mat" in the read_only mode
00:01:40.709 : <ERROR> [resource_task] Can not open '/vehicle/truck/volvo_fh16_2012/baki.dif.spec.add.env.mat'
00:01:40.730 : <ERROR> [fs] Failed to open file "/vehicle/truck/volvo_fh16_2012/pl nl.tobj" in the read_only mode
00:01:40.730 : <ERROR> [tobj] Can not open '/vehicle/truck/volvo_fh16_2012/pl nl.tobj'
00:01:41.769 : <ERROR> [fs] Failed to open file "/vehicle/truck/volvo_fh16_2009/glass.dds" in the read_only mode
00:01:41.769 : <ERROR> [resource_task] Can not open '/vehicle/truck/volvo_fh16_2009/glass.dds'
00:01:41.776 : <ERROR> [dds] Malformed DDS file '/vehicle/truck/volvo_fh16_2009/glass.dds'
00:01:42.033 : <WARNING> Model in old format detected '/vehicle/truck/volvo_fh16_2012/wipers.pmg', please upgrade format to improve load performance!
00:01:42.033 : <ERROR> [fs] Failed to open file "/vehicle/truck/volvo_fh16_2012/Default Material.Default Material.mat" in the read_only mode
00:01:42.033 : <ERROR> [resource_task] Can not open '/vehicle/truck/volvo_fh16_2012/Default Material.Default Material.mat'
00:01:42.069 : <WARNING> Model in old format detected '/vehicle/truck/upgrade/mirror/volvo_fh16_2012/mirror_03.pmg', please upgrade format to improve load performance!
00:01:42.069 : <WARNING> Model in old format detected '/vehicle/truck/upgrade/mirror/volvo_fh16_2012/front_mirror_01.pmg', please upgrade format to improve load performance!
00:01:42.070 : <ERROR> [fs] Failed to open file "/vehicle/truck/volvo_fh16_2009/bodypaint01.tobj" in the read_only mode
00:01:42.070 : <WARNING> Model in old format detected '/vehicle/truck/upgrade/mirror/volvo_fh16_2012/side_mirror_01.pmg', please upgrade format to improve load performance!
00:01:44.618 : <WARNING> Model in old format detected '/vehicle/truck/upgrade/sunshield/volvo_fh16_2012/sunshield_01.pmg', please upgrade format to improve load performance!
00:01:47.029 : <ERROR> [fs] Failed to open file "/vehicle/truck/volvo_fh16_2009/glass.dds" in the read_only mode
00:01:47.031 : <ERROR> [dds] Can not load '/vehicle/truck/volvo_fh16_2009/glass.dds'
00:02:03.956 : Incompatible save game loaded.
00:02:15.156 : Nothing to activate
00:03:02.932 : <WARNING> [resource_task] Default temporary buffer is insufficient while reading '/vehicle/truck/volvo_fh16_2012/truck.pmg' with size 37232160
00:03:03.409 : <WARNING> Model in old format detected '/vehicle/truck/volvo_fh16_2012/truck.pmg', please upgrade format to improve load performance!
00:03:03.481 : <WARNING> Model in old format detected '/vehicle/truck/volvo_fh16_2012/wipers.pmg', please upgrade format to improve load performance!
00:03:03.496 : <WARNING> Model in old format detected '/vehicle/truck/upgrade/mirror/volvo_fh16_2012/mirror_03.pmg', please upgrade format to improve load performance!
00:03:03.512 : <WARNING> Model in old format detected '/vehicle/truck/upgrade/mirror/volvo_fh16_2012/front_mirror_01.pmg', please upgrade format to improve load performance!
00:03:03.521 : <WARNING> Model in old format detected '/vehicle/truck/upgrade/mirror/volvo_fh16_2012/side_mirror_01.pmg', please upgrade format to improve load performance!
Help Big Grin
Szerokości!
(Ten post był ostatnio modyfikowany: 19/06/2015 04:27 PM przez FarmerGamer.)
19/06/2015 04:26 PM
Skipper Offline
Mistrz
Liczba postów: 190
Reputacja: 32
Podziękował: 48
Podziękowano mu 57 raz(y)
RE: Problem z matami...
po każdym eksporcie maty trza przerabiać na te etsowskie + tobj kownenterem
04/10/2015 06:41 PM
Zwierzak Offline
V.I.P
Liczba postów: 267
Reputacja: 10
Podziękował: 60
Podziękowano mu 167 raz(y)
Old format..... to znaczy że jest za stary. wiem bo tak samo miałem z naczepą schmitz.
(Ten post był ostatnio modyfikowany: 04/10/2015 06:45 PM przez Zwierzak.)
04/10/2015 06:43 PM
Skipper Offline
Mistrz
Liczba postów: 190
Reputacja: 32
Podziękował: 48
(04/10/2015 06:43 PM)zwierzak napisał(a):  Old format..... to znaczy że jest za stary. wiem bo tak samo miałem z naczepą schmitz.
Nie wiesz, nie mów...Maty są zrobione do gts a nie ets2...
04/10/2015 06:47 PM
  Problem z matami jakjapowojaku111 2 1,121 29/07/2018 08:35 PM
Ostatni post: jakjapowojaku111
  Problem z matami !? .:Subarynek:. 4 2,027 23/02/2016 01:21 PM
Ostatni post: Michal_Z_gno
  Pomoc Z Matami Rośniak 6 3,002 21/01/2016 08:51 PM
Ostatni post: kuba10105
  Pomoc z matami. FarmerGamer 1 2,196 04/10/2015 06:45 PM
Ostatni post: Skipper
  Problem z Matami Rafik12 8 3,373 23/08/2014 07:58 PM
Ostatni post: Rafik12
