Improved Truck Physics Mod v 1.4
Liczba postów: 15,100
Reputacja: 640
Podziękował: 34110
Podziękowano mu 15554 raz(y)
Jest to fizyka jazdy do ETS2
Cytat:– Mod adds more realistic and hard physics for ETS2 trucks;
– It is now more difficult to drive a truck, “feel” of the truck is increased;
– Changed driver body movement physics, which is now much less static;
– Lots of changes was made in truck behavior:
1. Decreased responistivity of truck. Increased air and wheel rotation resistance. Higher chance to tip over during high speed maneuvers;
2. Decreased brake effectiviness. Brakes now have more realistic warm up/cool down rates and proper max. temp;
3. Tweaked cabin movement behavior to be more responsive to truck maneuvers. Adjusted cabin weight to realistic value, redefined pitch and roll angles, damping and springing forces;
4. Changed suspension travel value and damping factor. Suspension is softer now;
5. Decreased clutch viscosity;
6. Decreased tire material friction and increased tires deformation parameters. Tires now have less friction with road and more prone to slipping.
Supported trucks (IMPORTANT!):
Mod supports all vanilla trucks and some of popular modded trucks:
DAF XF by 50k, Volvo FH Classic and FH16 2013 by Ohaha, SISU and all Scanias from RJL, Volvo VNL 670 and 780, MAN TGX Euro6 and TGA by Madster, Scania 143 by Ekualizer and Iveco Strator by Shoofer/EM Group, Scania P/G by GT-Mike, Kenworth T800/W900, Freightliner Classic XL/Argosy, Mack Superliner, MAZ 5432, KAMAZ 53212, Ural 43202. To use this mod with these modded trucks, install it with higher priorityWykrzyknik
If you have some other not listed above truck mods, install them with higher priority, than this physics mod!
Installation instructions:
1.Extract scs file from downloaded archive to mod folder of ETS2;
2.Open in-game mod manager and enable “Improved truck physics” mod;
3.Play!
-25.01.16 Version 1.2
Changelog:
Added full support for Scania P/G by GT-Mike, Kenworth T800/W900, Freightliner Classic XL/Argosy, Mack Superliner, MAZ 5432, KAMAZ 53212, Ural 43202.
Increased driver pitch forward/backward angle;
Decreased driver centrifugal compensation movement;
Decreased suspension travel for all trucks;
Increased max. steering sensivity;
Added small fifth wheel roll angle;
Increased overall brakes strength a bit;
Decreased cabin pitch forward angle and increased pitch backward angle;
Increased front wheel brakes strength;
Reworked cabin pitch/roll damping/springing factors;
Wheel mass increased;
Heavily reduced sway bar stiffness;
Wheel suspension damping strength increased;
Increased longitudinal stiffness of tyre material.
Credits:
AlexeyP
Info:
Autor: AlexeyP
Wersja gry: 1.22.x
(Ten post był ostatnio modyfikowany: 18/02/2016 01:20 PM przez Ania.)
19/01/2016 12:05 AM
MAD MAX Offline
F U R Y - R O A D
Liczba postów: 4,178
Reputacja: 195
Podziękował: 2204
Podziękowano mu 2840 raz(y)
RE: Improved Truck Physics Mod v 1.2
Aktualizacja w pierwszym poście.
Wykrzyknik Wykrzyknik
26/01/2016 03:20 PM
Ania Offline
Liczba postów: 4,675
Reputacja: 177
Podziękował: 2782
Podziękowano mu 5207 raz(y)
RE: Improved Truck Physics Mod v 1.4
#Aktualizacja modu w pierwszym poście do wersjy 1.4
18/02/2016 01:20 PM
  Flexible Truck Physics v1.1 Michal_Z_gno 1 1,902 13/01/2023 02:28 PM
Ostatni post: Luki
  TRUCK PHYSICS BY ALEX KAZAK | REL v 0.2.5.3 Altair 0 2,067 06/06/2020 08:56 AM
Ostatni post: Altair
  [ETS2] Truck and Cabin Physics v 1.6 Soft version (for 1.34) Ania 0 1,588 15/02/2019 10:48 AM
Ostatni post: Ania
  [ETS2] Truck and Cabin Physics v 1.6 Hard version (for 1.34) Ania 0 1,262 15/02/2019 08:33 AM
Ostatni post: Ania
  [ETS2] TT Truck and Driver Physics v 1.3 Hard Ania 0 1,254 31/10/2018 08:00 PM
Ostatni post: Ania
