Romanian Map v8.9 (1.26.x) for ETS 2
DjMrCoolkat
Thumbs Up Romanian Map v8.9 (1.26.x) for ETS 2
Romania map require trailer mod to be activated.
At Romanian map, if tha map it is not activated, you must create a new profile, and, at game mod, select romania.mdb : D
Sesons mods must have higher priority than map.
Some traffic vehicle have specific sound engine.
Hired driver number is increased to 494
Drivers names are Romanian.
Added new models or edited old ones.
You can have automatic season changer in game. Details in Season_changer.zip file
If you want only a specific season mod, extract it from Season Changer.zip file to mod folder and activate-it !
Increased traction in winter, and , from now, you don't have anymore, snow in tunnels !
Crossroads and prefabs, in winter, behave like roads.
Reworked many models, some new, correction on map, and fixed crashes on beta's due to wheels on trucks and trailers.
Important ! Due to compatibility with dlc to start a new profile must select the game mode<<romania.mdb >> otherwise you will not have the map .
Check if the game mode selected appears <<romania.mdb >> If not, you have to start a new profile.
Since present several new models , it is recommended PC memory as much . For those who have not , reduce the resolution and / or graphic details to avoid memory problems .
To use the additional traffic mode , depending on resolution and graphic details , it is necessary to have at least 8 GB RAM installed in the system.
Tested on game version 1.26.x
Changes in 8.9
- map adapted for ETs 2 V 1.26
- added more Romanian vehicle.
- reworked traffic lights (Note: Yet I don't have success to add pedestrian lights).
- some coutry cross roads now have traffic lights (in order to avoid traffic jams).
- corrected some models, prefab and maps issue.
- added coinsurance for repairs (thanks PIVA Wykrzyknik!!
- Others must be discovered...
Authors: Elyxir, Alin2008Todor
Download all parts for all the files to let the map work...
Unpack Part 1, The rest will unpack in the same Folder.
( Parts split by Me )
Part 1:
Part 2:
Part 3:
part 4:
05/12/2016 09:34 PM
 Podziękowań: Narzew
  [ETS2] Romanian Map v9.25 [1.28.x] Darson 5 4,107 12/09/2017 01:36 PM
Ostatni post: lukaszek34
  [ETS 2] The Dutch Map Rene-GAD 8 9,127 07/11/2014 06:56 AM
Ostatni post: phil01320
  [ETS 2] Russia Map Express v 3.8 for 1.12.1 Rene-GAD 9 8,876 11/09/2014 05:31 AM
Ostatni post: Rene-GAD
  [ETS 2] MMG MAP New Version V1.0 Rene-GAD 0 2,754 30/08/2014 02:21 PM
  [ETS 2] Nez MAp 1.2 for 1.12 Rene-GAD 0 2,774 30/08/2014 02:12 PM
