Map editor nie zapisuje
MacMax Offline
Podziękowano mu 1 raz(y)
Siema! Mam problem z map editorem na 1.38
Grę mam uruchomioną jako administrator. Według tutoriali niby wszystko się zgadza a mapa się nie zapisuje.
Log: 00:00:43.400 : <ERROR> [ufs] Failed to mount ../../base_map in read-write mode.
00:00:43.400 : <ERROR> [fs] Failed to open file '/[base_map:1:writable]/map/xdf.mbd' in the create_truncate mode.
00:00:43.400 : <ERROR> Unable to create file '/[base_map:1:writable]/map/xdf.mbd', will retry
00:00:45.401 : <ERROR> [fs] Failed to open file '/[base_map:1:writable]/map/xdf.mbd' in the create_truncate mode.
00:00:45.401 : <ERROR> Unable to create file '/[base_map:1:writable]/map/xdf.mbd', will retry
00:00:47.402 : <ERROR> [fs] Failed to open file '/[base_map:1:writable]/map/xdf.mbd' in the create_truncate mode.
00:00:47.402 : <ERROR> Unable to create file '/[base_map:1:writable]/map/xdf.mbd', will retry
00:00:49.403 : <ERROR> [fs] Failed to open file '/[base_map:1:writable]/map/xdf.mbd' in the create_truncate mode.
00:00:49.403 : <ERROR> Unable to create file '/[base_map:1:writable]/map/xdf.mbd', will retry
00:00:51.403 : <ERROR> [fs] Failed to open file '/[base_map:1:writable]/map/xdf.mbd' in the create_truncate mode.
00:00:51.403 : <ERROR> Unable to create file '/[base_map:1:writable]/map/xdf.mbd', will retry
00:00:53.403 : <ERROR> [fs] Failed to open file '/[base_map:1:writable]/map/xdf.mbd' in the create_truncate mode.
00:00:53.404 : <ERROR> Unable to create file '/[base_map:1:writable]/map/xdf.mbd', will retry
00:00:55.404 : <ERROR> [fs] Failed to open file '/[base_map:1:writable]/map/xdf.mbd' in the create_truncate mode.
00:00:55.404 : <ERROR> Unable to create file '/[base_map:1:writable]/map/xdf.mbd', will retry
00:00:57.404 : <ERROR> [fs] Failed to open file '/[base_map:1:writable]/map/xdf.mbd' in the create_truncate mode.
00:00:57.405 : <ERROR> Unable to create file '/[base_map:1:writable]/map/xdf.mbd', will retry
00:00:59.405 : <ERROR> [fs] Failed to open file '/[base_map:1:writable]/map/xdf.mbd' in the create_truncate mode.
00:00:59.405 : <ERROR> Unable to create file '/[base_map:1:writable]/map/xdf.mbd', will retry
00:01:01.405 : <ERROR> [fs] Failed to open file '/[base_map:1:writable]/map/xdf.mbd' in the create_truncate mode.
00:01:01.405 : <ERROR> Unable to create file '/[base_map:1:writable]/map/xdf.mbd', will retry
00:01:03.406 : <ERROR> [fs] Failed to open file '/[base_map:1:writable]/map/xdf.mbd' in the create_truncate mode.
Pozdrawiam.
29/07/2020 06:56 PM
Tymuś Offline
Liczba postów: 1
Podziękowano mu 3 raz(y)
RE: Map editor nie zapisuje
Cześć, miałem ten sam problem na 1.38. Z tego co zrozumiałem to mapa zapisuje się w innym folderze.
Zamiast tworzyć folder ,,base'', utwórz folder o nazwie ,,base_map''. (W plikach lokalnych gdzie zapisuje się edytowana mapa)
U mnie pomogło Smile
09/08/2020 07:37 PM
 Podziękowań: Bozo , Michal_Z_gno , Pablo1985a8
  Map Editor – brak cieni Kamilziaja054 3 743 02/10/2024 02:29 PM
Ostatni post: Kamilziaja054
  Własna firma Map Editor oshee/man 1 1,906 20/04/2023 08:11 AM
Ostatni post: manfredo
  Podkład Do Map Editor Pumpkin Johny 1 1,344 21/11/2022 06:07 PM
Ostatni post: Adam.J
Star Jak umieścić własny skin na naczepie/ciężarówce w map editor BlondynYT 3 2,320 22/02/2022 08:37 PM
Ostatni post: BlondynYT
  Map edytor nie zmienia nic na mapie. StanislawTDI 13 2,812 14/10/2021 01:48 PM
Ostatni post: RadolSzczecin
